My 5 lug
Discussion in '5 Lug' started by 00greentaco, Jul 25, 2016.
  1. Aug 8, 2016 at 7:54 PM
    00greentaco
    00greentaco [OP] Well-Known Member
    And post some pics!
  2. Aug 8, 2016 at 8:04 PM
    Kevin King
    Kevin King Texan Taco
    I will once I get my tires and wheels! :D What wheels are you running?
  3. Aug 8, 2016 at 8:43 PM
    00greentaco
    15x8 fake beadlock wheels
  4. Aug 8, 2016 at 9:09 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    That's the tire size I want to get to eventually lol
  5. Aug 8, 2016 at 9:14 PM
    00greentaco
    Well it's definitely do-able. Mine doesn't rub either.
  6. Aug 31, 2016 at 6:29 AM
    Kevin King
    Was the spring over hard to do? What flip kit did you used?
  7. Aug 31, 2016 at 9:22 AM
    00greentaco
    It was done by the previous owner
  8. Dec 6, 2016 at 11:30 AM
    Arty97tacoma
    Arty97tacoma 97tacoma5lug2.4L
    Art Narvaez
    Rohnert Park, CA USA
    97 tacoma 2wd 5 lug 2.4L
    Fabtech 3in lift spindles, 1 1/2in coil springs spacers, with 30in Kenda klever mt tires with 15in procomp rims, rear 2in fabtech lift shackles, Fabtech performance shock all round, k&n air intake, street & performance throttle spacer, Doug thorley headers, magnaflow highflow catalytic converter, super 44 flowmaster muffler, Royal Purple synthetic fluids all round,
    Hey greentaco im wondering how well the Fabtech lift coil and upper arm work with the Fabtech spindles. Im currently running fabtech spindles and coil spacers with 30in mts on my 97 tacoma 5 lug. I recently bought a brand NEW Fabtech upper arm and lift coil kit. Im about to install but I keep reading that alot of people don't like it and that coil rubs with upper ball joint and that lower shock mounts break. I have broken a stabilizer bar mount in the past as well as driver side lower ball joint so I know I'll breaking parts after 6in lift . Let me know what you think before I install and regret it cutting off bumpstop mounts. Truck look awesome btw are you running rear wheel spacers? How many inches
  9. Dec 6, 2016 at 12:33 PM
    surftaco16
    surftaco16 Well-Known Member
    Oahu
    1997T100 V6, MT, 4WD T100 1996 V6 5lug Taco, MT
    Looks awesome. Where did you find the 583 gear and how did you decide to use that one? I am wanting to regear mine due to the loss in power, but am not too sure where to find them or which one to use
  10. Dec 8, 2016 at 2:03 AM
    spencerjg72
    spencerjg72 Well-Known Member
    2004 toyota tacoma 5 lug base model
    LCE built motor +40 street piston set Chromoly H-Beam Connecting rods Lightweight flywheel (11lb) 2RZ Head Stage 3 KIt Pro Head stud kit Stage 3 Camshaft set Street Series water pump Adjustable Camgears 2RZFE Flex Fan (16in)
    what lowers are you using
