My 1st Gen needs your help with a little lift
Discussion in 'Suspension' started by shoeless, Nov 29, 2013.
  1. Nov 29, 2013 at 11:16 PM
    shoeless
    shoeless [OP] Well-Known Member
    Brian
    Nashville
    I know….there are multiple threads on this already….which is why Im confused.
    Ive been researching endlessly but still don't know what I should get.
    I am coming from a VW that only needed a good set of coil overs to improve handling so Im really lost with what is best here.
    Thinking Ill just need ~2" of lift or so. Truck is a 03 DC Prerunner, so it won't be seeing many rocks. Some easy trails and camping use will be its primary terrain(other than daily driving). Looking to fit a set of 265/75 Duratracs.
    From what Ive gathered, Im leaning towards the Eibach/Bilstein setup.
    5100s front & rear
    Eibach springs up front
    But Im lost on an AAL or new leaf pack. What would be best to level everything out?
    Is there anything Im missing?
    Looks like wheelers has the best prices on most stuff. Any other suggestions?
    Thanks for any help. I know this topic has been beat to death.
  2. Nov 29, 2013 at 11:26 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    First off, with the Eibach/Bilstein setup up front you will get over 3" of lift. The Eibach coils are rated for 620lbs. But that's what I'm running and I have no issues with it.
    I currently have an add-a-leaf in the rear, but mine have sagged again because I've flexed it so much. So I have a new set of leafs waiting to be installed. If you don't haul heavy loads and don't plan to flex the rear all the time, then there is nothing wrong with an add-a-leaf. I ran one on my 96 for over a year with no sagging issues.
    As for other things you will need, I recommend new u-bolts.
    Here's a list of what I recommend...
    I want to say the total cost of my lift ran me about $550 for all of this...
    Shocks
    Coils
    Add-a-leaf
    u-bolts
  3. Nov 29, 2013 at 11:28 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    If you want 2" lift. Take a look at the Old Man Emu coils
  4. Nov 29, 2013 at 11:30 PM
    PcBuilder14
    Brent
    Southern New Mexico
    Yes, if you prefer to not have that much lift then OME is a great option as well. I recommend the 881 coils and no top plate spacers to keep you under 3" of lift.
    If you have the extra cash, go for the new leaf springs as well. Unless you plan on carrying heavy loads. Then I recommend some different leafs.
    http://toyteclifts.3dcartstores.com/Old-Man-Emu-Tacoma-suspension_p_225.html
  5. Nov 29, 2013 at 11:35 PM
    shoeless
    Brian
    Nashville
    I don't need to be at 2"….3" would be fine. Just figured it would up my costs a bit and be unnecessary for my needs.
    From my research, Ive gathered the OME stuff is good, and many seem to like theirs, but the ride suffers a bit. I could be wrong though….
  6. Nov 29, 2013 at 11:37 PM
    shoeless
    Brian
    Nashville
    And I won't be hauling anything too heavy or doing much flexing.
    A camper shell is a possibility though.
    An AAL would be ok then?
  7. Nov 29, 2013 at 11:37 PM
    PcBuilder14
    Brent
    Southern New Mexico
    Your ride will improve whether you go with OME or Eibach/Bilstein over stock.
    The Eibachs tend to be more stiff, but very stable.
    OME is softer but still provides a much better ride over stock.
    An add-a-leaf should do you fine then. :thumbsup:
  8. Nov 30, 2013 at 7:11 AM
    shoeless
    Brian
    Nashville
    Thanks for the advice.
    How does your AAL ride? The site says it's rough.
  9. Dec 2, 2013 at 6:56 PM
    shoeless
    Brian
    Nashville
    So, I had a look under the truck today and noticed the leafs were nearly flat. Is this normal for stock or are they worn out?
  10. Dec 2, 2013 at 6:59 PM
    PcBuilder14
    Brent
    Southern New Mexico
    Mine was pretty much flat as well. After that many miles they all do that.
