my 2012 DC/OR at 2,000 miles...lug nut check!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alan in GA, Jan 28, 2012.
  1. Jan 28, 2012 at 7:06 AM
    Alan in GA
    Alan in GA [OP] Well-Known Member
    Alan
    Powder Springs, Georgia USA
    '12 Tacoma Off Road 4x4
    tool chest, company logo/decals
    Actually I did this back around 500 miles and don't think I mentioned it....check the LUG NUT TORQUE ON YOUR MAG WHEELS! About 2 nuts of each wheel were not tight. I just did a minor torque check with a 4 way lug wrench and found that the lug nuts were not all evenly tight. I have a torque wrench but did not even use it because I KNEW I was only checking for EXCESSIVE 'looseness' on my new truck's wheels. Now I wished I had used the torque wrench because some here might think I didn't know how tight the lug nuts should be....just heed my advice and CHECK your new trucks wheel lug nuts.
    YES, USE a TORQUE WRENCH for proper tightening if you have one but the lug nuts on several of my wheels were almost loose enough to finger spin! [ok, not that loose but not up to 'spec'].
    Anyone else notice this on a new Taco?
  2. Jan 29, 2012 at 8:13 AM
    Alan in GA
    Alan
    nobody?
  3. Jan 29, 2012 at 8:18 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Meh, let the wheel fall off, sue the shit out of Toyota. Then buy a new Tacoma!:p
  4. Jan 29, 2012 at 8:19 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Same should be with new wheels.
    Thanks for the heads up.
  5. Jan 29, 2012 at 8:28 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    When I removed my rear wheels a few weeks ago to put on my air bags they did seem a little loose.
  6. Jan 29, 2012 at 8:29 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Any time anyone other than me touches my lug nuts, I always loosen them and retorque to spec as soon as I get home.
  7. Jan 29, 2012 at 8:34 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    proper torque is 83 ft lbs if I remember correctly
  8. Jan 29, 2012 at 8:48 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Correct
  9. Jan 29, 2012 at 9:02 AM
    Alan in GA
    Alan
    the loose ones on mine must have been about 30 or 40 ft lbs....just guessing but I know they could have worked loosed from where they were!
  10. Jan 29, 2012 at 10:01 AM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    how do you check how tight a nut is on in foot pounds? I dont have any special equipment other than a ratchet set and the factory tire iron...
  11. Jan 29, 2012 at 10:11 AM
    ImpulseRed008
    Susan
    SC
    You need a torque wrench to check it
  12. Jan 29, 2012 at 10:36 AM
    TexasTacoma37
    You can get a torque wrench for $15 from harbor freight.
  13. Jan 29, 2012 at 10:39 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    good reminder for all of us
  14. Jan 29, 2012 at 12:51 PM
    Alan in GA
    Alan
    Set if for 10 lbs less than the spec it's supposed to be. If the nut turns before it clicks [click type torque wrench] then you know it was less than spec.
    Just take a 'regular' lug nut wrench and put mild torque on the nuts, it's easy to tell if any are TOO loose.
    Best advice is still to use someone's torque wrench.
