My 2006 Tacoma brake upgrade (EDITED!!)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DG92071, Feb 14, 2020.
  1. Feb 10, 2023 at 4:23 AM
    #241
    TaylorTRD
    TaylorTRD Big ole log thumper
    Taylor
    Eastern Berks/Lehigh Valley PA
    14 Tacoma DCLB TRD Sport 4x4
    TRD catback exhaust, Volant CAI with Powercore filter, Meso Customs Red/White LED map lights, Sequential smoked 3rd brake light, Morimoto XB LED foglights
    No worries, I'm not exactly ready to tackle this project yet. My brakes are still fairly good up front but I do plan on towing a small camper with my truck down the road. I may just swap all of this stuff to help with braking while towing and just in general, better brakes are always a good thing. Thanks for the info guys
    PapaBear likes this.
  2. Feb 10, 2023 at 7:09 PM
    #242
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @YamaDirtrider lines received! Awesome job!
  3. Feb 13, 2023 at 5:42 PM
    #243
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Texoma likes this.
  4. Feb 14, 2023 at 7:11 AM
    #244
    DG92071
    DG92071 [OP] Well-Known Member
    Most Tacoma owners that only changed the rotors and calipers report a spongey brake pedal with a loss of brake performance.
    Bigger calipers have bigger pistons (usually) and without moving more fluid with a larger master cylinder (larger piston) the brake pedal will have to move further to move those larger pistons with the same force on the brake pad/rotor as a smaller master cylinder piston could. So when there's more fluid moving the pedal will have to be pushed harder to get the same amount of pressure on the pads OR you put a bigger booster on to do the additional work.
    It's a total package deal, you either do the whole (easy) job or you get disappointed.
    TaylorTRD[QUOTED] likes this.
  5. Feb 14, 2023 at 7:25 AM
    #245
    TaylorTRD
    Taylor
    I get it, and will most likely do the full swap down the road more for towing purposes. I want the best braking I can get if I'm going to be towing without going full BBK. I don't have the cash or need for all that. This seems more doable.
    DG92071[OP] likes this.
  6. Feb 15, 2023 at 10:01 AM
    #246
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    re energized to do some work on my truck and read through this thread. If we are still looking for a few more people to get another set of GB lines made count me in!
  7. Feb 15, 2023 at 7:13 PM
    #247
    DG92071
    That's the reason I did the upgrade (for towing). My truck tows boats often. The truck stops excellent.
  8. Feb 16, 2023 at 4:07 AM
    #248
    TaylorTRD
    Taylor
    Do you have trailer brakes as well on yours?
  9. Feb 16, 2023 at 5:05 AM
    #249
    lbhsbz
    lbhsbz Well-Known Member
    2009 and later had M12 fittings on the master cylinder. 2005-2008 used M10.
    I can probably make a run of the soft lines (in either M10-M12 or M12-M12) in Stainless Braided for about $60/set shipped...let me know if there's any interest.
    moweryaviation likes this.
  10. Feb 19, 2023 at 9:10 AM
    #250
    DG92071
    No I do not. I can tow a boat up to around 3,000 lbs and it makes absolutely no difference in its stopping ability. To date it's towed a max of 6,800 lbs.
  11. Feb 19, 2023 at 10:43 AM
    #251
    moweryaviation
    moweryaviation Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    Thanks for all the detailed info OP! I just finnished my truck and the results were good like you explained. I just did the booster and MC. I might do the 4 runner calipers and discs in the future if needed. I probably need to bleed more too, however the brakes are not "Im going to die" brakes anymore. I have driven a second gen for 12 years and the brakes were always soft compared to the first gen and my firends 3rd gen. Again, thank you for the time you put into this. Im sure a bunch of TW members appriciate it.
    There are two things I would like to share. First is that my Tundra booster did not come with a vacume check valve. I needed to use the Tacoma unit. They are diffrent sizes. The Tacoma is larger. The fix for this is to buy a Tundra check valve. Second, is no one has mentioned which brake pressure port is which. The origional tacoma lines happen to line up (forward and aft) to the new MC.
    DG92071[OP], PapaBear and SUMOTNK like this.
  12. Feb 20, 2023 at 6:39 PM
    #252
    DG92071
    When the brakes are bled some sort of computer thingy needs to be hooked up to it due to the ABS module. If the thingy isn't used you'll never get all of the air out of the lines. My apologies on my crap memory, I can never remember what the computer thingy is called.
  13. Feb 20, 2023 at 6:47 PM
    #253
    PapaBear
    Austin
    SIN CITY
    Toyota Tech stream will do it, you can find devices online but it’s still cheaper to just take it in and have the dealer do it so if something messes up, it’s on them not you
    DG92071[QUOTED][OP] likes this.
  14. Feb 20, 2023 at 7:05 PM
    #254
    moweryaviation
    Dixon, California
    Thanks a bunch for the info. I bled them from the bottom up , the bled the MC to the new unions. They feel good now. This weekend my brother in law will come over and we will use his scanner to actuate the ABS solenoids and bleed again.
  15. Feb 20, 2023 at 9:44 PM
    #255
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Meh, just find some gravel road and mash the brakes a few times.
    Torspd likes this.
  16. Feb 20, 2023 at 9:47 PM
    #256
    PapaBear
    Austin
    SIN CITY
    You do you boo boo :turtleride:
  17. Feb 20, 2023 at 9:48 PM
    #257
    moweryaviation
    Dixon, California
    I have done that a time or two…..
    Torspd and TireFire[QUOTED] like this.
  18. Feb 21, 2023 at 9:26 AM
    #258
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    I think if you go backwards fast enough and hit the brakes it sometimes triggers the abs module as well.
    TireFire[QUOTED] likes this.
  19. Feb 21, 2023 at 9:50 AM
    #259
    TireFire
    Olympic Peninsula
    Never tried that. But no reason it wouldn’t work. Point is, there’s a simple way (maybe more than one) to avoid a trip to and paying the stealership. Then of course there are those that run to their safe space in the service department to have their washer fluid topped off and there is nothing wrong with that either :)
  20. Feb 21, 2023 at 11:28 AM
    #260
    US1973MC
    US1973MC Well-Known Member
    Greg
    2007 4wd Taco Access
    K&N, XM, Trifecta Tonneau
    Same here, who has the correct speedbleeder part numbers?
    Jimmy92870 likes this.
