My 2013 Tacoma Access Cab Chinook build in progress
Discussion in '2nd Gen. Builds (2005-2015)' started by Jaybashant, Oct 1, 2017.
  1. Jan 10, 2018 at 2:31 PM
    #141
    Jaybashant
    Jaybashant [OP] Well-Known Member
    I am back on it! really happy to be home in the warm weather. Have been in NC freezing. Had the pleasure of shoveling snow for the 1st time in over 45 years... good times!
    Decided to weld in 2" spacers to my rear camper mounts. It just needed to be a bit higher and had been bothering me. Looked a tad saggy. I will also add 2" blocks under the leaf springs. Then after the interior is in with full fuel, water etc etc...
    I will evaluate the suspension.
    Thinking air bags will be a bonus but it may be fine as is. It is pretty light and I am keeping it that way. Being very careful to keep my overall finished heighth under 7'5" so it will fit in a standard 20' shipping container!
    Also have everything to plumb the water tank and extra fuel tank. Adding 15 gallons of gas with a transfer pump. Splitting the factory fill hose so I can pump fuel directly into the main tank from the auxiliary tank. I will install a ball valve so the factory system is closed so no sensors can be a problem... With the extra fuel I should have a range of over 600 miles depending on conditions...
    I have a pair of locking powder coated steel fuel doors that will mount on the driver's side in the front of the camper. All of the fuel including the fills will be bulkheaded from the interior with exterior venting and overflow.
  2. Jan 10, 2018 at 8:01 PM
    #142
    taco_chinook
    taco_chinook New Member
    Great build ! Followed your link from expedition portal. Will definitely be following along … Here's my Tacoma and a friends old diesel Chinook … instagram.com/taco_chinook instagram.com/lifeinmytruckIMG_5961.jpg
  3. Jan 10, 2018 at 8:51 PM
    #143
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    I lack the motivation and skills to do this sort of work, but there's a Chinook about a block from my house, in Ohio, for $800 OBO if anyone is looking for a donor.
    ChadsPride and Jaybashant[OP] like this.
  4. Jan 11, 2018 at 7:22 AM
    #144
    Toyko Joe
    Toyko Joe Here for the pictures
    :drool::drool::drool::headbang:
    Jaybashant[OP] and ChadsPride like this.
  5. Jan 11, 2018 at 7:32 AM
    #145
    Taco Hell
    Taco Hell Well-Known Member
    Lititz, Pa
    2007 TRD Sport DC Prerunner
    One word...BALLS!!!
    ChadsPride likes this.
  6. Jan 11, 2018 at 6:06 PM
    #146
    Jaybashant
    Got some stuff worked out today... this improv design is not without challanges! Got the center spacers installed on the factory mounting points. By adding the additional 2 inches in the back it sits much nicer but it meant raising the center and having to extend the mounting bolts.... Patrick has been helping a few hours here and there which is great! Welding extensions on the bolts and fabrication an aluminum bracket for the back up camera were a huge help today, thanks!
    Worked out some details on the outside chuck wagon kitchen... this is important because I am space planning the interior and the kitched stows below the bed. I will be framing that out soon...
    Also my factory tacoma taillight installation into the chinook has turned about to be a bitch. (Should have taken Tokyo Joe's advise)..... But I got it figured out... I should have cut the fiberglass a bit smaller than the lights and left them recessed. Instead the shell was cut for flush mounting making the finishing really tough and time consuming. I made patterns of the shape and having a guy CNC me some 3/4" wide black Seadek trim pieces to frame out the lights... it solves so many problems for me... Seadek is a closed cell marine foam used for high end decks a trim on boats... UV stable and peel and stick with a badass 3M adhesive.. I will also us a thicker version to trim out where the fiberglass shell meets the diamond plate boxes and wheel wells. Clean trim out, and bonus protection af protecting from door dings in parking lots... I uploaded a pic of the Seadek installation on my boat. The decks in Seadek faux teak and gunnel covering boards and knee coaming jn a bone color..
    ... and my boat building friend Erik donated the paint...Algrip allcraft... in my new favorite color Off White Revisited! A great day!
  7. Jan 11, 2018 at 6:25 PM
    #147
    Dan H
    Dan H Wife thinks I'm having an affair with my Tacoma
    Daniel
    Glendale AZ
    2006 indigo ink PreRunner DCSB- 2012 Venza AWD
    ProComp Pro Runner shocks n struts Painted engine cover Fog anytime mod Cherrybomb muffler Bestop 3/16 tailgate plate and top cap Where do I begin with all the camo
    I'm glad to see your back to work on it. I kept checking in for updates every few days.
