My 2,500 mile 2023 Off Road will not move this morning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sandthemall, Oct 3, 2023.
  1. Oct 3, 2023 at 8:24 AM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    This happened to me once after washing the car. Was confused at first, then read on here, gave it a ton of gas and it finally broke free.
    WesNeedsCoffee likes this.
  2. Oct 3, 2023 at 8:29 AM
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    Put some WD-40 on the parking brake pads to prevent this from happening again.:rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
  3. Oct 3, 2023 at 8:33 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    safer to just remove the brakes altogether
  4. Oct 3, 2023 at 8:35 AM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    If I wash my truck and park it on the hill I live on sometimes the rear drums will flash rust and get stuck. I’ve chirped the tires a few times and have to break it free before it will move.
  5. Oct 3, 2023 at 8:35 AM
    kona61
    J
    RCI Skids
    Yep, he’s got a manual. He’ll be fine.
    doublethebass[QUOTED] likes this.
  6. Oct 3, 2023 at 8:48 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I don't know man, this sounds like a bad idea. Lubricants and friction braking typically don't mix well.
    Mad German[QUOTED] and Chew like this.
  7. Oct 3, 2023 at 9:01 AM
    Mad German
    2016 TRD Off Road
    I was joking...
    Junkhead and kona61 like this.
  8. Oct 3, 2023 at 9:07 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    If the rear wheels are “burning out” that’s where the parking brake is. Seems like it’s an issue with the front … if anything
  9. Oct 3, 2023 at 10:08 AM
    Sandthemall
    Sandthemall [OP] Well-Known Member
    Sandamal
    2023 TRD OR MT
    @doublethebass
    The locker, of course! Makes sense. Will do, thanks!
    doublethebass likes this.
  10. Oct 3, 2023 at 10:24 AM
    Buck Henry
    Well that's a relief! But consider that there are some folks out there that are not very vehicle savvy and might take your comment seriously. Maybe include one of those smiley face things next time you are cracking a joke that could get someone killed.
  11. Oct 3, 2023 at 10:45 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If it was like my truck that i posted about hopefully you'll never have this happen again. After giving mine enough gas there was a load noise when it freed... thought i messed something up but it's drove like new ever since.
  12. Oct 3, 2023 at 10:50 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Next time, after the car wash, drive the truck for longer distances to heat up the brakes and dry them out. Don't park it for the day when they're still wet.
  13. Oct 3, 2023 at 11:03 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    this happened to my 2nd gen. Got so stuck had to have it towed to dealership.
    After washing I either drive it several miles or chalk wheels and don't put on the parking brake.
    davidstacoma likes this.
  14. Oct 3, 2023 at 11:17 AM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    This happens all the time with semi trucks with drum brakes, just have the benefit of an extra axle and 5-7x the torque to the break free the flash rusting and it helps to mostly not park in low traction spots by the very nature of the vehicle operating conditions. But basically that is the magic way of freeing up flash rusted drums, applying lots of torque particularly in reverse first if possible (due to the design of drum brakes it takes less force to break free in reverse, same goes for iced, literally frozen, drums).
    Basically everything you did in your update post is the same kind of tricks everyone else uses in combination, or by themselves, generally in order of ease of application, the easiest being applying the brakes as hard as possible/applying lockers/transfer case, etc anything that doesn't involve leaving the driver's seat.
    Banging on the drums with a hammer and/or torch was last as crawling around in the mud/snow not being the funniest of tasks to free frozen, by rust or ice, brakes.
    Just leave it in 1st and don't use the parking brake, alternatively you can drag your brakes by applying your parking brake slightly, as if you where applying the service brakes to gently coast to a stop, to heat them up and vaporize the moisture in the drum, and this does make sure they are ready for use on demand for full brake application when needed much sooner then letting them dry naturally, which does take time with a sealed drum design.
    doublethebass, Bertw192 and Hogleg918 like this.
  15. Oct 3, 2023 at 12:03 PM
    #35
    Mad German
    2016 TRD Off Road
    It's been corrected. :thumbsup::rofl::thumbsup::rofl::thumbsup::rofl::thumbsup::rofl:
  16. Oct 3, 2023 at 12:09 PM
    #36
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Quit washing your truck...problem solved.
    Junkhead and Sandthemall[OP] like this.
  17. Oct 3, 2023 at 12:12 PM
    #37
    Sandthemall
    Sandamal
    2023 TRD OR MT
    I'm 56...you think I would have experienced this at least once with all the trucks I've owned and living on the east coast and mid west as as well.
    But next time I'll drive it a bit to heat and dry the brakes. The car wash is just uphill from me...and being the savvy driver I am I was able to drive down the hill and make a left onto my street without ever having to use the brakes until I parked. I'm sure that's what caused this.
  18. Oct 3, 2023 at 12:15 PM
    #38
    CTtoNoVa
    Pop N Lock
    After that day I did. I figured it was better to have a dirty truck with bird crap all over it.
    zoo truck[QUOTED] likes this.
  19. Oct 3, 2023 at 12:20 PM
    #39
    zoo truck
    None
    Heck, you ought to see all the bird poop that collects on mine till it rains.
  20. Oct 3, 2023 at 1:17 PM
    #40
    trenchdigger
    trenchdigger Active Member
    southern Ontario Canada
    2020 trd sport, mgm, long bed
    bone stock
    Has happened to my 2020 sport a few times after washing it and then not driving it for a while,mine seems to break loose fairly easy if I put it in reverse and back up a bit
