My 1st issue 2017 w/ 230k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Artjr, Jul 20, 2020.
  1. Jul 20, 2020 at 3:42 PM
    Artjr
    Artjr [OP] Well-Known Member
    Art
    2017 SR 2.7
    Cruise Keyless entry Apple Carplay
    Finally, something is going wrong. My AC will not come on (Press ac button it lights for 3 seconds and goes off ) for 5 or 10 minutes in the morning. Once it comes on it works fine. I’ll stop and shut it off for a hour or two and it comes right back on. Leave it sit over night and same deal , need to run 5-10 minutes. Any ideas. I’m thinking it must be some type of pressure switch or something like that.
  2. Jul 20, 2020 at 4:03 PM
    Tacospike
    Two Trucks
    You need a recharge probably? Just some ac refrigerant. First thing i would do
  3. Jul 20, 2020 at 4:32 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    This sound like you are just barely almost too low on freon.
    Low pressure switch shutting system down, then as it warms it meets the spec, runs until it can't and shuts down.
    tacomakid96, Boghog1, AKGSD and 3 others like this.
  4. Jul 20, 2020 at 4:42 PM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Wyd driving 75k a year? Is it a work truck... just curious. I second the charge. Unless third gens are like the 2nd gens and it will only work on high. Something to do with the high setting running off a different component I believe. Maybe different blower actuator it’s been a long time. Glad to hear no other issues.
    DAS Taco and wrightme43 like this.
  5. Jul 20, 2020 at 6:35 PM
    Artjr
    Art
    2017 SR 2.7
    I believe this. I’ll check into that
    hiPSI likes this.
  6. Jul 20, 2020 at 6:38 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Glad you believe it because it's true!
    Skydvrr likes this.
  7. Jul 20, 2020 at 6:39 PM
    Artjr
    Art
    2017 SR 2.7
    Yes, I use it for work. The last one I put 389k on it. The blower motor works fine. It’s something do do with compressor not kicking on. Low pressure switch or low pressure itself.
    SR-71A likes this.
  8. Jul 20, 2020 at 6:42 PM
    Artjr
    Art
    2017 SR 2.7
    since you have a Tundra also. I just got one last week. Lovin this thing. The AC works fine226F8ED5-0E39-42A6-8832-96E8B7BE6954.jpg
  9. Jul 20, 2020 at 7:13 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    If i were to venture a guess, its probably a switch. Yea you've got lots of miles, but freon does not evaporate, unless of course there is a leak somewhere. Gl, let us know what it is once you get it sorted.
    Congrats on Tundra too, its a beast
    SR-71A and wrightme43 like this.
  10. Jul 20, 2020 at 7:27 PM
    wrightme43
    Yes sir, there is probably a seep. It will get worse over time. If it is low ask for uv dye injection with the insanely expensive new 1234y freon. It may last for a year or two, but no matter what with the uv dye you will know what is leaking.
    Hope this helps. I don't understand what dye is not installed at the factory. It would save 1000s of man hours, and 1000s of dollars every year.
  11. Jul 20, 2020 at 7:32 PM
    Knox_Taco
    Knox_Taco Well-Known Member
    17’ Off-road 6-spd Manual
    Can we get a picture confirming this 230k miles? :headbang:
    SR-71A and BGXtobe like this.
  12. Jul 20, 2020 at 7:33 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Hard to beat the 4bangin reliability!
    Sandy94, 9th and BillsSR5 like this.
  13. Jul 20, 2020 at 7:35 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Over time, it does. There is no perfect seal...
    bbartol, 4x4_Taco and G8R_Taco like this.
  14. Jul 20, 2020 at 7:36 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    230k! Hell yea, man!
  15. Jul 20, 2020 at 7:38 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I really like my Tundra. Drove it on a 9,000 mile adventure in March lol.20200224_114512.jpg
    BillsSR5 and Artjr[QUOTED][OP] like this.
  16. Jul 20, 2020 at 8:24 PM
    3r3Taco
    3r3Taco Well-Known Member
    So.Cal
    17 SR5 DCSB
    Factory Stock
    Any other issues encountered ? Out side from Routine maintenance?
  17. Jul 21, 2020 at 2:26 AM
    Professor D
    Gregorny
    Mass
    Yes
  18. Jul 21, 2020 at 5:37 AM
    Artjr
    Art
    2017 SR 2.7
    Nothing but be a little dash rattle and sticky instrument cluster both were taking care of around 5000 miles
  19. Jul 21, 2020 at 5:41 AM
    Artjr
    Art
    2017 SR 2.7
    This is from a few weeks ago
  20. Jul 21, 2020 at 5:52 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Put some gages on it and test it.... Seems it’s earned a little tlc, fantastic long term report.
