My 1999 Taco TuRD Build - I sold it
Discussion in '1st Gen. Builds (1995-2004)' started by xtremewlr, Nov 2, 2018.
  1. Feb 16, 2019 at 2:16 PM
    #141
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Yup, it's got a lock on it. Not foolproof but better than nothing.
  2. Feb 16, 2019 at 9:33 PM
    #142
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Frame horn reinforcement completed today and the passenger side looks much better, even if the bolts still install crooked. They are a little straighter than before I think.
    Driver side all welded in, except for on the engine side. Eventually I might be able to get those done.
    Primed it up for paint.
    After some tips from @Adude, I cleaned up and trimmed the driver side some more and then burned that into place, using a C-clamp to bring the 1/4" plate into line with the frame. Still is a little bent but it's way better and stronger than before.
    Finished up with Krylon bedliner. Ready for the new bumper, once it arrives.
    Ngneer, loyaltothetaco and jubei like this.
  3. Feb 16, 2019 at 10:50 PM
    #143
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    That looks great man, and your welding has improved in just one project!:thumbsup: You know you got good penetration from the blued .25 plate nice consistent heat zone. 2 years from now you will look at it and want to re weld it, just like everyone does.:cheers:
    You can also tack a piece like that in so its flat. Secure it on the ends, then use the weld to draw the weaker bent material down to it by filling the gap. As the weld cools the weld will shrink pulling it the weaker material in. Using short 1 in welds in unison.
    Keep at it man:burnrubber:
    jubei and xtremewlr[QUOTED][OP] like this.
  4. Feb 16, 2019 at 10:51 PM
    #144
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @xtremewlr I'm going to assume that those CBI Frame Plates are welded on for increasing the strength of the stock frame. Is this for more weight capacity or just to keep the frame from flexing.
  5. Feb 17, 2019 at 5:45 AM
    #145
    cynicalrider
    cynicalrider #NFG
    Jersey
    Do you have a link for the large power steering cooler? Love your inline filter location, much easier to access there.
  6. Feb 17, 2019 at 7:44 AM
    #146
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Tacoma frames are known for being somewhat week, especially the 1st gens like ours behind the cab. With the added weight of the rack and the RTT on said rack, plus all the crap in the bed when I go wheeling and the upcoming plate bumper with tire carrier, I thought it prudent to reinforce the rear frame. At some point I might also box the rear frame if I get a wild hair about it but that involves pulling the bed so I'm not in a rush for that.
    Thanks, I wanted to make sure it wasn't too much of a pain to get at the filter to change it but also still in a protected location.
    Here's the cooler I used.
  7. Feb 17, 2019 at 7:51 AM
    #147
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks! I already went over some of the welds on the crossbrace that the skid is mounted to. I actually tried getting that 1/4" plate to bring the bent section of the frame down some. As I was welding, I was also tightening the bolts to try to help draw the metal down while things were hot and then left them in for a little bit when I was done and everything was cooling off. Helped a little bit but not enough to really make much of a difference. The bolts are still crooked. But I should be able to work with it better than if I had done nothing. The bolts are M12 so I made the holes in the plate 1/2" but had to enlarge the rear most one on the passenger side to 5/8" to be able to install the bolt at an angle.
  8. Feb 17, 2019 at 1:49 PM
    #148
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Working on getting storage, tools and recovery gear organized and mounted in the bed. For now, I have to work around having the spare in the bed still.
    I mounted 2 sets of quick fists to the driver side bed rail and wheel well to mount the shovel and large axe.
    The box in the corner is a plastic ammo crate that I found on Amazon for $18 shipped. It's the perfect size to fit in the corner and contains my tow strap, a 10x12 tarp, tent stakes, a deadblow hammer and my small camp axe. And there is room enough to fit some more smaller items if needed. The lid is hinged and has a gasket to make it watertight with plastic latches on each end. Not so watertight now, since I drilled a couple holes in the bottom to bolt it to the bed with a couple of rivet nuts. But I really like the can and just ordered another one for the passenger side.
    I mounted my High Lift Off Road base to the bottom of the tent, making use the rails that are already there and a couple of carriage bolts with wing nuts and some fender washers. For now, I have it mounted on the open end but will probably move the mounting bolts so they are between the bed rack rails so I can slide the base further back towards the cab. I could mount the bas on the cab end but there was less mounting surface there as the tent is slightly shifted toward the back of the truck.
