My $350 mistake!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheSchwartz, Feb 21, 2009.
  1. Feb 21, 2009 at 12:25 PM
    TheSchwartz
    TheSchwartz [OP] Well-Known Member
    Aaron
    Smithsburg, MD
    '11 DC/LB SR5 Magnetic Gray
    Avid BullBar, BFG 265/75R16, remote car starter, Slim's HID heads and fogs
    Well it happened and I have no one to be mad at but me. My friend (an experienced mech for five years) and I (experienced operator for five years installed) my TOYTEC 2.5" lift last weekend. Since then I was hearing a chattering noise in the front end. Since im a procrastinator I decided to check it out when I did my oil change. Two days prior to my oil change I heard a pop while taking a turn and thought nothing it. While changing my oil I figured it out. My sway bar bracket was left loose and had fallen on to my CV boot tearing it. All in all dealer quote $350, would do it my self but nobody has the parts (to new).
  2. Feb 21, 2009 at 12:27 PM
    trcksr4grls
    trcksr4grls Prayers for Bill and Michelle
    Texas
    Debadged 08 Super White Prerunner
    ouchhhhhhhhhhh that is a costly lesson, but could of been worse....
  3. Feb 21, 2009 at 12:44 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    One of the many reasons I tend to stay away from lifts for these trucks. To many problems seem to develop after installing one. Not my cup of tea so to speak. Good luck. :)
  4. Feb 21, 2009 at 12:47 PM
    TheSchwartz
    Aaron
    Smithsburg, MD
    The lift both looks great and rides great. This was my mistake of not recheckng my work.
  5. Feb 21, 2009 at 9:34 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    His issue has nothing at all to do with a "problem" that "developed", he simply made a mistake (which we all do on occasion). If you aren't confident in your own wrenching skills, I understand, but there's nothing wrong with lifts when done properly.
  6. Feb 21, 2009 at 9:37 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    sounds like your buddy needs to cough up $350..lol
  7. Feb 21, 2009 at 9:41 PM
    hillbillytaco
    hillbillytaco HOT!!
    Jeremy
    westbyGodvirginia
    06 impulse red trd off road dc v6 6spd
    :worthless:
    still like to see the truck because i wanna put mine in the air so bad
  8. Feb 22, 2009 at 7:07 AM
    TheSchwartz
    Aaron
    Smithsburg, MD
    Ill get some pic up when I get the truck back. Ill also try to get it next to a TRD so you can see a comparison.
    Aaron
  9. Feb 22, 2009 at 7:14 AM
    TheSchwartz
    Aaron
    Smithsburg, MD
    We looked for 2nd gen parts in general and nobody had them. All they had were lugs.
  10. Feb 22, 2009 at 7:29 AM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    hey, we all make mistakes. i made some on my Transam a few times.
    I dropped a lifter while changing the cam one time. Had to pull the heads off and replace all the gaskets and bolts then- that was like 200 bucks worth of parts.
    The first time I was changing my torque converter I managed to break my trans pump. I don't recall the price to fix it, but I think it was about a grand or so.
    Since then I've changed converts and trans more times than I can count, same with heads and cams as well.
  11. Feb 22, 2009 at 7:45 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Sorry to hear of your pain.
    I had a track bar loosen and wallow out at the frame connection on a Jeep lift.
    If I had re-torqued after a few miles (like you're supposed to :eek:), I might have caught it in time.
  12. Feb 22, 2009 at 10:02 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    That doesn't sound right, I think you need to do more searching; these things have been around for many years. I can't imagine that the only folks able to perform work on them would be the dealers. I'm sure someone will come along with info shortly...
