My 2018 toyota tacoma
Discussion in 'New Members' started by KATAK38, Mar 9, 2023.
  1. Mar 9, 2023 at 3:29 PM
    KATAK38
    KATAK38 [OP] New Member
    VALERIE
    2018 Toyota tacoma
    My 2018 Toyota tacoma is very hard to steer and there is a brownish/blackish leak what part do I need to order and do I use a transmission fluid at the moment until it is repaired?
    Please help, thanks
    buckhuntin-tacoma likes this.
  2. Mar 10, 2023 at 6:14 AM
    taco_naranja
    taco_naranja Well-Known Member
    New York
    2017 Inferno Tacoma TRD OR
    Prinsu, bronze Method 305, Bakflip MX4
    Sounds like you have a leaking steering rack. Check the small reservoir between the windshield fluid tank and the coolant overflow tank in the front left quadrant of the engine bay (check the levels of those other two tanks while you’re there). If it’s low or nothing in there add some automatic transmission fluid (Dexron II or Dexron III) to the cold fill max line. Then take it to a shop to have your steering rack inspected.
    KATAK38[OP] and Stevie17 like this.
  3. Mar 10, 2023 at 9:35 AM
    KATAK38
    VALERIE
    2018 Toyota tacoma
    I put in ATF yesterday and the steering is better now, the coolant seems low do I need to fill it up?
    I live in a place where there is no shops so I have to do things myself, but there will be a mechanic coming next week I will get him to check it out, thanks
    wilcam47 likes this.
  4. Mar 10, 2023 at 10:58 AM
    taco_naranja
    New York
    I generally like to keep my coolant level at about 3/4 to the max line after it comes up to temperature.
  5. Mar 10, 2023 at 1:18 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
