My 6 cyl is pinging.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phildo, Mar 13, 2010.
  1. Mar 13, 2010 at 7:35 PM
    Phildo
    Phildo [OP] Active Member
    Phil
    Phoenix
    '14 DC PreRunner TRD
    I just bought a 1 owner lease return 2007 DC Taco. Got a good deal, 36,000 miles and change, and I have owned it for 1 month. The truck has been running great with no issues, until today.
    I had the A/C turned on, hit the on ramp and through 2 and 3 gear (auto) the truck started pinging. I could not get it to do it again, all day. I dont really want to run a higher octane gas, and I do have a warranty. Just wondering if anybody else has experienced this with their Taco.
  2. Mar 13, 2010 at 7:41 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    could have been some bad gas, i wouldnt worry unless it was constant
  3. Mar 14, 2010 at 7:57 AM
    JKD
    JKD Well-Known Member
    Try SeaFoam used as combustion chamber cleaner. If the pinging is being caused by carbon deposits in the combustion chamber, the SeaFoam will help clean it out.
  4. Mar 14, 2010 at 8:50 AM
    Phildo
    Phil
    Phoenix
    Thanks guys, I will try higher octane gas. If that doesnt work I will run some sea foam through it. I have only used that stuff on my Peterbilt, never thought of running it through my Yota.
  5. Mar 14, 2010 at 9:28 AM
    JKD
    I have run it through my previous vehicle's engine about ever 50,000 miles. Smokes out the neighborhood, but it does run better!
  6. Mar 14, 2010 at 9:50 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    So many things can cause noise like you were hearing. You have had good suggestions so far. I will add a couple things to think about.
    Did you check the oil level? This would be a drastic cause of noise on hard acceleration, but oil aeration could cause lifters to start to collapse. Just be sure.
    Are you running a stock air filter or a high flow type? Not that this is the only cause but when I am checking out a vehicle, I look for clues. These vehicles are Mass Air Flow systems as opposed to Speed Density systems. That means that the MAF is the major load calculator for the engine along with some modifiers. It not only give input for fuel, it also is important for calculating TIMING. If the MAF reading is inaccurate the timing could be too advanced for the actual driving conditions. That can result in a ping as well. I will not go into detail on how to check a MAF sensor for operation at this point, but just keep it in mind. Will your warranty cover checkout of a concern, or are you expected to pay for that and they cover the repair? ( If applicable )
  7. Mar 14, 2010 at 10:28 AM
    Phildo
    Phil
    Phoenix
    It still has the factory air intake with a new filter in it.
  8. Mar 14, 2010 at 10:32 AM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Sounds like bad gas. Run some injector cleaner through it too.
  9. Mar 14, 2010 at 8:08 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I've never had mine ping in over 5 years running the minimum octane gas. Some do, some don't. Likely the gas. BUT, if you just bought it and it has 36K miles on it, do you know if the spark plugs were ever changed? They're supposed to be changed every 30K miles. Maybe that's just part of the problem combined with the gas???
    Also, if you're switching octanes, I think others have mentioned that it takes a couple of tank fulls for the computer to recognize the new octane level. Someone can probably chime in on that one.
  10. Mar 14, 2010 at 8:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Before running any seafoam thru it, Change the plugs. Odds are, the plugs havent been changed yet. they are supposed to be changed at 30k miles.
  11. Mar 14, 2010 at 8:36 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^That. And yeah, good higher octane gas does make a difference in my experience with this vehicle.
  12. Mar 14, 2010 at 11:21 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    PING! i think plugs. i didnt realize it, by my pinging is gone! since i changed my plugs. summer is coming, so i will be sure then..but i think it pinged in cooler weather last year too.
    plugs. good luck..keep us posted. this is good info.
