My 2nd Gen Aux Reverse Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by erod998, Jul 24, 2015.
  1. Jul 24, 2015 at 3:29 PM
    erod998
    erod998 [OP] Well-Known Member
    Ethan
    2012 Silver Tacoma Off-Road
    Hey Everyone. Thought I'd do a simple and quick post to show how I did my auxiliary reverse lights.
    The lights I used are here:
    http://www.amazon.com/gp/product/B00NPQV06O?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
    I bought 2 of them. Cheap enough so if you bust them on a rock off roading it won't hurt the bank. There are 2 sizes. I got the largest and I also got the flood beam.
    Next, I went to Home Depot and picked up 2 of these:
    http://www.homedepot.com/p/Sioux-Ch...RV-_-rv_gm_pip_rr-_-205227224-_-202274013-_-N
    I chose these because they are insanely cheap and pretty strong, yet still malleable. I did cut them down a bit, and drill holes in them. I sanded them down, and removed the sharp edges with a bench grinder. Wiped clean with acetone then coated in plasti-dip. I chose plasti-dip instead of spray paint because I feel like it sticks easier, and when I needed to mount the lights, it was easy to remove the plasti-dip. You'll see what I mean by that later on.
    The lights are mounted to the plate.
    I had to go to Ace Hardware and get better hardware than the stuff that came with the light.
    I mounted them to by tow package bar. I did not feel comfortable drilling into it, nor do I think my drill has enough power to do so. Instead I sanded the paint off the beam, wiped clean with acetone, and JB-Welded the plate to the beam. Here you can see where I just used a razor blade to remove the plasti-dip, and sanded the plate to make sure the JB-Weld can "grip" it.
    Then, clamped the plate down and let it cure overnight.
    While they were curing, I made the electrical connections. For now, I have them tapped into my reverse lights. Soon, I will add a separate relay for them so they can come on whenever I want from a switch in the cab. The switch I plan on using is this:
    http://www.ebay.com/itm/261948345284
    But for now, it is just tapped into the reverse lights. I tapped into the lights in the split loom wire next to the driver side light.
    The green and black wire run down to the first light, then through the tow beam and out the other side to the other light.
    The light next to the RV connector on my tow package barely was far enough away to allow these lights. If the lights were not angled at the ends, I'd be forced to get the smaller length light but it fit perfectly.
    (before I attached them)
    I'll post some light output pics later on tonight.
    Over all, I am pleased with the way this came out.
    Night time pictures on post #19.
  2. Jul 24, 2015 at 3:33 PM
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    Me likey
  3. Jul 24, 2015 at 3:48 PM
    muddog67
    muddog67 Well-Known Member
    Did you have to install a resister in the positive wire ?
  4. Jul 24, 2015 at 3:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Any pics of the whole back end? I'm curious to see how hidden these are. Good work OP!
  5. Jul 24, 2015 at 3:51 PM
    erod998
    Ethan
    I did not, should I?
    And yes, I will get some pics tonight when I can take the clamp off.
  6. Jul 24, 2015 at 3:53 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Only when you install a relay to turn them on independently. That way if you switch them on, power doesn't go to your reverse lights as well and light those up.
    At least I'm pretty sure that's why you'd need a resistor...
    EDIT: Nevermind. I'm thinking of a diode.
  7. Jul 24, 2015 at 3:58 PM
    erod998
    Ethan
    Ah yes. Also you would use a diode somewhere else so if you turn the aux lights on they do not trick the tranny into thinking it's in reverse and lighting up the R in your dash.
  8. Jul 24, 2015 at 4:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't see the need for a resistor like the other guy mentioned, but once you put the relay in I'd throw a diode in there. Never personally used them before (never needed too) so I'm of no help there.
  9. Jul 24, 2015 at 4:01 PM
    muddog67
    Resistor prevents overload on that circuit so you dont blow fuses . But if you can light it up without blowing a fuse which i see you have done you should be good to go . Only reason I ask is cuz I have a single light like yours laying around im not using so You just might have given me an idea . Thanks Ethan
  10. Jul 24, 2015 at 4:01 PM
    erod998
    Ethan
    muddog67 likes this.
  11. Jul 24, 2015 at 4:31 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh man I like how low profile those are. I may just have to do this. I'm curious to see how well the JB Weld holds up over time and how bright they are at night.
  12. Jul 24, 2015 at 5:08 PM
    erod998
    Ethan
    I think with proper sanding and prep, the JB-Weld should be pretty dang strong. And with how much I used. If not, looks like I will be drilling into the tow bar.
  13. Jul 24, 2015 at 5:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm too lazy to walk outside and look at my own truck so I'll just ask here. Couldn't you just drill a couple more holes in the sheet and get some heavy duty zip ties and zip tie them to the hitch? Or maybe a large hose clamp?
    EDIT: As long as they're not visible of course. Can't remember off the top of my head if that portion of the hitch is visible.
  14. Jul 24, 2015 at 5:12 PM
    erod998
    Ethan
    I did think about that, and I might do it on top of the JB Weld. Especially if you used black zip ties, it shouldn't be visible. I can only see my lights if I crouch.
  15. Jul 24, 2015 at 5:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That'll definitely be the route I go then when I decide to do it. A little cheaper than JB weld and less work because there's no time waiting for it to set up.
  16. Jul 24, 2015 at 5:14 PM
    erod998
    Ethan
    Let me know when you do it, can't wait to see it.
  17. Jul 24, 2015 at 5:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'll definitely post it up. Probably won't be for at least a few weeks unfortunately. While I'm back there I might as well throw in one of those big rig reverse alarms for those crowded parking lots :cool:
  18. Jul 24, 2015 at 5:59 PM
    Bman4X5
    Bruce
    Upland CA
    '15 AC/OR
    They look pretty safe up in there
  19. Jul 24, 2015 at 7:22 PM
    erod998
    Ethan
    Alright everyone, here are some night shots. Crazy bright.
    Dj Suisav likes this.
  20. Jul 24, 2015 at 8:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hot damn those are bright!!!
