My 4 Wheel Drive is Messed Up!
Discussion in 'Technical Chat' started by aleok, Sep 21, 2009.
  1. Sep 21, 2009 at 1:51 PM
    aleok
    aleok [OP] Active Member
    Hi Everyone,
    I got my 09 tacoma about 2 months ago. I feel like ever since the day I got it my 4-wheel drive has been acting strange. Whenever I put it in H4, it sometimes flashes and doesn’t want to go in and sometimes it does. The truck really feels different when in H4, it seems to be driving with the brakes lightly pressed. And when I make a slow turn, the truck basically comes to a stop, like the brakes are fully on. While in the turn it won’t even move, unless I give it some serious gas. Anyone know what the problem is?
    Thanks.
  2. Sep 21, 2009 at 2:09 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    it should be operating normaly. thats the way mine operates in my 99. it'll slow and stop while turning in 4WD unless pressing the gas. however, u have an electronic 4WD i got mechanical meaning i can control my 4WD with a lever that sits right next to the shifter on my truck. take the truck to the dealer for the 4WD not wanting to engage. everthing elses is working fine tho.
  3. Sep 21, 2009 at 2:27 PM
    aleok
    Thanks for the quick reply, why is it like this. the 4wd on my jeep drives like normal...
  4. Sep 21, 2009 at 2:29 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Doesn't sound like a problem to me. That is how it works for me:rolleyes:
    Woot woot 1,700 posts
  5. Sep 21, 2009 at 2:31 PM
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    normal x3
  6. Sep 21, 2009 at 2:41 PM
    toytaco85
    toytaco85 Well-Known Member
    Arizona
    96' 4x4 single cab
    thats how mine feels when 4wd is engaged
  7. Sep 21, 2009 at 4:25 PM
    aleok
    ok thanks guys! just seemed strange...
  8. Sep 21, 2009 at 4:38 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    normal driving you shouldn't really feel any difference with it engaged. it will feel different in turns though but shouldnt bog the engine down. unless your at full lock (which you really shouldnt be doing in 4wd anyways) mine engages/disengages without even noticing it while i'm driving straight. you can feel a slight clunk but thats about it.
  9. Sep 22, 2009 at 5:01 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If you have 4wd engaged on pavement it will probably be more pronounced (worse). It's not so bad on gravel or dirt and rocks.
    Also, driving on pavement with 4wd is not good for the drive train as I believe it puts much more stress on all the parts. Someone can chime in here and tell me if they agree with that.
  10. Sep 22, 2009 at 7:26 PM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    I wish I had the stick shift type 4wd instead of electronic. It seems to always engage instantly (had one on an Izusu trooper), unlike my Tacoma which sometimes engages instantly and sometimes flashes before it engages.
  11. Sep 22, 2009 at 7:36 PM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    My '06 taco engages into 4 without noticing. Very smooth. I wonder from what you described if there is any fluid in the transfer case or front diff!? If you got it from the dealership, maybe you should check if they put oil in!!! You should not feel a major change in anything when going into 4X4. It should be smooth.
