My 2016 TRD just shut off while I was driving down the interstate. Any advice?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DDegan, Sep 28, 2017.
  1. Sep 28, 2017 at 6:27 PM
    DDegan
    DDegan [OP] Member
    Wayne
    2016 Tacoma TRD Sport
    I was driving home from work this afternoon when my truck suddenly shut off. I was going about 60 mph on the interstate when a warning light came on stating "A/T Transmission fluid Temp High" and then it just shut off. There was some brief clanging, and I was luckily able to coast over to the shoulder of the interstate.
    I waited several minutes and tried to restart and it sounded bad. Clanging sound and the same warning light. I called Toyota care and they came and picked it up and brought it to the dealership.
    I know there is a recall on my truck regarding the Crankshaft Position Sensor. I brought it to the dealership when the recall was first issued (July) and I was told that they had no fix at the time and there was nothing they could do. I set up an appointment for next week (10/4/17) for an oil change and to see what they can do about the recall. Looks like my truck will be seen earlier than that.
    I only have 17,000 miles on the truck and am pretty bummed out, but thankful to be alive. Be careful out there to anyone who has the same recall issued.
    Any advice anyone can provide would be appreciated.
  2. Sep 28, 2017 at 6:29 PM
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    cps?
    H3ATH3N2016 and Friggin Fuego like this.
  3. Sep 28, 2017 at 6:33 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Did you ever have the dealer verify the tranny fluid level? Do you have the tow package?
    dYL0n likes this.
  4. Sep 28, 2017 at 6:35 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    tacoflavoredkisses1 likes this.
  5. Sep 28, 2017 at 6:39 PM
    DDegan
    DDegan [OP] Member
    Wayne
    I did. The dealer verified the tranny fluid level on that particular visit. I saved the documentation. Yes, it is the tow package as well.
  6. Sep 28, 2017 at 6:39 PM
    Fitzpatrick78
    Fitzpatrick78 Well-Known Member
    Robert
    2016 trd sport 4x4 3" lift
    3" front 2" rear leveling kit 285/70/17 on fuel assault
    When was a transmission recall issued?
    eurowner likes this.
  7. Sep 28, 2017 at 6:44 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Ya, don't remember a transmission recall, that would have blown up TW.
  8. Sep 28, 2017 at 6:45 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    That is a serious episode. You should only be talking to your dealer and Toyota proper. That's the only advice that's important or reasonable. This forum has no affiliation with Toyota or any dealer so anything we say means absolutely nothing.
    So my advice: Talk to your dealer. If necessary, talk to Toyota. Nobody here has any clue what the problem is.
    Good luck and please report back with the cause and the solution.
  9. Sep 28, 2017 at 6:47 PM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    I'm thinking CPS . That A/T warning is known to go off when a CPS fails. Where are you located OP? Temperature is known to play a role in that particular failure.
  10. Sep 28, 2017 at 6:50 PM
    DDegan
    DDegan [OP] Member
    Wayne
    Whoops, I am mistaken. Not a recall relating to the transmission. It is a Crankshaft Position Sensor recall.
    over60 and Spare Parts[QUOTED] like this.
  11. Sep 28, 2017 at 6:50 PM
    Bigbadbucki
    Bigbadbucki Spicy Taco
    2016 TRD OR DCLB, 1990 22RE, 1995 1/2 Tacoma, 67 400 4sp Firebird
    None needed.
    Put gas in the tank. ;)
    DDegan[OP] likes this.
  12. Sep 28, 2017 at 6:50 PM
    DDegan
    DDegan [OP] Member
    Wayne
    my mistake, it is the CPS recall.
  13. Sep 28, 2017 at 6:51 PM
    DDegan
    DDegan [OP] Member
    Wayne
    Thank you. Understood. I will certainly report back.
    hiPSI[QUOTED] likes this.
  14. Sep 28, 2017 at 6:52 PM
    DDegan
    DDegan [OP] Member
    Wayne
    Currently located in Birmingham, AL. It was pretty warm out today.
  15. Sep 28, 2017 at 6:53 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Good old CPS...... gotta love it
    over60 likes this.
  16. Sep 28, 2017 at 6:55 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    CPS usually sets off Check Engine light. High Temp sounds like something else. Going to guess this is a one off, but let the dealer diagnose and then come back and let us know.
  17. Sep 28, 2017 at 6:58 PM
    GPC
    GPC Well-Known Member
    LFOD
    2015 Tacoma TRD Pro
    Glad you are ok.
    It's under warranty make sure it is fixed to your satisfaction. Demand a Landcruiser for a loaner.:)
  18. Sep 30, 2017 at 9:30 AM
    DDegan
    DDegan [OP] Member
    Wayne
    *Update - It was my crank position sensor.
    over60, eurowner, hiPSI and 5 others like this.
  19. Sep 30, 2017 at 9:34 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Thanks for the update. Mine is a 2016 10/15 build and on the recall list. I have been waiting to bring it in for the 25K final free service. Hoping I don't regret this plan- I have 21K now.
    PvilleJohn likes this.
  20. Sep 30, 2017 at 9:51 AM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Might as well take it in just for the CPS
    Don't want to be sweating those 4k miles
    boynoyce[QUOTED] likes this.
