My 2006 Tacoma brake upgrade (EDITED!!)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DG92071, Feb 14, 2020.
  1. Jun 15, 2023 at 1:09 PM
    #301
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I’ll take it!
  2. Jun 15, 2023 at 1:13 PM
    #302
    194
    194 Member
    Dave
    2007 Tacoma DBL TRD OR
    OME 2.5" Lift Full RCI Skid plates Rocky Road rock sliders ARB Bull Bar with Warn XD9000 winch CBI OR Rear bumper K&N CAI DT headers UDR Full Exhaust Tuned w/ HPTuner
    Done. PM me your deets.
    DG92071[OP] likes this.
  3. Jun 15, 2023 at 1:15 PM
    #303
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Edit…. I’m a dumbass and cant read. It’s still available
  4. Jun 15, 2023 at 1:23 PM
    #304
    194
    194 Member
    Dave
    The master cylinder is still available.
  5. Jun 15, 2023 at 5:34 PM
    #305
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Dibs
  6. Jun 15, 2023 at 5:56 PM
    #306
    194
    194 Member
    Dave
    PM me your deets.
  7. Jun 16, 2023 at 9:32 AM
    #307
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    If it falls through again I'll take it.
  8. Jun 18, 2023 at 5:27 AM
    #308
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    Is it upgrade will be work on 2015 tacoma?
    Swap booster brake and master cylinder from tundra really make big different performance huh.
  9. Jun 18, 2023 at 5:50 AM
    #309
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Does your 2015 TRD Pro have a traditional booster and master ? I thought the newer TRD models had the full electronic system ?
    Yes, it makes a big difference because the booster is a dual diaphragm design so it is much stronger.
  10. Jun 27, 2023 at 2:30 PM
    #310
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    Mine TRD Pro still has booster and master cylinder, I believe that's 3 gen TRD Pro.
  11. Jun 29, 2023 at 10:08 PM
    #311
    G_Taco
    G_Taco Member
    Gio
    2006 Tacoma
    oh man I literally live like 20 min away from you. Located over by mission trails. Any chance I can meet up to talk to you about the brake booster upgrade? Mine is leaking and I will need to replace it soon, but this seems like a better upgrade
    DG92071[QUOTED][OP] likes this.
  12. Jul 2, 2023 at 11:54 AM
    #312
    194
    194 Member
    Dave
    So, can confirm that this will 100% not work with 16" rims.
    Completed the mod MC and brake booster mod, ground down the top and bottom of the new calipers so the 16" rim would JUST clear it, bled the system, thought I was good to go. First big pump on the brake using my hand and the internals from one of calipers perforated through the wall. Welp... that was a $150 mistake. Thankfully it happened in my garage, rather than on the road. In hindsight, I think I should have been a bit more reticent to grind down the calipers.
    Went back to my original rotors/calipers, bled the system again, took it for a test drive, night and day difference. Besides tuning and putting on LT headers, this is definitely my favorite mod on the truck. Huge shout out to @DG92071 for pioneering this. Solid.
    DG92071[OP] and tacoma16 like this.
  13. Jul 4, 2023 at 5:09 PM
    #313
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    Is it necessary swap the booster with tundra one as I saw at SOS performance website they only recommend swap MC only.
    Is it tundra really a lot bigger then tacoma?
  14. Jul 4, 2023 at 6:39 PM
    #314
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    just swapping the Tudra booster alone is a huge upgrade. Your Tacoma booster is only a single diaphragm and the Tundra booster is a dual diaphragm
  15. Jul 5, 2023 at 9:04 PM
    #315
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    Thanks for clarification man.
    Definitely need hunt the tundra booster
  16. Jul 5, 2023 at 9:23 PM
    #316
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    The brakes on my 06 Tacoma suck. I've had all major components replaced and new pads. Still braking is very weak. Any ideas out there?
  17. Jul 6, 2023 at 2:07 PM
    #317
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    1. Bleed them...bleed them good.
    2. Stop tech 6 piston caliper upgrade with 340mm rotors.
    3. Tundra booster upgrade.
  18. Jul 6, 2023 at 7:10 PM
    #318
    DG92071
    DG92071 [OP] Well-Known Member
    PM sent
  19. Jul 6, 2023 at 7:13 PM
    #319
    DG92071
    Thank you!
    It's a night and day difference.
    Replaced with stock Tacoma parts or the Tundra upgrade parts?
    Do you live in Scripps Ranch?
  20. Jul 6, 2023 at 9:36 PM
    #320
    ScrippsRanch67
    Bob
    Fiberglass shell
    Yes! For 38 years. Scripps Ranch Old Pro's!
