My 50W FX-R Retrofit Build
Discussion in 'Lighting' started by viperstd, Nov 9, 2011.
  1. Nov 20, 2011 at 10:09 PM
    #41
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    this^ and i don't like using screws to mount any projector personally buy a 5 gallon buckets worth of jb weld and your golden it would be better than the screws imo
  2. Nov 23, 2011 at 6:09 AM
    #42
    viperstd
    viperstd [OP] Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Thanks. I ended up doing just this and it seems to be working.
    It wasn't a typo. Every page I had seen for HID retros mentioned turning the oven to 300*, letting it come to temp, then turning it off and lputting the headlights in for 7 minutes. Honestly, if they were any cooler I wouldn't have been able to pull them apart. This only had the housings hot enough to work with for 2 minutes.
    The housing are hot when they come out of the oven, but I can still handle it bare handed.
    Be careful with heatguns, they can get much hotter than a lot of people realize. Like 1800 degrees.
    Yeah, the screws were a PITA, however, it let me do test fits, make small adjustments, and move the projectors to get ready for the 5 gallons of JB weld.
    I just put 600 miles highway driving in the rain yesterday and they didn't seems to leak, and more importantly worked the whole way.
    Overall, this projector mod was a disaster. When TRS sent the replacement it was a different model (vers 1 vs 2) and a different colored ballast. The new projector required a bigger hold, the holes in teh reflector bowl didn't line up..a disaster. I should have returned the new projector to TRS and had them send the right one, but I needed to drive 600 miles ASAP.
    I will get some finished results pictures up next week when I get back from the trim.
  3. Nov 23, 2011 at 7:38 AM
    #43
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Looking forward to the pics
  4. Nov 23, 2011 at 7:52 PM
    #44
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I'm glad someone else is having a bitch of a time with this. I thought I was the only one!! To the OP -looking forward to seeing your progress
    Also with the stripped plastic screw anchors, are you adjusting the screws with a drill instead of by hand?
  5. Nov 25, 2011 at 9:14 PM
    #45
    viperstd
    Maryland
    I wasn't adjusting them with the drill, but disassembled them with a drill. I was too impatient to use a screw driver for 30 minutes...
    Live and learn!
  6. Nov 25, 2011 at 9:26 PM
    #46
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i was meaning to say for you to use no screws at all. if you mount it directly to the rear of the reflector bowl using epoxy that way the projector mounts further back in the bowl and will give you complete control over the aiming and positioning of the projector it is more secure than the screws.
    also the plastic anchors you stripped out blob some epoxy on those as well to drive the screw in you can still adjust your lights but they will be much more resistant to stripping or having any other issues later down the road. if your into off roading your truck that may very well happen due to the extra weight of the projector hanging off of those two plastic anchors.
    the heat gun is a better way the lens is a hard plastic and resistant to heat much more so than the rear plastic of the housing the tabs that your grill clip into can become brittle and break that is a fact it happened to me twice once done by a professional and once myself i used aftermarket housings as well but, still that soft gray plastic was not meant to see that type of heat especially for that length of time.
  7. Nov 27, 2011 at 9:10 PM
    #47
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Same exact mistake I made. After readjusting a hand full of times I noticed I couldn't get the reflector bowl to stay put :(
    I ended up finding some damaged lights for dirt cheap and now I'll be tearing those apart to possibly re-cut new holes in those reflector bowls.
  8. Nov 28, 2011 at 9:32 AM
    #48
    viperstd
    Maryland
    Filling those adjuster clips with 100% silicon and drilling a small hole in it worked well. The lights adjust fine now and don't seem to bounce. 1500 miles later they are exactly where I left them. I'm not sure that they would take a huge amount of offraoding though.
  9. Nov 29, 2011 at 3:11 PM
    #49
    viperstd
    Maryland
    Below the cutoff line:
    More color Flicker:
    This is rain on the outside. No condensation inside as far as I can tell after 500 miles of driving in the rain.
  10. Nov 29, 2011 at 3:23 PM
    #50
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, OME Nitrocharger shocks and Dakar leafs, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, Leer shell, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    looks awesome! can't wait to do mine!
  11. Nov 29, 2011 at 4:33 PM
    #51
    BenJammn5
    BenJammn5 RN
    San Jose
    That looks awesome. Any day pics w/ the black reflector bowl?
  12. Nov 29, 2011 at 5:13 PM
    #52
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    loooks good!
  13. Nov 29, 2011 at 6:08 PM
    #53
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Looks good man nice and level cutoff good work
  14. Nov 29, 2011 at 6:18 PM
    #54
    viperstd
    Maryland
    I'll snag some daylight photos tomorrow.
  15. Mar 1, 2012 at 9:09 PM
    #55
    AstroluxAtom
    AstroluxAtom Well-Known Member
    Sunnyvale, California
    '05 v6 4.0L DCSB Offroad Prerunner Debadged
    3" Pro-Comp lift kit, Pro-Comp Tires, Magnaflow exhaust dumped at rear axle.
    lies.
    Snap some pics man I'm thinking of doing this soon enough.
  16. Mar 3, 2012 at 8:32 AM
    #56
    viperstd
    Maryland
    not lies... I have photos... just never posted them :p.
    I'll see what I can do when I get home from work.
  17. Aug 28, 2013 at 8:21 AM
    #57
    fenderpicks
    fenderpicks Well-Known Member
    Can anyone explain to me how to look at the aiming diagram?
    Because I been staring at it and don't understand wth I'm looking at lol