  8. Jan 11, 2018 at 6:33 PM
    #148
    Jaybashant
    Thanks Dan, way more fun than what I have been doing for the past few weeks!
    Dan H[QUOTED] and ChadsPride like this.
  9. Jan 11, 2018 at 6:44 PM
    #149
    Dan H
    Daniel
    Glendale AZ
    Getting cold playing in the snow can be fun.
  10. Jan 12, 2018 at 1:42 PM
    #150
    Jaybashant
    Well I drove her around today fit the first time legally. Temp masking taped the tail lights and installed the back up camera. It drives nice! Feels no different than driving it before the camper went on it....Estimating she is 500-600 lbs heavier than the factory pickup.... no top heavy feeling at all. I am happy!
    Had a bundle of thick wall 3/4x3/4" thick wall aluminum square tube stock delivered...Using it to frame out the bed frame and interior componants. I will weld instead of tech screw the aluminum framing to minimize the chance of rattling and squeeking.
    I worked out a trifold sofa to bed conversion that should be simple to build as well as easy open close... bought a matress that was designed for a pull out couch. 2" firm foam laminated to 1" memory foam. Seems like it will be pretty comfortable. ..
  11. Jan 12, 2018 at 4:25 PM
    #151
    ChadsPride
    Sponsored by TacomaWorld.com
  12. Jan 13, 2018 at 4:18 AM
    #152
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    I'm really enjoying watching this come together!:thumbsup:
  13. Jan 13, 2018 at 10:12 AM
    #153
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Nice to see you back at it. Any reason you chose to run blocks in the rear and aren't going to upgrade that suspension? Or did I miss it?
  14. Jan 13, 2018 at 12:44 PM
    #154
    Jaybashant
    I am opting to stand by on the suspension decisions until it is done Rogue.... full tanks and gear on board... Maybe some air bags will be in order. So far all is stock accept we installed some 1500lb Superspring helper springs when the rear end was getting swapped out. I have the blocks but will probably not use them as I am close on my overhead heights to be able to load the truck into a 20' shipping container...
  15. Jan 15, 2018 at 2:49 PM
    #155
    btenlow
    btenlow New Member
    Brad
    Toyota Chinook
    Not yet
    What a great build, I am looking at putting one on a t100 extra cab, What did you do to fill the gap between the vertical forward slanted back of the cab of the toyota and the fiberglass, it creates like pie shape that needs to be filled.
    Thanks
  16. Jan 15, 2018 at 3:57 PM
    #156
    Jaybashant
    Thanks Brad...I really did not have anything to fill except the very back of the roof where it does a 90° down the back of the cab. It is a tiny pie shape of about 3"x3".... After I cut out the roof and back of the cab, the cab and Fiberglass sort of found a happy medium I guess. Then I sandwiched the fiberglass between the Tacoma cab and my fabricated 1"x3" frame structure with a thick rubber seal and 3M 5200 caulk, carriage bolted. It I'd really stiff but can twist a bit if the situation calls for it. The steel frame gives some structure back to the cab but the cab remained remarkable ridgid after the roof and back were cut. I do not know if your results wojld be the same with the T100...
    Watt maker and ChadsPride like this.
  17. Jan 16, 2018 at 8:00 AM
    #157
    btenlow
    btenlow New Member
    Brad
    Toyota Chinook
    Not yet
    Any chance you snapped a photo of that think rubber seal you used. or link to where you got it?
  18. Jan 16, 2018 at 12:10 PM
    #158
    Jaybashant
    I got it at either West Marine or maybe Lewis Marine... it is about 3/8” x about 7/8”. Butyl rubber, not foam. I laid down 2 parallel seals with a couple inches between them. Than a FAT bead of 3M 5200... the 5200 is really the seal, and more importantly the bond... super strong adhesive...
  19. Jan 16, 2018 at 12:13 PM
    #159
    Jaybashant
    Extra gas tank mount is ready for install after paint... the frame will get welded to my subfloor steel frame.
  20. Jan 16, 2018 at 12:15 PM
    #160
    Toyko Joe
    WestMarine and McMastercarr are an inventors best friend!