    I had to drill a couple of new holes in the base for the mounts but they don't affect the function or strength of the base at all.
  9. Feb 17, 2019 at 2:56 PM
    #149
    Adude
    Pnw
    04 Double cab
    How does the durability of that ammo can feel? Does it seem like the lid will crack in half? That would be a awesome option instead of my rubber maid tubs.
  10. Feb 17, 2019 at 3:00 PM
    #150
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    They are built pretty well IMO. I wouldn't put a lot of weight on the lid, like stand on it but it should hold up to lighter items on it. Mounted in the bed, it measures about 9 1/4" from the bed to the top of the closed lid. They have other sizes available too and for the price, they are worth it.
    Adude[QUOTED] likes this.
  11. Feb 19, 2019 at 1:55 PM
    #151
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Got my 2nd ammo can and mounted it today. Worked out perfect as I can still fit my 2 gas cans between them. Between the ammo cans and the Husky storage boxes I got for the cab, I have a ton of secured storage now.
    Both ammo cans are bolted to the bed of the truck. I'll throw a strap between the 2 corner anchor points on the bed to secure the gas cans.
  12. Feb 19, 2019 at 2:03 PM
    #152
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Very nice, man! I like how you’re handling storage with the spare in the bed. I know how challenging that can be.
    xtremewlr[QUOTED][OP] likes this.
  13. Feb 19, 2019 at 2:06 PM
    #153
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, doing what I can for now. Got the tracking number for the front bumper today, hopefully the rear is included with it. The rear I got with tire carrier so the spare in the bed shouldn't be for too much longer.
    jubei[QUOTED] likes this.
  14. Feb 28, 2019 at 6:14 PM
    #154
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Bumpers arrived this past Tuesday and I have started work on them. The small ammo cans worked out perfectly and were water tight during this past weekends wheeling and camping trip.
    Few pictures from the trip. From left to right, @Phessor , @Sapnjack , myself and @Ace115
    MR E30, jubei, Ace115 and 2 others like this.
  15. Feb 28, 2019 at 6:49 PM
    #155
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I have to admit, these tent platforms look really good, but setting up a regular tent and sleeping on the ground is a whole lot cheaper. I need to win the lottery, so that I can spend a ton doing some of the mods, I'd like to do. As it stands right now, my budget only allows keeping up basic maintenance, and realistic suspension improvements.
    Arctic Taco, Ngneer and xtremewlr[OP] like this.
  16. Feb 28, 2019 at 6:51 PM
    #156
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The RTT beats sleeping on the ground, especially when you wake up to 13 degrees with snow and ice on the ground! Keep an eye on craigslist and the for sale sections here on the forums and you can find them pretty inexpensive. Just takes patience.
  17. Feb 28, 2019 at 6:53 PM
    #157
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I didn't mind sleeping on frozen ground when I was 20 years younger. Now with all the added titanium in my spine, it will most likely act as a conduit for cold to permeate my body and freeze my old ass off.
  18. Feb 28, 2019 at 7:00 PM
    #158
    Sapnjack
    Sapnjack Well-Known Member
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
    Bilstein 6112/5160 Dakar EL096R Leaf Springs KO2 265/75/16 Tires OCF Rock Sliders Cali-Raised Hidden Lightbar Diamonback Cover HD KB VooDoo Premium Rack CVT Tent ARB Awning
    I second that... smitybilt tent runs $730 new and can be cheaper on the used market. Basic racks can be had for cheaper as well, especially if just holding up a tent
    Ace115 and xtremewlr[QUOTED][OP] like this.
  19. Mar 1, 2019 at 9:06 AM
    #159
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Spent a little time this morning replacing vacuum lines and various others that don't hold any pressure. All new lines are black silicone from siliconeintakes.com. Nice heavy walled stuff so it shouldn't collapse under vacuum.
    Doesn't really look like I changed anything. Still a few lines to replace but they are much more difficult to get to.
    Arctic Taco and loyaltothetaco like this.
  20. Mar 1, 2019 at 9:47 AM
    #160
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @xtremewlr great idea, when can you drive over and do mine for me. :)
    xtremewlr[OP] likes this.
