My 98 Tacoma Flat Bed Project
Discussion in '1st Gen. Tacomas (1995-2004)' started by Strostkovy, Mar 6, 2021.
  1. Jun 28, 2021 at 1:04 AM
    Strostkovy
    Strostkovy [OP] Well-Known Member
    Alex
    White 98 Tacoma
    The bed will be 80-84 inches long and 66" wide. I'm sure I could get an 8 foot bed looking nice if I moved the rear axle back but I'm trying to keep this project under control.
  2. Jun 28, 2021 at 2:18 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Subbed here.
  3. Jun 28, 2021 at 2:44 AM
    Key-Rei
    Key
    Florida
    You've got quite the Toyota family there, you must do this for a living? Or trying to start your own Fab shop?
    I've seen those dots on elements in my line of work but never knew you could 3D map with them like that, that is so damn cool.
    What program is that? Solid works? Fusion?
    What actually used to take the "scan" with the retro-reflective dots?
    What's going in with the leafs on the Taco? Is that an anti-wrap set-up?
    Strostkovy[OP] likes this.
  4. Jun 28, 2021 at 4:33 AM
    Strostkovy
    Alex
    White 98 Tacoma
    I work for a somewhat prominent manufacturer of bumpers and may or may not live on site.
    The scanner is a peel 2 handheld scanner made by creaform. It's fairly entry level but does a good job. This scan took 500 stickers, 2 hours to scan, and 3 hours to clean up and export the scan. There are high end ones that you just turn it on and point it in a few spots and it's 100% done but those are over $40k. Eventually, but not yet.
    The program in the picture is peel2cad that handles mesh cleanup and exporting and all of the fun stuff. I quite like the program actually.
    I then commit a cardinal sin and import it into sketchup, despite having a seat of solidworks. But I got the bed 50% of the way done in the model in about 6 hours, and that's just not something I can do in solidworks that fast. I don't have an internet connection worthing trying fusion with.
    I was looking at the leafs and I noticed it was weird to me with all of the partial leaves and assumed it was for axle wrap. I was under the impression it was stock. I'll be swapping them for deavers when I do the lift.
    EDIT: They are definitely a bolt on aftermarket item. It's held in place with two U bolts around the spring. The E-brake cable is actually super tight against them and that probably has something to do with why it's so hard to set. I'll check the transmission and engine mounts because sometimes people confuse those being broken with axle wrap.
  5. Jun 28, 2021 at 6:26 AM
    MooseDawg
    MooseDawg Active Member
    2002 Prerunner SR5 TRD 3.4lv6 Auto
    Chassis unlimited front & rear bumpers
    :popcorn: Sub’d
  6. Jun 28, 2021 at 7:06 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    those are "helper springs" that bolt onto a leaf pack so that when extra load/weight is applied they are factored in. otherwise they sit pretty idle and don't do much
  7. Jun 30, 2021 at 4:07 AM
    Strostkovy
    Alex
    White 98 Tacoma
    What do you guys think so far?
    [​IMG] [​IMG] [​IMG]
    01x4, rogerman, Nicklovin and 4 others like this.
  8. Jun 30, 2021 at 9:31 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    A wee bit jealous :laughing:
    Is that outside rail for tying things down?
    How high above the frame is the bottom of the deck going to be?
    And is that door for the fuel filler on the left there? Fuel filler was kind of a pain on mine. Its easy enough to get it working, but getting it so the pump cut off worked correctly took some doing, not a whole lot of room to tweak it in my case.
  9. Jun 30, 2021 at 10:54 AM
    Strostkovy
    Alex
    White 98 Tacoma
    Yes, the rail is spaced off 3/4".
    The deck is 5" above the highest point of the frame. That gives just a little bit of gap when 33s bottom out.
    Yep, that's a fuel filler door on the driver's side and hot and cold water and compressed air on the passenger side. It's so close to stock location I don't really need to tweak anything.
    0xDEADBEEF[QUOTED] likes this.
  10. Jul 3, 2021 at 10:31 PM
    Strostkovy
    Alex
    White 98 Tacoma
    Rough estimations show 300-350 pounds for everything except the rear winch.
  11. Jul 7, 2021 at 1:03 PM
    750ml
    750ml Active Member
    A.
    2001 Tacoma
    235/85r16 Toyo Open Country AT3's, 4.88 Yukon gears, Eaton Trutrac front and rear, 2" lift
    Sweet!
  12. Jul 8, 2021 at 9:51 AM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    This is amazing.
  13. Jul 9, 2021 at 12:10 AM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Now I want a flatbed for my 4 door so I can get rid of my 4 foot bed :rofl::anonymous:
  14. Jul 10, 2021 at 6:09 AM
    Palencia97
    Palencia97 BDPALENCIA
    Sarasota, Florida
    '16 Sky Silver SR DC I4, '00 SF Red TRD OF XC V6 4x4
    Welcome to TacomaWorld! Any question you have, you'll find here!
