My 99 Shake really bad at highway speeds...need advice !!
Discussion in '1st Gen. Tacomas (1995-2004)' started by savoy, Mar 5, 2009.
  1. May 13, 2009 at 8:04 PM
    #41
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    affirmative
  2. May 13, 2009 at 10:10 PM
    #42
    jeeters79
    jeeters79 Active Member
    Arlington , WA
    '99 4X4 SR5
    Not that I need to anymore on this thread, but DIITO! That's totally me too. It almost seems as if it's the driver-rear corner that's bouncing more than the other side.(which is also my buggered up wheel)
  3. May 14, 2009 at 4:22 AM
    #43
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    Hmmm....
  4. May 14, 2009 at 6:39 AM
    #44
    HARDSHELLTACO
    HARDSHELLTACO HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    what type of rear shocks, just curious.
  5. May 14, 2009 at 7:03 AM
    #45
    Robbsolid
    Robbsolid Zombie Killer
    ABQ, N.M.
    02 PreRunner SuperWhite DBL Cab
    Plastic X'd Flares, deck plate mod, Thrush welded muffler, graphite painted wheels, relocated turn signals, fogs in bumper
    someone has to know something about this... I love my truck, but the shakes drive me crazy.
  6. May 14, 2009 at 7:06 AM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Someone mentioned one of their wheels was bent....I would fix that first, then see if there are any more vibes.
  7. May 14, 2009 at 7:18 AM
    #47
    Robbsolid
    ABQ, N.M.
    I noticed that my tires wear on the inside a little more than the rest,
    and my rims DO NOT hold the weights that discount tire puts on them, 2 days after they balance them I hear the wieghts pinging off my truck going down the highway.
    I am gonna rebalance the tires, and put spacers on my carrier bearing and see if that works
  8. May 14, 2009 at 6:16 PM
    #48
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    hey guys, just checking in. i went today and swapped out the nexens with some michleins, and guess what? the shake is still there. the guys at the tire store inspected the michleins and the wheels and reported that neither one was bent/warped/out-of-round. I still believe that my carrier bearing is bad, due to the 1/2'" of play in it. so i just ordered a new one that will be here saturday. if this does not fix it, i got some lefter ordinance that I will put to good use :eek:. hardshelltaco, i am not sure if you were talking to me, but i just went with some gabriels, front and rear. since i do no off-roading, i dont need anything fancy. b.t.w., i do the maglite mod today, with the aid of some quick fist clamps, looks superbad!
  9. May 14, 2009 at 6:19 PM
    #49
    S1E675
    S1E675 Never enough toys
    Ohio
    04 TRD 4x4
    Okay, I know I’m new here, but I had something like this on my 01 PreRunner, and just recently on the wife’s 97 4Runner. It was an unexplainable vibration that seemed to come from nowhere, couldn’t feel it in the brake pedal, and didn’t really show in the steering wheel either. It only seemed to show up at highway speeds, and braking from down from them. For me in both cases, it turned out to be the E-brake not releasing on one side.
    Just climbed under the truck, moved the rubber boot out of the way where the E-brake cable gets to the brakes, spray lavishly with penetrating oil, beat the heck out of the lever until it moves freely, and fixed.
    Not sure this is the problem for the OP, but some of the other post sounded very much like this.
    Hope it helps
  10. May 14, 2009 at 6:27 PM
    #50
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    were your vehicles manual shifts? I have an auto and never use my e-brake, or can it do it regardless?
  11. May 14, 2009 at 6:32 PM
    #51
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd still do it, and its a good idea to engage the parking brake every so often....makes sure everything is in working order....keeps it from rusting and locking up potentially.
  12. May 14, 2009 at 6:53 PM
    #52
    S1E675
    Ohio
    04 TRD 4x4
    It really shouldn’t matter if it was auto or standard. The E-brake is an independent system. But both were autos.
    I guess I would have to ask how long you have had your vehicle? I didn’t discover the wife’s 4runner problem until I drove it. She never “felt” it, even though it felt like the thing was going to shake apart like a bad caravel ride! It only takes one time of applying the E-brake for this to happen. And it will only be worse if it hasn’t been used for a long time.
    Either way, it’s very easy to check and fix.
  13. May 14, 2009 at 7:01 PM
    #53
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    i have had it about a month or so, didn't really notice at first until a got the tires rotated/balanced. then it stood out like a sore thumb. matter of fact, i am goin to check mine now. brb
  14. May 14, 2009 at 7:06 PM
    #54
    98tacoma27
    Ben
    Not Beech Creek
    Has anybody with the conditions checked their u-joints? Some of your symptoms are indicative of a bad u-joint.
  15. May 14, 2009 at 7:08 PM
    #55
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good idea man.
  16. May 14, 2009 at 7:14 PM
    #56
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    how hard of a beaten are we talking about, and in which direction? mine moves, but not to freely, you have to give it a tad bit motivation.
  17. May 14, 2009 at 7:17 PM
    #57
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    i have checked my u-joints, they are fine, but i am concerned with my center support bearing. is 1/2" play in it to much?
  18. May 14, 2009 at 7:18 PM
    #58
    98tacoma27
    Ben
    Not Beech Creek
    That sounds a bit much.
  19. May 14, 2009 at 7:20 PM
    #59
    98tacoma27
    Ben
    Not Beech Creek
  20. May 14, 2009 at 7:21 PM
    #60
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    that's what i was thinking, i got a new one coming in 1st thing sat. morning, hoping to get it installed sat. afternoon. damn those things are expensive. but if it solves my vibes., it will be more than worth it. i am tired of losing sleep over my bad ride.:(
