my 88 pickup I just bought
Discussion in 'Toyota Trucks & SUVs' started by matthew5olson, Aug 28, 2009.
  1. Aug 28, 2009 at 5:55 PM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I just bought an 88 reg cab 2wd 22re pickup auto with a bad motor in it for $200. Has 159,000 miles on it. The frame has no rust on it at all, although the body has a few small spots.
    It did not finish the drive home however. Some previous idiot used 8 gauge wire for the battery terminals and when the truck stalled out at a red light it wouldn't start because the wire was all fried. So I have to tow it home (which would be better for the motor anyway)
    I plan on building it for 1/8 mile racing. The block and head should be good so I will just get a rebuild kit. I'll build it to be able to handle NOS.
    Any thoughts as to whether I should put a carburetor motor in (possible?) for added tuning.
    Will post pics when I get the truck home tomorrow. had to leave it in the parking lot where it broke down. After I got home I realized that I forgot to get an address where I left it so hopefully I can retrace my steps and find it. That would suck trying to spend all day looking for it. Thoughts, comments, and advice appreciated.
    Oh and as always I don't have a lot of money to spend (the kind to drop in a chevy 350 say). It doesn't have to be a rocket ship but I would like it to be faster than my taco (times in sig)
  2. Aug 29, 2009 at 8:05 PM
    matthew5olson
    matthew
    pittsburgh, PA
  3. Aug 29, 2009 at 8:06 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    :woot:
    Awesome!
  4. Aug 29, 2009 at 8:08 PM
    Wren
    Wren Well-Known Member
    Josh
    Williamsburg, Ky
    11 White Reg. Cab 4x4
    great buy but only if it was 4x4 but you probably have a reason for it so good job :proposetoast:
  5. Aug 29, 2009 at 8:09 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Why is the motor bad?
    Welcome the pre2taco club brother!!!
  6. Aug 29, 2009 at 8:12 PM
    matthew5olson
    matthew
    pittsburgh, PA
    knocks real bad. prolly bad rod bearings as it does it through the whole rpm range. it only has 159,000 on it though. somebody didn't treat it to nice I think. Frame is immaculate though.
  7. Aug 29, 2009 at 8:14 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I know what you mean. The body is falling off mine but the frame looks brand new. Go figure. Maybe toyota will get it right one of these millennium. :notsure:
  8. Aug 29, 2009 at 8:48 PM
    matthew5olson
    matthew
    pittsburgh, PA
    I just read your build. I was disappointed that you didn't finish until I realized you just bought your truck too. The body on mine is a lot better than yours (although I'm afraid of what is under the bedliner too). I have to do a whole engine rebuild though. I wish it was just a head gasket issue. I had a 4 cyl head milled, cleaned and tested about a year ago (2.2L gm) and it came to 160 I believe.
    I'm building mine for the race track so I'm gonna try to get a few extra horses when I do the rebuild. I'm also gonna make it strong enough to withstand some nitrous.
    Not sure what your intentions are for the truck but I have a set of running boards, a bedliner, and a bug shield (on the hood) if your interested. I was gonna try and sell em so if you want you can have first dibs.
    Also you live in PA right? I have family in lancaster which I think theres a beech creek out there.
