My 2gen Tacoma, driver side "NEEDLE BEARING" is vibrating.
Discussion in 'New Members' started by LYT90, May 21, 2019.
  1. May 21, 2019 at 7:34 AM
    LYT90
    LYT90 [OP] New Member
    Leng
    Desert tan mica
    Pumped gas
    My 2gen Tacoma, driver side "NEEDLE BEARING" is vibrating. It just starting vibrating one day ago and I was wondering how long would it last me before fully breaking down? Would the ECGS T8 clamshell be worth switching over to? Or should I just stick to OEM?
  2. May 21, 2019 at 7:36 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    are you sure its not a wheel bearing?
  3. May 21, 2019 at 7:40 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    If it's just the typical needle bearing vibe, it's just a nuisance issue. It's not going to grenade on you.
  4. May 21, 2019 at 10:22 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  5. May 21, 2019 at 10:24 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Lots of threads on this, I mean LOTS. Try searching next time
    Taco critter likes this.
  6. May 21, 2019 at 11:31 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    irayfz6 and Taco critter like this.
  7. May 21, 2019 at 12:14 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
  8. May 21, 2019 at 12:23 PM
    KILLINTIME
    KILLINTIME Like a Villain
    Lift front of truck with a jack and wiggle your tire, if it’s loose it will be the wheel bearings which is easy to replace, just replaced mine. Needle bearing replaced with an ecgs bushing isn’t that bad either, just a little more steps. You can get the needle bearing puller tool on here for free and then send it to the next guy that needs it, that’s what i did. There are some Great step by step videos on how to replace both.
    Taco critter and irayfz6 like this.
  9. May 21, 2019 at 1:36 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  10. May 21, 2019 at 4:42 PM
    KILLINTIME
    Yep this forum will solve and cause all your life’s problems with your taco.
  11. May 23, 2019 at 10:44 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
