my Aal is shifting
Discussion in 'Suspension' started by BMOC, Feb 20, 2011.
  1. Feb 20, 2011 at 7:12 PM
    BMOC
    BMOC [OP] Well-Known Member
    Paden
    Phoenix, AZ
    i just installed my AAL's a few days ago from toytec, that i got in my ULK.
    and i noticed while today out playing in the mud. the AAL started to move out slightly on both sides. not sure if its something to be to worried about. a good sized hammer solved the problem for a little while. until i went back out to the mud, they would shift again. driving around town it stays put however.
    i know this cant be normal.. as i've never seen any other posts about it. maybe i need to torque my u bolts further?? or something else??
    just tired of slamming my leafs with a big ol hammer to put em back into place... which cant be good for em :lol:
  2. Feb 20, 2011 at 7:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Have you checked the torque on the U bolts?
  3. Feb 20, 2011 at 7:27 PM
    BMOC
    Paden
    Phoenix, AZ
    i got it aligned a couple days ago before the rains hit. asked them to re-torque everything for me, i hope they did... but tomorrow i will re-check their work.. :p
  4. Feb 20, 2011 at 7:30 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Check tq on the center pin and u-bolts. It really shouldn't be loose enough that you can shift it with a hammer without loosening anything.
  5. Feb 20, 2011 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you want, You can swing by my place, and I'll check it out for ya.
  6. Feb 20, 2011 at 7:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Center pin only holds the springs together from separating. It doesnt hold them from shifting sideways at the ends.
  7. Feb 20, 2011 at 7:35 PM
    BMOC
    Paden
    Phoenix, AZ
    awesome, thanks guys, i figured it had to be an untorqued something or other :)
    that would be great, what's your coordinates? :p
  8. Feb 20, 2011 at 7:42 PM
    jandrews
    Agreed, but if it's loose things will shift more easily. Ditto if it's broken.
  9. Feb 20, 2011 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im in Tempe, so if your in Phoenix, Im not sure how long of a drive it is for ya.
  10. Feb 20, 2011 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only if the U bolts are loose. The center bolt really only holds the springs together until the U bolts are torqued. The U bolts asume the load after that.
  11. Feb 22, 2011 at 10:41 AM
    BMOC
    Paden
    Phoenix, AZ
    torqued them up today to 75 lbs... so should all be well now :) thanks for the help
    the idiot mechanics didn't torque them at all..
  12. Feb 22, 2011 at 3:20 PM
    BMOC
    Paden
    Phoenix, AZ
    i installed it on my own, i told the mechanic doing the alignment however, to retorque the U-bolts for me. they didn't i guess.
