My 5100 Installation Experience
Discussion in 'Suspension' started by Guy Incognito, Jul 18, 2009.
  1. Jul 18, 2009 at 11:31 AM
    Guy Incognito
    Guy Incognito [OP] New Member
    Teague
    Carson City, NV
    03 4x4 Xtra cab
    Cold-air intake Bilstein 5100/5125s Front/Rear (No extra lift)
    I just got finished installing my 5100s in my 1st gen Taco. All said and done, it was only a two and a half-hour job...most of that time being spent using a "two-piece" manual spring/strut compressor. After unhooking the sway-bar linkage and taking the castle-nut off the upper ball-joint on the right side, my buddy and I realized all we really had to do was remove the top and bottom mounting hardware on the coilover in order to remove it. Sure enough, the left side came off w/ the removal of four bolts. Re-installation was just a matter of lining the bottom of the shock back up with the lower control arm; a pry-bar between the frame and the UCA provided plenty of leverage to do so.
    After reading many of the tales of woe and frustration from 2nd gen owners, I wasn't sure if this was going to be an all-day ordeal or what. Having done it, I'd say "go ahead" and try to do it yourself if you're considering new shocks...and a big thanks to Down South for the sweet pricing on the 5100/5125 setup. It's just foolish to not upgrade...
  2. Jul 18, 2009 at 12:04 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Good to hear you didn't have any issues.
    I always scratch my head when I read these posts about people disconnecting the UCA from the spindle, or what ever else they might be taking off that isn't necessary. I've done two 3 inch lifts on the Tacoma so far and have not once needed to disconnect anything other than the sway bar and strut. :confused:
  3. Jul 18, 2009 at 12:05 PM
    SC4333
    Grant
    San Antonio, TX
    And I almost forgot, welcome to TacomaWorld! :thumbsup:
  4. Jul 18, 2009 at 1:14 PM
    Guy Incognito
    Teague
    Carson City, NV
    03 4x4 Xtra cab
    Worthless?! It looks like any other non-lifted 1st gen Taco :)
  5. Jul 18, 2009 at 1:23 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
  6. Jul 18, 2009 at 1:37 PM
    Guy Incognito
    Teague
    Carson City, NV
    03 4x4 Xtra cab
    (Is this) Satisfactory?
