My 2006 Tacoma brake upgrade (EDITED!!)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DG92071, Feb 14, 2020.
  1. Jul 7, 2023 at 9:56 PM
    #321
    DG92071
    DG92071 [OP] Well-Known Member
    Is your trucks MC and booster Tacoma or Tundra?
  2. Jul 7, 2023 at 10:02 PM
    #322
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    So you have stock Tacoma front and rear brakes plus Tundra MC & booster now?
  3. Jul 7, 2023 at 10:02 PM
    #323
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Tacoma stock parts
  4. Jul 7, 2023 at 10:06 PM
    #324
    DG92071
    Stock Tacoma brakes are horrible and it's why I upgraded the brakes on mine. You mentioned all of the parts were replaced, did a reputable shop bleed your trucks brakes for you after the parts were replaced?
  5. Jul 7, 2023 at 10:32 PM
    #325
    ScrippsRanch67
    Bob
    Fiberglass shell
    I had it done at Poway Toyota where I have generally had good luck. Sometimes I take my 06 Tacoma to The Truck Shop on Miramar Road in San Diego for other major work.
    Toyota of Poway bleed the lines twice after I took it back and told them I did not like the results. The brakes are still weak, as they have been for some time even before the major components were replaced. Maybe the 3rd try will be the charm?
    Next time I take in in for an oil change (they have good oil change coupons) I'll give it a shot again.
    Thanks for your response.
    DG92071[OP] likes this.
  6. Aug 17, 2023 at 9:28 AM
    #326
    moweryaviation
    moweryaviation Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    Does anyone have the software to run the ABS system for brake bleeding? I have bleed the brakes manually, but I wanted to see if there was more to gain by running the ABS. I’m in the Sacramento/Napa area. I’m happy to pay for some help. Yes, I have done the dirt parking lot trick!
    I have a 2005 Tacoma, with the tundra booster/MC and just installed a residual valve. A little help from my TW friendswould be great!
  7. Aug 17, 2023 at 1:10 PM
    #327
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Anyone with tech stream, and many of the higher end scanners will be able to as well
  8. Aug 17, 2023 at 3:19 PM
    #328
    ScrippsRanch67
    Bob
    Fiberglass shell
    Can you explain why the ABS system needs to "run" when bleeding the brakes? I've been complaining about the lack of braking on my 06 Tacoma forever. All major components have been replaced-brake booster, etc. and new pads installed, my brakes still suck. Dealer installed...does the dealer always follow the procedure mentioned above for bleeding the brake lines?
  9. Aug 17, 2023 at 6:44 PM
    #329
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Air gets stuck in the ABS module. The tech stream can open the abs solenoids individually so the air is purged out of the module. Not getting the air out of the ABS module will make your brakes spongy
  10. Aug 17, 2023 at 6:50 PM
    #330
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    @Red Baron
  11. Aug 18, 2023 at 5:43 AM
    #331
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    He likes spongy :rofl:
    Red Baron likes this.
  12. Aug 18, 2023 at 6:03 AM
    #332
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Yous a bitch! I just gotta prime the pedal once for really good breaks.......
  13. Aug 18, 2023 at 6:45 AM
    #333
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    whoa whoa bro pump the brakes now
  14. Aug 18, 2023 at 8:29 AM
    #334
    DG92071
    Why did you install a residual valve?
  15. Aug 18, 2023 at 10:28 AM
    #335
    ScrippsRanch67
    Bob
    Fiberglass shell
    Thanks a bunch. This gives me a good head start on asking MORE questions when I take my Tacoma back in shortly to the Dealership that redid my brake system.
  16. Aug 18, 2023 at 10:29 AM
    #336
    ScrippsRanch67
    Bob
    Fiberglass shell
    You know, I have been craving Twinkies recently.
  17. Aug 18, 2023 at 1:02 PM
    #337
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    @Red Baron new nickname... Twinky Brakes
    YamaDirtrider likes this.
  18. Aug 18, 2023 at 1:09 PM
    #338
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    I never did the techstream stuff. Just bled my brakes like normal and they work flawlessly after the upgrade except that i don't have ABS, but that's a pre-existing condition from a bad sensor harness and has nada to do with the upgrade.
  19. Aug 18, 2023 at 2:01 PM
    #339
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    If you don’t let the brake lines between the abs module and the brake calipers go empty you will not get air in the Abs module. Changing a master cylinder will also introduce air to not the abs system. ABS does not have to be working either. If there is air in the module you get spongy brakes regardless of it being operational.
  20. Aug 18, 2023 at 2:02 PM
    #340
    Pittsy
    Pittsy Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    I changed my MC and did a normal brake bleed, didnt do any ABS module actuation and my brakes are firm as a rock. No sponginess
    AllTacosFloat and Littles like this.
