My 2008 Tacoma's front end is tiered! Need some insite!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smcgill, Jan 13, 2016.
  1. Jan 13, 2016 at 5:05 AM
    smcgill
    smcgill [OP] Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    My 2008 Tacoma's front end is tired! ( Only 270,000 miles on it ):annoyed:
    I have a Curtis snow plow that is just installed when needed.
    The Taco is sagging when the plow is one and in the raised position.
    The frame is too close to the ground in this situation.
    If this was yours how would you fix this?:notsure:
    Stock front end.
    Thanks for your input!
    Sean
    Can't spell .. spell check can't either!
  2. Jan 13, 2016 at 5:09 AM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    New suspension. I'm sure the plow weighs a bit and it doesn't help if your still on the original factory suspension.
  3. Jan 13, 2016 at 3:35 PM
    smcgill
    Sean
    OK
    What type of coil over do you recommend?
  4. Jan 13, 2016 at 3:40 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Something with 700 lb springs? Some Bilsteins or OME's?
  5. Jan 13, 2016 at 3:58 PM
    smcgill
    Sean
    How hard are they to replace?
  6. Jan 13, 2016 at 4:01 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I would recommend Bilstein 5100 with OME X884 coils. That will give you a 1.75 inch front end lift over stock.
    They're decently easy to install. Took me about half a day going at a slow pace.
  7. Jan 13, 2016 at 4:16 PM
    smcgill
    Sean
    Best place/price to bye?
  8. Jan 13, 2016 at 6:01 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I'm guessing you mean tired, not tiered. If tiered, I don't know what the solution for that is...If tired, a phone call to any of the suspension vendors on TW will tell you all you need to know, especially in light of the plow setup. Give 'em a call, they are the experts...
    smcgill[OP] likes this.
  9. Jan 14, 2016 at 7:21 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    @HeadStrong Off-Road will be able to help you out.
    They can answer any questions that you may have, and can advise you on updating your suspension.
    I'm sure they'll chime in here and/or PM you.
