My 5100 install
Discussion in 'Suspension' started by DWreck, Jul 24, 2010.
  1. Jul 24, 2010 at 4:16 PM
    DWreck
    DWreck [OP] Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    First off, thanks to DSM for the awesome service!
    Here is their link; http://www.tacomaworld.com/forum/do...lstein-5100-2nd-gen-series-shocks-update.html
    Received my 5100's less than 48 hours after ordering them!
    Took my 85 LTD LX 5.0L out of the garage and threw my truck in for the install.
    I had to go buy new jack stand because mine were not tall enough.
    This is also the factory bottle jack maxed out, what a joke!
    Started off by removing the tires, sway bar, lower control arm bolts, and tie rods, then set the spindle and rotor back to allow for work room and enough space to remove the shock.
    I removed the shocks. Used a rented spring compressor from Autozone and sucked down the springs just enough to unbolt the top plate without it decapitating me! I ended up having to hold the shocks rod with a wrench and loosen the bolt with another as it spun on me.
    I lifted the whole assembly off the old shock and set it on the new one. I did have to crank down on the spring compressors to get the new bolt started on the new shock. After the top nut was tight, I loosened the compressors.
    This is it after completing that...
    Did the same with the other side and installed assembly. A helpers foot on the lower ball joint is enough to get the shock in.
    Installed the other side and began to put everything back together. Using locktite where previously used. (Lower control arm to spindle and sway bar). Then torqued everything to factory specs.
    Replaced the wheels and here we sit...
    Here is my measurement from center of hub before install...
    And after install...
    Hope you enjoy and this offers any help to anyone looking to install some 5100's. :D
    7/27/10 Edit;
    Before (brand new)
    After 5100 install at 5200 miles
    After TSB at 5500 miles
    After the TSB i ran it down the same powerline road I always run my dogs on. It is definately stiffer, which is good! It feels like a damn truck now and now a sedan. Especially with the stiffer front from the 5100's set at 2.5. Anyway, I love how it handles. It hits the bumps, takes em, and settles. No more bounce after. I would recommend this set up to anyone!
  2. Jul 24, 2010 at 4:40 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    nice write up.....
  3. Jul 24, 2010 at 5:33 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Looking good D!
  4. Jul 24, 2010 at 5:36 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  5. Jul 24, 2010 at 10:58 PM
    DWreck
    Derek
    Las Vegas, NV
    Honestly, feels stiffer, more like a truck should feel I guess. It also controls and holds the road better. Almost feels similar to the 3" spacer lift I had on my '07, but better.
  6. Jul 24, 2010 at 11:13 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    :thumbsup: Looks good. Nice write up.
  7. Jul 25, 2010 at 3:10 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Great job, great results & great illustration, no offense man but when you rolled out that ugly boxy Ltd you shoulda rolled it on down the street & parked it in front of that neighbor that you don't really like !! (we all have one)Those years were butt-ugly for U.S. autos (not just ford) but again ,you did a good job of installing & documenting it too ! :D:D
  8. Jul 25, 2010 at 8:09 AM
    DWreck
    Derek
    Las Vegas, NV
    Hahaha! Thanx but that LTD is sadly part of me. Like I said it was my dad's old squad car. My first car and I drove it for 4+ years. Even when I got a different vehicle is was always there to back me up :D. It has the 5.0L in it and everything from a fox body mustang is interchangable, including the front clip! I will probably never part ways with this car. Even though it is not worth it, I will end up fixing it up again one day!
    Glad you liked it though!:rolleyes:
  9. Jul 25, 2010 at 9:04 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    Did you done anything in your rear beside the 5100 shock ? how was your truck sit ? level or nose high ?
    Im gonna lift my truck to 2.5" and add 1" block for the rear to make her sit level.
  10. Jul 25, 2010 at 7:19 PM
    DWreck
    Derek
    Las Vegas, NV
    I only installed the shock! Taking it in tomorrow for the TSB. Depending on how it sits I may to an AAL. I would recommend the AAL for you also, instead of the block. It does sit somewhat nose high at the moment, not too noticable though. And like I said, after the TSB we shall see.
  11. Jul 25, 2010 at 7:20 PM
    DWreck
    Derek
    Las Vegas, NV
    I promise!!!:D
  12. Jul 25, 2010 at 7:23 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Take pics & post alignment info pls.
  13. Jul 25, 2010 at 7:26 PM
    DWreck
    Derek
    Las Vegas, NV
    I shall! It does sit a little Toe In at the moment!
  14. Jul 25, 2010 at 7:34 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    Thanks for taking the time to do the write up. I installed my 5100's about a month ago and I couldn't be more happy about them. Sonny is the go to guy for these shocks!
  15. Jul 25, 2010 at 7:36 PM
    DWreck
    Derek
    Las Vegas, NV
    Word! I love them so far. Did a 300mi round trip today to Caliente, NV and back. Haven't done an alignment or anything and they rode soooo sweet.
    May I ask what you have yours set at and if you did anything with the rear?
  16. Jul 25, 2010 at 7:49 PM
    28Gauge
    Brian
    Grapevine, TX
    06 PreRunner SR5
    I set them at 0 with a new set of Eibach springs. I also added a set of Toytec 1.5 inch TSB add a leaf springs on my non TSB leaf springs.
  17. Jul 25, 2010 at 7:53 PM
    DWreck
    Derek
    Las Vegas, NV
    Final result? Lift?
  18. Jul 26, 2010 at 7:21 PM
    DWreck
    Derek
    Las Vegas, NV
  19. Jul 27, 2010 at 8:37 PM
    DWreck
    Derek
    Las Vegas, NV
    edit bump
  20. Jul 28, 2010 at 11:58 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Looks dead level to me, awesome! How was the alignment post TSB? And maybe a dumb question, but does the stock jack still work?
