My 2nd Gen Aux Reverse Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by erod998, Jul 24, 2015.
  1. Jul 24, 2015 at 8:20 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Can you confirm the measurements for the lights?
  2. Jul 24, 2015 at 8:24 PM
    erod998
    erod998 [OP] Well-Known Member
    Ethan
    2012 Silver Tacoma Off-Road
    The glass of the lights is 6x1, the metal is 7.5x1.7. I can make sure those are right in the AM. Those are rough.
  3. Aug 1, 2015 at 5:46 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Dang, Good job...
    I saw those exact lights on Amazon this morning.
  4. Aug 1, 2015 at 5:53 AM
    Weis1
    Weis1 Go Ducks!
    Phoenix AZ
    2019 DCLB TRD Sport Cav Blue
    Subd
  5. Aug 1, 2015 at 10:04 PM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    Just out of curiosity, why'd you choose these lights/mounting method as opposed to using lights with a "traditional" light mount and mounting to the pre-existing holes in the bumper? Not knocking your install OP, just legitimately curious.
  6. Aug 2, 2015 at 7:33 AM
    erod998
    Ethan
    I have not seen any lights mounted in the "pre existing holes." I've seen flush mount lights in the bumper, but I don't like those and I'd have to get a new bumper first. What do you mean by "traditional" light mounts?
  7. Aug 2, 2015 at 8:15 AM
    MDB Taco
    GA
    ‘05 TRDOR DC
    The style of mount I was referring to was the type found on halogens and other small LED's (similar to what's pictured below). Wasn't sure what that style is actually called, I just know it's what I normally see on off road lights of all kinds.
    I noticed your truck is a 12, so maybe Toyota quit putting the holes in the bumper? Mine were mounted with them.
  8. Aug 2, 2015 at 8:16 AM
    erod998
    Ethan
    Those probably could work. To be honest I didn't know those existed lol. But hey I've already done it so no going back
  9. Aug 2, 2015 at 8:19 AM
    MDB Taco
    GA
    ‘05 TRDOR DC
    Haha, gotcha. I mean hey, yours seem to work just as well anyway. :thumbsup:
  10. Sep 5, 2015 at 3:37 PM
    HBGIBBY
    HBGIBBY Well-Known Member
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    Is the housing plastic or aluminum on those lights?
  11. Sep 5, 2015 at 3:48 PM
    erod998
    Ethan
    The housing is aluminum, or another type of metal. Lense is glass or incredibly strong plastic that feels just like glass.
  12. Sep 5, 2015 at 3:50 PM
    HBGIBBY
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    Thanks!
  13. Sep 5, 2015 at 4:03 PM
    erod998
    Ethan
    Hey everybody, forgot to update this showing the new switches and the aux fuse box.
    The switches are also wired into my remote start parking light output. The reason I did this is for when ever I unlock or lock the truck, or remote start the lights will come on. Also hooked up into my light bar up front. This was done using diodes. The reverse light was also diode isolated into the reverse line in the kick panel. The reverse lights have 3 triggers, light bar up front has 2. The auxiliary fuse box will support 4 more lights for the future. It's ran off 4 gauge wire.
    The lights turn on with the dash lights thanks to a fuse tap in the lower dash fuse box. The lights can not turn on unless they are on, except they can still be activated via the remote start or reverse. The switches also illuminate the top light whenever the switch is depressed meaning the circuit is on. The picture doesn't show it but I mounted the relays to the aux fuse box and mounted my remote start siren next to it on the factory fuse box. Also covered the wires coming from my fire wall in split loom.
    HBGIBBY likes this.
  14. Sep 5, 2015 at 4:09 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    welcome to the club. I did mine 2yrs ago. Just drilled into hitch receiver instead of jb. I think my lights are similar. I have a shell so these are must have.
  15. Sep 5, 2015 at 4:10 PM
    #35
    erod998
    Ethan
    Lights look similar and very clean. Was it difficult drilling into the beam?
  16. Sep 5, 2015 at 4:12 PM
    #36
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Nope. Just make sure you have a wrench long enough to fish through the end of the receiver.
  17. Sep 6, 2015 at 5:45 AM
    #37
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hey OP, how's the JB holding up so far?
  18. Sep 6, 2015 at 6:07 AM
    #38
    erod998
    Ethan
    Absolutely perfect. Still as strong as when it was first put on. I can try and pry it as hard as I can but it just starts bending the metal mounting plate. I highly doubt the jb weld will ever come off. Granted, the 2 spots being cold welded together need proper sanding and prep work to make it stick well.
  19. Sep 12, 2015 at 12:29 PM
    #39
    SnowDrift
    SnowDrift Questionably qualified member
    Alex
    Indianapolis
    2014 White TRD sport 4X4
    K&N Short Ram intake TRD short throw shifter Flowmaster cat-back exhaust ProComp 3" suspension lift ProComp 17" wheels ProComp MT2 tires 20% window tint (front) UWS tool box - black Plastidip front emblem 2" front receiver 8500 Superwinch Wet Okole seat covers
    Next upgrade I'm doing to my taco is lighting. I got deep in the backwoods and learned the hard way through 3' tall grass that factory lighting is... inadequate. Thinking 50" light bar on top, two extra fogs in the lower grill, and something like this for reverse. Id rather mount them higher up since factory lighting is garbage is brush, but then again, the only other option would be top of the tailgate or on the back of the cab. Both places they would get crushed anytime I use the truck bed... undecided on location, but great step by step erod998!! I always save these pages for when I decide to finally take the plunge. They look great!
  20. Sep 12, 2015 at 12:41 PM
    #40
    Loudass Arod
    Loudass Arod Active Member
    A-ROD
    St. Petersburg, Fl
    2015 Tacoma TRD Sport 4x4 long bed
    Thule Truck Rack, tow package, front seat covers, indoor/outdoor carpet for the lay down of the bench seats.
