My 4bander makes an annoying rattleing sound.
Discussion in '4 Cylinder' started by Grant!, Sep 12, 2010.
  1. Sep 12, 2010 at 5:04 PM
    Grant!
    Grant! [OP] Member
    Grant
    Folsom California
    04 PreRuner SR5 2.74cill
    As the title says my 4banger makes an annoying rattleing sound when its stalling. Anyone have any idea what it could be?
  2. Sep 12, 2010 at 5:13 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Let me guess it only does it when the a/c is on and your not on the clutch?
  3. Sep 12, 2010 at 5:27 PM
    Yota1
    Yota1 Well-Known Member
    mine does that to, any ideas what it could be, almost sounds like a heat shield
  4. Sep 12, 2010 at 6:39 PM
    08pretaco
    Oliver
    az
    well for the 05+ it might be a throw out bearing...im not sure though. Everytime I have gone to the dealer to ask they "dont" hear it when its blatant as hell
  5. Sep 12, 2010 at 6:50 PM
    tacoma92
    tacoma92 Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    Well after I changed out my timing belt I don't hear the noise anymore so idk tht mite b it
  6. Sep 12, 2010 at 6:58 PM
    08pretaco
    Oliver
    az
    hmm for you that makes sense but I have had this since I drove off the lot brand new :(
  7. Sep 13, 2010 at 4:24 PM
    old dad
    old dad Well-Known Member
    mark
    sc
    tacoma pickup
    n/a
    there is a thread going on it on the 2nd gen side,, same issue
    mark
  8. Sep 13, 2010 at 4:59 PM
    Grant!
    Grant! [OP] Member
    Grant
    Folsom California
    mines an 04... I just went out and started it and it's not makeing the noise. I turned the AC on and still didnt make the noise. And mine's an automatic.
  9. Sep 13, 2010 at 5:09 PM
    AlexXx
    AlexXx Well-Known Member
    Louisiana
    99 taco
    All-Pro 3" Rear kit, Camburg Coilovers, 1" RB BL, 285/75/16's, and rear Lock Right locker Collecting 4wd parts to convert.
    Check to see if the clap for the tail pipe, right above the pass. A-arm came loose. Mine came loose and it just sits on the pipe and rattles at stalling.
  10. Sep 16, 2010 at 11:43 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Mine did the same thing. It was the clamp. The bolt backed out and the clamp slides down to the O2 and just vibrates and rattles against the pipe. Just reinstall it to the black bracket that's bolted to the trans bell housing and tighten it good and keep checking it. mine did this before just 2 months after I bought it but the dealer repaired it. Then it happened again last month.
  11. Sep 17, 2010 at 4:14 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    you have a v6....
  12. Sep 18, 2010 at 4:01 PM
    chriss
    chriss Well-Known Member
    chris
    What do you mean by "stalling"? Like heavely loaded at a low RPM and just about to die? Maybe valves.
