My 2009 DBLCB mystery squeal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aravenguide5674, Mar 25, 2023.
  1. Mar 25, 2023 at 4:12 PM
    aravenguide5674
    aravenguide5674 [OP] New Member
    Hope you folks can help. I've done the following;
    -Two top idlers
    - Belt
    -changed gears, put in neutral, turned on AC, switched to 4WD with no change. Charging normally.
    Only seems to change with idle to just off idle and does not do it all the time. Every 3-4 months it happens for a week and goes away. Finally record the following video
  2. Mar 26, 2023 at 7:46 AM
    aravenguide5674
  3. Mar 26, 2023 at 7:49 AM
    John43
    John43 Well-Known Member
    Dallas
    07 PreRunner
    Take the belt off and check all the rollers. Should have changed them all.
    aravenguide5674[OP] likes this.
  4. Mar 26, 2023 at 8:46 AM
    aravenguide5674
    Changed the top two in the snow and mud, will hit the bottom next then.
