My 1999 Taco TuRD Build - I sold it
Discussion in '1st Gen. Builds (1995-2004)' started by xtremewlr, Nov 2, 2018.
  1. Dec 2, 2019 at 10:00 AM
    #341
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    It was already there, factory.
    Phessor likes this.
  2. Dec 2, 2019 at 10:16 AM
    #342
    Phessor
    Phessor Well-Known Member
    The previous owner already swapped in a spring there.
  3. Dec 2, 2019 at 10:33 AM
    #343
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Nope, mine was all factory when I got it. I doubt the previous owners even had a clue about the spring swap.
  4. Dec 2, 2019 at 10:46 AM
    #344
    cynicalrider
    cynicalrider #NFG
    Jersey
    :thumbsup: I have had a linear spring on my work bench for a while now. :anonymous:
    xtremewlr[OP] likes this.
  5. Dec 2, 2019 at 10:47 AM
    #345
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Flat blade screw driver and a pair of pliers and 5 minutes to do it.
    slander likes this.
  6. Dec 9, 2019 at 8:57 AM
    #346
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Nice build, one thing about inverters and inductive loads(compressors) you can be looking at between 16 -24 amps at start up. So you might be able to go with a smaller inverter- they are rated at their peak wattage(if memory serves correctly) which is about double continuous load wattage. You might be able to get by with starting the compressor with the tank drain open (like a compression release)and then close it once it starts.
    I went with the Viair 400P:
    https://www.amazon.com/VIAIR-40043-400P-Portable-Compressor/dp/B000X9AXR8
    Update: figured that you would have gone to onboard air so some of this is moot, but once again, nice job on your rig, well done!
    Nice country for wheelin enjoy it and treat it nice so your kids can enjoy it as well.
    Cheers
    xtremewlr[QUOTED][OP] likes this.
  7. Dec 9, 2019 at 9:44 AM
    #347
    Arctic Taco
    Denali Park, Alaska
    Epic build going on here, well done.
    I had the same bend on mine, I think mine was done while the PO was out wheeling and got it stuck in a creek. Same thing, it looked like he hit a rock with the tow hook, bent the stock skid bracket among other things. When I replaced the center console I found about 3/4 an inch of packed sand under it, so that explains a lot of the drama/trauma I have found on my rig.
  8. Dec 18, 2019 at 12:17 PM
    #348
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
  9. Dec 18, 2019 at 12:26 PM
    #349
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I used the existing hardware, didn't change anything. Fender liner is held in place with plastic fender clips that accept a screw. I did not use the 01-04 blue or red fender clips for the flares, just the factory, 1999 bolt holes.
    One of these 3 should work:
    https://www.amazon.com/dp/B07H89JJ8M
    https://www.amazon.com/dp/B07FW3ZD7H
    https://www.amazon.com/dp/B07FW4VT6
  10. Dec 18, 2019 at 12:44 PM
    #350
    betterbuckleup
    Ian
    Concord, CA
    Gotcha. Thanks!
    Any particular screw that you used, with a washer or anything?
  11. Dec 18, 2019 at 12:48 PM
    #351
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Factory screws are the self tappers for plastic. You can really use whatever works best with those grommets. Using a fender washer with them is always a good idea since it spreads the load over a larger surface. I actually plan on going through all of them to replace the original grommets with ones that I linked and new screws with fender washers.
  12. Dec 18, 2019 at 1:05 PM
    #352
    betterbuckleup
    Ian
    Concord, CA
    that's what I figured. I'll probably use some fender washers as well to help with that.
    Thanks for the links!
    Just ordered a set of the inserts.
  13. Jan 11, 2020 at 3:28 PM
    #353
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    A little late to the party, but I just did this a couple months ago too. So glad to have that squeak gone.
    Best.
    Mod.
    Ever.
  14. Jan 11, 2020 at 3:50 PM
    #354
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I didn't have a squeak but you can see by the spring it was only a matter of time before something broke up there. And the part where it hooked in was even worse!
  15. Apr 5, 2020 at 2:06 AM
    #355
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    Really nice work. I've just read up to this point and was wondering why you welded the 1/4" spacers to the frame. FYI, I was drawn to your build because of the Costal Offroad bumper. I'm considering one.
  16. Apr 5, 2020 at 3:01 AM
    #356
    rybern
    N Alabama
    I'm enjoying watching your progress. What feedback led you away from the full hoops?
  17. Apr 5, 2020 at 7:12 AM
    #357
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The 1/4" end caps add some strength for the bumper mounting and completely seal up the front of the frame horns. 1/4" plate is what I had so I used it, thinner material could also be used there.
    Ease of access for working on the motor mainly. And I was torn on the look with the headlight hoops. I still have them so can weld them up if I ever decide too.
  18. Apr 5, 2020 at 9:12 AM
    #358
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    You still liking that Coastal rear bumper? How is the spare carrier doing for you? I’m still really interested in going with their bumper eventually.
  19. Apr 5, 2020 at 9:17 AM
    #359
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Love it. The swingout is great after I re-made it with the 4xInnovations parts, completely rock solid. The hiems and latch that Coastal uses just weren't working for me, I don't know if I just had them setup wrong or what. I also definitely recommend adding the extra kicker bar on the swingout side to help stabilize the bumper wing, it flexes too much otherwise.
    jubei[QUOTED] likes this.
  20. Apr 5, 2020 at 10:39 AM
    #360
    jubei
    NoCo
    Stuff. Also things.
    Nice! Thanks for the update.
    I’ll have to go back thru your build and read up on the mods you did to it. It’s by far my favorite HC rear for the 1st Gen, and I’ve heard nothing but good things about working with the company.
