My 2000 V6 Temp Gauge showing Hot
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tboner78, Mar 13, 2015.
  1. Mar 13, 2015 at 10:44 AM
    Tboner78
    Tboner78 [OP] Member
    Trevor
    Northern California
    SR5
    2" lift in front and 3" in rear with off set rims with 32/10.50
    I noticed about 6 months ago I had just started the truck and looked down and notice the gauge pegged hot I quickly stopped the truck and turned the engine off popped the hood and it was not hot at all got in the truck started it up and tapped the dash above the gauge and the needle went to normal. over the next 6 months it had been doing this and I would just tap the dash and it would go to normal. Now as soon as I start the truck it always pegged hot. I recently had the radiator and hoses replaced so I know I am not actually overheating but it is a bit unnerving to see your gauge pegged hot. My brother said its grounding out need help with locating this ground and how to fix this any help would be great thanks
  2. Mar 19, 2015 at 2:02 PM
    Tboner78
    Trevor
    Northern California
    SR5
    Need help where can I look to find this problem now when I start the engine anytime it goes right to hot has anybody experienced this problem
  3. Apr 20, 2015 at 9:18 AM
    sernabe
    sernabe Member
    brian
    Casa Grande
    05 SR5 TRD
    SnugTop camper shell
    did you ever figure out your issue?
