My 2021 Tacoma accelerated on its own?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jdp1219, Apr 29, 2022.
  1. Apr 30, 2022 at 3:59 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    This happened to me at low speed from a stop. I also think it was an instance where the transmission got confused and downshifted from 2nd to 1st and the truck lunged forward and wanted to go. Lasted about two seconds but scared the shit out of me. Hasn’t happened again.
    Jerry311SD likes this.
  2. Apr 30, 2022 at 4:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Serious question, are the floor mats OEM
    and have you looked to see if it is locked in place?
    kfallsfunk, zoo truck and Chew like this.
  3. Apr 30, 2022 at 4:44 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Happened to me too, suggestion. Go to dealer and get ECU updated.
  4. Apr 30, 2022 at 6:56 PM
    smb41
    smb41 Well-Known Member
    Trd Off Road stickshift
    Yet another reason why I dont drive auto. MT all the way and I don' t have to worry about transmission shifting on its own. So glad I bought my TOR with MTo_O
    soundman98 likes this.
  5. Apr 30, 2022 at 7:10 PM
    mikeaesq
    mikeaesq Well-Known Member
    TRD Off-road 4x4
    This happens to me a couple times a week. Same thing. Accelerates for 3-4 seconds after I come off the gas.
  6. Apr 30, 2022 at 7:13 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Couple times a WEEK!?
    JJ Diablo and Benny blanco like this.
  7. Apr 30, 2022 at 7:18 PM
    smb41
    This is scary. It needs to be looked at asap. Something is clearly not right.
  8. Apr 30, 2022 at 7:29 PM
    mikeaesq
    TRD Off-road 4x4
    Probably the right call. It happens same spot coming home from work.
  9. Apr 30, 2022 at 8:40 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Damn. You should video it.
  10. Apr 30, 2022 at 9:28 PM
    mikeaesq
    TRD Off-road 4x4
    Can do that Monday on my way home from work. Will report back
  11. May 1, 2022 at 6:06 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Make sure the engine is fully warmed up before taking off. Sometimes you'll drive a short distance before coming to a stop...the engine will pick up rpm as its not up the running temps.
  12. May 1, 2022 at 8:21 AM
    mikeaesq
    TRD Off-road 4x4
    This actually happens after I’ve been driving for about 45 minutes. So issues when cold.
  13. May 1, 2022 at 8:50 AM
    zoo truck
    None
    Is it happening only when you run the ac, or all the time?
  14. May 1, 2022 at 8:58 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The transition when the VVT kicks in can be pretty abrupt, and the truck accelerates noticeably quicker. It's possible that it was transitioning right when you lifted and it took a second to transition back.
  15. May 1, 2022 at 8:59 AM
    #35
    mikeaesq
    TRD Off-road 4x4
    Haven’t paid attention to that. I’ll try both ways. From what I can remember the AC is on. It’s always when I come to the summit of a hill and begin descending. I’ll take my foot off the gas to coast down the hill and it’ll keep accelerating for a few seconds until I hit the brake or give the gas a quick pump.
  16. May 1, 2022 at 10:43 AM
    #36
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Throttle by wire..not surprising
    33yrsoftoys likes this.
  17. May 2, 2022 at 10:06 PM
    #37
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    I've also had what feels like a delayed response when letting off the accelerator at times. I've also noticed I can quickly tap my accelerator pedal down more than inch and the engine will not rev. Just ignores me. I only really notice this when I have to park with extra precision for some reason. Makes me think there is something wrong with the accelerator or throttle body, But the symptoms I'm describing would almost certainly throw code(s) if that where the case.
    PanzerDivisionBlack likes this.
  18. May 3, 2022 at 6:19 AM
    #38
    zoo truck
    None
    I'll notice on my 2020 tacoma when on a flat grade, or going downhill using the ac there is a slight jump in engine rpm at times, and then it clicks off as your driving. Its normal as my tundra did the same when using the ac.
  19. May 9, 2022 at 7:30 AM
    #39
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    sooo, the thread is back? what happened?
  20. May 9, 2022 at 2:32 PM
    #40
    Off Topic Guy
    @JimBeam For clarification, this thread, plus the 3 others. I don't think there's any debate why the recent threads were locked; mod bashing doesn't really do anything. I think the cry is bc the 1st thread listed below disappeared, and speculation is that this current thread had a lot of posts "cleaned up" although I can't confirm. Any insight on the first threads disappearance? I think that's the reason for the outcry.
    This current thread: https://www.tacomaworld.com/threads/my-2021-tacoma-accelerated-on-its-own.764325/
    https://www.tacomaworld.com/threads/tacoma-accelerating-on-its-own.611912/
    https://www.tacomaworld.com/threads...ing-threads-about-acceleration-issues.765269/
    https://www.tacomaworld.com/threads/truck-accelerates-on-it’s-own.765211/
