My 2013 Tacoma smells like feet when the A/C is on...help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 100, Mar 3, 2013.
  1. Mar 3, 2013 at 10:38 PM
    100 [OP] I have 4 Dogs
    Texas
    2013 DCSB(Prerunner) TX Edition
    2013 Tacoma
    Mileage: 1,870
    Purchased: December 21st, 2012
    Parked: I park this on my driveway overnight
    Every time I turn on my A/C, it begins to smells like feet. It goes away after a minute or sometimes it lasts longer. I just began noticing this a week ago. It is getting frustrating, my 2008 Mazda 3 never had this issue, it was parked in the same driveway . What can be the problem? Any advice or tips for getting rid of the smell?
  2. Mar 3, 2013 at 10:45 PM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    19 Tacoma TRD Sport Premium
    3" lift. $10K in TRD options. Richie's semi-hidden bumper, and soon his Elka suspension
    Ask the dealer to check the A/C drain hose to make sure it's not twisted. If it is, water can go stagnant in the unit and make it smell like.........(place description here)
  3. Mar 3, 2013 at 10:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This is usually caused by mold inside the evaporator coil in the car due to dampness. The cheapest way to avoid this is when you go to turn off the truck for the night is to turn the heat on full for a minute or two before shutting it off. This will kill the mold.
    Also make sure the drain is not plugged.
  4. Mar 3, 2013 at 10:46 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Wow we posted at the same time! 10:45PM
  5. Mar 3, 2013 at 10:47 PM
    Texas
    Where is the drain hose located? Sorry, I am not that mechanically inclined.
  6. Mar 3, 2013 at 10:47 PM
    Sloweburn
    Woodstock, ON
  7. Mar 3, 2013 at 10:48 PM
    Texas
    Is having to blow heat before shutting off a Tacoma normality? I have never had to do that with my previous cars.
  8. Mar 3, 2013 at 10:49 PM
    Sloweburn
    Woodstock, ON
    It will be on the firewall at the passenger side. If you look under the truck, it will be sticking out about 4 inches with a slight bend down.
    You could pull the pass side carpet back to see it.
  9. Mar 3, 2013 at 10:51 PM
    Sloweburn
    Woodstock, ON
    I've never done that. Mine doesn't smell. But then again, It's currently -40 where I live...
    Actually, it's probably more like 15 - 20... just feels like -40
  10. Mar 4, 2013 at 1:24 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I haven't had to do it either and mine doesn't stink. That being said, I know that my drain hose is clogged and the heat exchanger box isn't full of rotten condensate...
    It is a common issue with all make and model vehicles with AC.
    Running the heat wide open is a common way to kill the mold ( if there is mold ).
    The Toyota dealer also has a a cleaner that they will back fill the heat exchanger box with that is supposed to clean and kill the mold.
    Ditto on the location of the drain hose.
  11. Mar 4, 2013 at 1:27 AM
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    wow! i didnt know there was an actual explanation for the smell other than someone who got in my truck had stinky feet....
  12. Mar 4, 2013 at 4:20 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You learn something new every day.
  13. Mar 4, 2013 at 4:43 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    how does the cabin filter look?
  14. Mar 4, 2013 at 5:06 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Take it to the dealer and have them fix it. You paid for the Warranty, use it. Plus It's a cya thing, it might be something more serious now or develope into something more serious. feedback is a good thing, might be an ongoing problem that Toyota can address to improve quality.
  15. Mar 4, 2013 at 5:33 AM
    Texas
    I will def be contacting the Toyota dealership. Has there been other reports of this? I shall try the heating solution aswell, to see if that helps.
  16. Mar 4, 2013 at 5:35 AM
    KeavyD
    KeavyD Well-Known Member
    KeavyD
    SATX
    15 DCSB 4x4 TRD Sport
    Pro Comp Nitro 3" Lift TRD Skid Plate Predator Step Bars TRD Exhaust TRD Antenna BFG T/A KO2 275/70/17 XD Monster 2 Wheels TRD Shift Knob Tacoma Door Seals Toyota Devil Horns TRD Grill Badge TRD 3rd Brake Light Cover Red Toyota Devil Horns
    I'm having the same problem with my 13 Tacoma it only has 3200 miles purchased it in Sept. 2012 and with my wife's 4RUNNER Limited. I don't know if its because of this crazy Texas weather heater one day and a/c the next. But
    I'm taking both of them in to the dealership to be checked out.
  17. Mar 4, 2013 at 9:19 AM
    100
    Texas
    I called and I will be dropping off the truck tomorrow at the dealership. They will be dropping me off at work, instead of giving a rental car. Hmmm...
  18. Mar 4, 2013 at 9:27 AM
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    Yeah, feet and toxic mold is the aroma I'm frequently greeted by. Sucks too because my humidity here is about as low as it can go - I can't imagine how bad it must be in swampy states. Must be some serious moisture trapped or the area must be pretty air tight / void of air flow when off and sitting for my 15% relative humidity to not just zap it up.
  19. Mar 4, 2013 at 9:42 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the drain hose is behind the upperleft pass side footwell carpet.
    sometimes it can get crushed
    I solved this problem on my yaris, and it was a very odd problem
    a) going around corners, pass carpet got wet. clear sign water is building up
    b) checked everything, no clogs...but water would only drain if I squeezed the hose
    manually. there were no clogs anywhere
    c) it would not drain on it's own...a few drops would come out then
    refuse to drain. WTF ??? some type of bubble/surface tension problem ?
    FIX (this surprised me but hey it worked)
    a) i got a smaller stiffer clear plastic tube off a reel at auto-partz-hauz
    b) pulled off the black rubber hose in the footwell from the condenser drain,
    and fed my insert tube down inside it, like a liner, into the engine bay until it stuck out
    past the end of the black tube by 1 inch.
    c) effectively i have lessened the inside diameter of the large black rubber
    hose to the same size as the nipple coming off the condenser tank
    d) inside the footwell, I cut the tube off flush with the black hose, and then connected the
    black hose back where it goes. now I have basically the original tube but
    a smaller inside diameter tube inside it...and that just touches the condensor drain
    nipple it doesn't attach to it...the black original tube is what goes over the nipple
    and the inner tube is just held right up against it
    e) now for some reason it drains fine all the time. very odd since there
    was no clog. the black tube with the insert tube is now un-crushable where
    the original black tube was easy to crush (if you stick your feet up there
    for example) maybe that is what was doing it...carpet pressure
    all I know is it works great now...and if my Taco ever had a drain problem
    I'd do the same thing...stick a hunk of my homemade catheter in there and be done
  20. Mar 5, 2013 at 6:08 PM
    Willcory
    Willcory Well-Known Member
    San Antonio TX
    2013 Black Tacoma 4x4
    happen to me with my 13' one time i only have 400 miles on it..
