My 5100 install
Discussion in 'Suspension' started by DWreck, Jul 24, 2010.
  1. Nov 18, 2010 at 10:23 PM
    #41
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I just installed my front 5100's at the 2.5" setting. I have a few comments and questions for those who have done the install, and for those who plan on doing this install:
    1- After the install, my lift measured MORE than 3" on both sides. I assume this will settle to 2.5"ish? How long will it take to settle? An hour of driving? A few days of driving? I'm concerned about the CV angles while driving at this height with no diff drop.
    2- I'm picking up my new tires tomorrow and getting an alignment. Right now (immediately after lifting) my alignment is ffffffffff'd. Major vibes/shaking above 30mph, and even after driving 5 miles or so I can already see that the tires are wearing on the outside treads. How is it that some of you guys wrote above that you had "no need for alignment" after your install??
    3- I used a cheesy coil compressor to get the coils off my stock struts, but couldn't get enough draw on them to squeeze them onto the new struts at the 2.5" setting. So I took them to Midas. I realized some time after I picked the assembled struts up that the Midas guys had left out the smaller bushings that go under the top plate. They just used the larger bushings that go above the top plate. They said they couldn't get the small ones to fit under the top plates. :confused: Is this a serious issue that they didn't install the smaller bushings? I know the stock struts don't have a second bushing underneath the top plate, so is it 100% necessary for the 5100s?? Can omitting those bushings affect ride height?? It would be a major PITA to disassemble everything at this point and have them re-assemble the struts/coils with the small bushings in place, but I'll do it if I have to.
    4- I assembled everything and torqued everything to spec, leaving the sway bar re-attachment for last. I realized to my dismay that the ends of the swaybar (still unattached) were stuck above the UCAs because I had tilted the bar up towards the fronts of the wheel wells to keep them out of the way. There was NO WAY to get it un-tilted past the UCAs, so I had to undo the UCA's from the spindles again. Major "doh!" that cost me an extra hour. :(
  2. Nov 30, 2010 at 6:21 PM
    #42
    IrishTaco
    IrishTaco Active Member
    Patrick
    Fort Lewis, Wa
    08 4x4 TRD Sport 6spd
    Window Tint, K&N Air filter...ideas?
    Is there a list somewhere of the tools that are needed for this? gotta borrow some tools from a buddy .
  3. Nov 30, 2010 at 8:12 PM
    #43
    DWreck
    DWreck [OP] Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I too got more than 2.5" lift. I was able to get the second bushing on. Leave it how you found it. I did not take off uca because they have adjustment as the lca does not, this is why your alignment went sooo bad. As far as your cv joints, leave em. They are designed to be at an angle. The diff drop lowers clearance. Search for the guy who learned the hard way.
  4. Dec 1, 2010 at 1:42 PM
    #44
    BenWA
    Boston burbs
    There are a few other threads linked in the following thread that may help (note that they are all slightly different approaches to do the same task):
    http://www.tacomaworld.com/forum/suspension/121223-bilstein-5100-install-pics.html
    You don't need much. I used:
    -Liquid Wrench to spray on all the nuts/bolts a day prior to removal
    -two metric socket sets (one deep socket set and one regular)
    -a set of metric crescent wrenches
    -a set of metric allen wrenches
    -a 3/8" rachet wrench
    -a long 3/8" or 1/2" breaker wrench (to undo highly torqued nuts/bolts -- you WILL need this)
    -a torque wrench that goes up to 100 ft/lbs
    -needle nose pliers (for cotter pins)
    -a hammer
    -a tube of Loctite (medium)
    -nylon cord or wire to tie the spindle to the UCA
    -a six pack of your favorite beer
    And of course a good jack, jackstands, and wheel chocks. I recommend NOT doing the coil compressing yourself. Midas will do it for $50. Also, would avoid removing the tierods, as some of the how-to threads suggest you do. I don't think it is necessary to undo tierods to be able to remove or install the strut and is just extra work.
    Feel free to shoot me a text or give me a call if you run into any snags. I'd be happy to try to help.
  5. Dec 1, 2010 at 6:04 PM
    #45
    DWreck
    Derek
    Las Vegas, NV
    Oh man up! Compress springs yourself. I also removed tie rods.
  6. Dec 1, 2010 at 8:02 PM
    #46
    BenWA
    Boston burbs
    Maybe they make better compressors that are a lot beefier than the ones I used, but I felt like I should've been wearing a kevlar vest with the ones I used :) The threaded rods were srsly bent like bananas under all the tension :eek: ...def did not look safe!
    YMMV
  7. Dec 1, 2010 at 8:40 PM
    #47
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'm sure there are some better but from my own experience from using a couple diff. ones, they all banana'd out & looked like they were going to go batshit on me any sec. Just got to make sure they "lock" properly around the coil & get tightened up equally, still kind of a hairy process though....:eek:
  8. Dec 1, 2010 at 8:49 PM
    #48
    DWreck
    Derek
    Las Vegas, NV
    Rented from autozone and used an air gun to compress.
  9. Dec 2, 2010 at 2:29 AM
    #49
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Those guys charged you huh ? Guess it varies from store to store, BIG THUMBS UP for the air wrench !!!!
  10. Dec 2, 2010 at 5:56 AM
    #50
    DWreck
    Derek
    Las Vegas, NV
    1/2 gun. Air wrench wouldnt have the torque.
  11. Dec 2, 2010 at 8:12 AM
    #51
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    wrench,gun OK USE AN IMPACT RATTLE GUN !!! :D:eek::D:eek:
  12. Dec 2, 2010 at 9:40 AM
    #52
    DWreck
    Derek
    Las Vegas, NV
    But the gun, not the ratchet!
  13. Dec 2, 2010 at 12:31 PM
    #53
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    yeah they charge you $50 and then when you return their compressor they give you your $50 back so it's free;)
  14. Dec 12, 2010 at 5:49 PM
    #54
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Adjustable Billies, Debadged, Painted emblem on grille Kenwood Double din, polk components, co-ax, polk 8" sub & polk amp, TSB springs, 6000K hids, FJ Wheels
    Just installed mine today. :D I followed the write up somewhat. I unbolted the sway bar and the tie rods off the spindle.. Instead of loosening the control arm I just pushed own hard one time to get the shock close to the hole then one more quick time to put the bolt in. Went fairly easy and had it in and out in a little under 2.5 hrs with NO air tools. Damn compressor was no where to be found :mad: imagine compessing the springs 1/2 turn at a time :goingcrazy: but went really good and the truck is brand new so I'm sure that made it much easier. Now just waiting to put miles on so I can re-torque the bolts
  15. Oct 30, 2012 at 11:18 AM
    #55
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Nice write up fella. Thinking of doing mine but have a few questions though. I don't plan on raising my truck up I just want to keep it normal hight as it is now, do I put the 5100's at "0" or .85 or what? If I keep the same hight lavel I have now I don't need to mess with the back end leafs? correct? I don't plan on hauling anything heavy or pulling anything with my TACO. Does all the hardware needed come with the shocks? Did you get them at the tacomaworld member discount price? and what was that price?
  16. Oct 30, 2012 at 11:42 AM
    #56
    DWreck
    Derek
    Las Vegas, NV
    Contact Downsouth Motorsports. They are a TW vendor, the cheapest by far, and can answer any and all questions for you!
  17. Oct 30, 2012 at 4:01 PM
    #57
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    You don't need to remove all that to install Bilsteins. I didn't.
