My 99 Shake really bad at highway speeds...need advice !!
Discussion in '1st Gen. Tacomas (1995-2004)' started by savoy, Mar 5, 2009.
  1. May 19, 2009 at 5:45 PM
    #81
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    well.....i had the used michleins on for about 5 days, and the hard bouncing ride disappeared but the steering wheel still shook(no suprise b/c they had about 35000 miles on them and were not rotated on a regular basis), yesterday i put my nexens back on, and the hard bounce is back but the steering wheel stays as still as can be( hard riding tire but have been balanced and rotated regularly, imo). i am started to think that my whole problem has been shaty tires. i found some brand new michleins ltx m/s for 500, as soon as a get the funds new tires it is.
  2. May 19, 2009 at 9:31 PM
    #82
    boredazhell
    boredazhell Well-Known Member
    to all who sprayed wd40 on their e-brake, where did you actually spray it? did you spray it on the cables and joints on the center of the rear truck? Or did you spray it near the wheel hub?
  3. May 19, 2009 at 10:34 PM
    #83
    jeeters79
    jeeters79 Active Member
    Arlington , WA
    '99 4X4 SR5
    I sprayed everything that touched the e-brake, cables, or linkages. And by that, I mean WD40 was on sale...:D
  4. May 19, 2009 at 11:23 PM
    #84
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I had this issue in my 97... having the tires rebalanced fixed the issue.
  5. May 30, 2009 at 10:49 AM
    #85
    Robbsolid
    Robbsolid Zombie Killer
    ABQ, N.M.
    02 PreRunner SuperWhite DBL Cab
    Plastic X'd Flares, deck plate mod, Thrush welded muffler, graphite painted wheels, relocated turn signals, fogs in bumper
    Dont mean to revive threads like a doctor, but do you think i should just get the traction bars and leave my leaf springs? I like the soft ride i have, but not the axle wrap. I'm not sure if it would be pointless to get just traction bars, or just get a whole new spring set(I also dont haul very often).
    Thanks
  6. May 30, 2009 at 9:31 PM
    #86
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well....for what traction bars cost, versus new springs, i'd rather go with springs. try this first tho...........get a set of helper springs from autozone(around$25 to 30 or so) and see if that helps.
  7. Aug 7, 2009 at 6:56 PM
    #87
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    sorry guys for keeping this thread alive but i must share the good news. I finally got my truck straightened out. the problem was with my wheels, come to find out the previous owner for, some strange reason had put steel lug nuts on the stock alloy wheels and when they did the steel nuts just bored out the stud hole. this caused the wheel not to line up with the center ring on the hub which caused all 4 wheels to wobble. I bought some stock '04 wheels and tires from my buddy and now the problem no longer exists. at last i am able to get some sleep at night. :D
  8. Aug 9, 2009 at 1:16 AM
    #88
    jeeters79
    Arlington , WA
    '99 4X4 SR5
    My $.02
    I went to stock wheels, new tires, and replaced my lugs (which were also acorn style, not the toyota mag style). Nice and smooth since. :D
  9. Aug 31, 2009 at 11:07 AM
    #89
    Robbsolid
    ABQ, N.M.
    I just did the same, junked my old stock steel pieces and bought stock 2006 trd rims and painted them. The crazy vibe is gone! I do still have a slight vibe in the seat when i am at like 65 mph, but its not enough to make me go crazy. My u-joints on both ends of the shaft are brand new, so maybe its the CSB causing a little vibe? i have no clue but I'm glad a few of us fixed the deadly shakes!
  10. Sep 1, 2009 at 10:15 AM
    #90
    i love tacos
    i love tacos Well-Known Member
    St. Louis, MO
    01 PreRunner TRD
    Bull Bar, Hella Lights, AiRaid cold air intake
    I would check all ball joints 1st. Second I would check your sway bar. They are hollow and the ends can break from corrosion. Also check the endlinks. (the threaded rods that attach to the ends of sway bar) The sway bar should keep the body roll under control. You may have a broken shock or spring.
  11. Sep 1, 2009 at 2:05 PM
    #91
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I didn't catch what brand & size tire yer running but tire choice & size for Toys are pretty critical because they affect the characteristics dramatically, bigger, softer compound tires like BFG's can wear down to a "loping" as you cruise about 60mph-70mph & do have a problem with "belt/band shifting" inside the tire & it could have started by the one thing we all have & on occasion still do, hitting curbs, sidewalks, rocks that don't move etc;, if you think this is nutty concept try this experiment, while you're driving aim your outside mirror towards your right rear wheel & observe all the flucuations & "warped" rotation, I'm leaning towards a tire problem, also step away from your truck & look at the sidewalls for deformaties...:cool:
