My 2007 Xrunner turbo build
Discussion in 'Performance and Tuning' started by Smittyxr1984, Jul 16, 2019.
  1. Aug 7, 2019 at 4:25 PM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To be honest, I an not certain. Mine is looped around to the back port which used to be where the PCV attached, to the intake manifold.
  2. May 12, 2023 at 8:25 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What's the latest?
  3. May 12, 2023 at 9:30 AM
    #43
    Smittyxr1984
    Smittyxr1984 [OP] Well-Known Member
    2007 XR
    Ordering pistons from cp Carrillo as week speak and then block going out for darton sleeves
    Torspd likes this.
  4. May 12, 2023 at 9:34 AM
    #44
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Nice. What specs you going with?
  5. May 13, 2023 at 10:44 AM
    #45
    Smittyxr1984
    2007 XR
    97.5mm bore 10:1 compression
