My 2004 Tacoma "Failed"
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMike, Apr 26, 2010.
  1. Apr 26, 2010 at 4:33 PM
    TacoMike
    TacoMike [OP] Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    I took my '04 in for a frame inspection today and it failed. I think I'm kinda relieved, as I was debating on whether to trade it in or not. It's been paid for since last summer. The frame has a lot of surface rust on it, but didn't think it would fail. There was one next to mine that was getting a new frame, and the technician explained what they do and how they do it. While it's being reframed I'm gonna have them do the 5100 install on the fronts, new rotors and brakes, new bushing kit, and whatever else I can come up with. If you guys have any suggestions throw them out there. There will be a small labor charge for the front shocks, and none for the rear. The truck only has 58,000 miles on it. I gotta go do some shopping, talk at you later. Mike
  2. Apr 26, 2010 at 4:44 PM
    h_curtis
    h_curtis Well-Known Member
    Wholly shite! An 04? I thought I was not to worry. Mine is an '03. I have to get that checked!
  3. Apr 26, 2010 at 4:53 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    So how long till the 2nd gens start rustin out? 2004 is only 7 years old!!!
  4. Apr 26, 2010 at 7:24 PM
    HusqyRider
    HusqyRider Well-Known Member
    Adam
    La Mirada, CA
    01 Tacoma Prerunner SR5
    Bilsteins, HD Bakflip G2, Popnlock
    04 in Penn? A lot of winter driving, no? I have an 01 in Calif. I guess I'll be in no rush to sell the Jeep. I thought the problem was resolved and it only affected 95-2000s?
  5. Apr 27, 2010 at 12:40 AM
    TacoMike
    Pennsylvania
    We get about 5 months of winter weather here, November thru March. They use a brine solution as well as salt on the roads. I received a letter from Toyota awhile back stating I should have it checked, and I'm glad I did. The recall is only for those states that encounter heavy winter conditions.
  6. Apr 27, 2010 at 1:57 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    X2. Only for the saltbelt. They dont rust like that here in tha south! :D
  7. Apr 27, 2010 at 1:58 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Well as many problems as your haveing probably in the next few days for you. Lol jk. ;)
  8. Apr 27, 2010 at 9:53 AM
    mlittle
    mlittle T O Y O T A
    Michael
    Fort Sill, OK
    2014 Toyota Tundra Crew Max 4x4
    Where in PA are you located? I have a 2003 with similar mileage. The closest dealer to me can't spray the frame until they get approval from the township. I will call around to set up an appointment to take my truck in for inspection.
  9. Apr 27, 2010 at 9:58 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Oh really, if you qualify for the frame coating or replacement depends on where you live? I came close to buying an 01 from a guy in SC. He said that he had owned in in marlyand for a while. I wonder if it had rusted and I brought it in, what toyota would say? Does it depend on the original purchase location or current location?
  10. Apr 27, 2010 at 10:18 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I think Toyota needs to tone down their commercials about "quality"...:rolleyes:
  11. Apr 27, 2010 at 10:53 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    ...What is this "RUST' you speak of???
    (j/k....Im glad we dont have these issues in Cali)
    Good Luck!
  12. Apr 27, 2010 at 10:59 AM
    Kitty
    Kitty Beware: I bite! ^_^
    Kelly
    Alabama
    02 "Lunar Mist" Xtra PreRunner
    billet grille, clear corners, bug shield, window tint, under-rail bed liner, and running boards.
    The coating/replacement is determined by if it fails or not. If it fails then they will replace if 2001-2004, buy if older. If it passes they will coat it. The only reason location plays a factor at all is b/c in areas where they salt the roads there is a higher chance of it failing.
  13. Apr 27, 2010 at 11:11 AM
    x2468
    It sounded for a second like they would only spray the preventative coating if you live in an area that salts the roads heavily.
