My AC Controls Light Mod - How To
Discussion in 'Lighting' started by m3zy6, Aug 3, 2010.
  1. Aug 3, 2010 at 7:46 PM
    m3zy6
    m3zy6 [OP] Well-Known Member
    Richmond, VA
    '17 TRDSport AC 6spd 4x4
    I figured I should edit in a preface with a shot of my completed blue and red dash, completely amber free -
    (click on the pic below, and then click on the pic that opens to see the full size version)
    I only want to change one thing. I am looking for a clearer/darker blue tint for the clock. I use the term "looking" loosely though, if I come across something better I'll change it, but I'm not actively searching. I am going to get my windows re-tinted this week, so maybe I'll find something there.
    The mods are in this post, #1, and post #10.
    ________________________________________________________________________________________________
    OK, so earlier I posted about a mod to the AC controls, but I wasn't sure what I was going to do. This is a walk through of what I ended up doing.
    EDIT- For additional views of the AC control check this thread - http://www.tacomaworld.com/forum/lighting/106324-ac-controls-disassembly-pics.html
    First thing, changing the LEDs.
    Get two 3mm 3v LEDs in your chosen color for the AC and air recirculate buttons. I went with blue.
    [​IMG][​IMG]
    Completely open up the AC control until you are looking at the circuit board.
    Remove the two amber LEDs.
    Install your two new LEDs, maintaining correct polarity. The base on my LEDs had a flat side to help with this, the red backwards "D" indicates the correct way.
    I swapped one out, and then checked it in the truck to make sure I was doing it right. I would suggest doing this. You don't have to reassemble the whole thing, just the fan control knob on the left.
    -Now, if you just wanted to do the LED swap you're done. But if you want to change the color of the buttons keep going
    Now, as I'm sure you've read, the AC control face is painted on, so there isn't a way (yet) to change that color to anything other than red.
    The buttons are also painted, but....the amber paint is on the backside, which means you can strip it without touching the silver face.
    I used a Dremel to carefully, CAREFULLY take off the amber paint.
    EDIT - Aquilla1 found a safer/easier way to do it.
    Yep, that's a before and after.
    Yes, it is completely clear. Yes, you can make the buttons any color you want (providing you have a way to tint them that color.) I kept the blue theme going.
    I looked around the house and found an old binder divider with a blue tab.
    I then cut it and glued it into the back side of the buttons.
    All of this has led to this -
    The blue LEDs are sweet, but the real star it the blue backlight. It is the exact same color as the blue on the temp dial. I love it.
    I am only about half done. I still need to make the dial pointers blue, and the face backlight a deep red. The clock assembly is getting a blue makeover too. Once thats done it will be a perfect match to my cluster. I have a new radio HU on the way too so that will match as well.
    I will continue to update as I finish up the things I listed.
    Thanks!
  2. Aug 3, 2010 at 9:35 PM
    JAG
    JAG Well-Known Member
    Bump for sticky!
  3. Aug 3, 2010 at 10:05 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Sweet, added to my LED bookmarks to keep track of it for when I have a free weekend.
    Rep!
  4. Aug 3, 2010 at 10:40 PM
    Kritter
    Kritter Member
    06 4x4 SR5 crew cab long bed
    Tint, stereo, and stock size black GEAR wheels, BLHLM, tinted tail and 3rd brake light, satoshi grill mod, tactical redeployment lights under back bumper. fog light anytime mod. HID's,
    bump...
    props dude
  5. Aug 4, 2010 at 7:31 AM
    m3zy6
    Richmond, VA
    Thanks guys!
    Hopefully I can finish today, but Im not holding my breath. I still need to track down some red tint film and some blue plexi.
    Will update once there is an update.:)
  6. Aug 4, 2010 at 8:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    props man!
  7. Aug 4, 2010 at 10:33 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Nice! I totally forget how I made mine blue, but nice work!
  8. Aug 4, 2010 at 11:37 AM
    CRfofiddyF
    CRfofiddyF Well-Known Member
    AZ
    07 TRD DC 75Kmi
    Great write up! can you give the LED specs of the new ones and where you got them?
    Thanks!
  9. Aug 4, 2010 at 12:49 PM
    m3zy6
    Richmond, VA
    flightcancled pointed me in the right direction, but I was unable to fine the 3mm, 3v LEDs he suggested in my area. I found these in a local electronics place called Practical Electronics. Just look in your yellow pages and find someplace that sells individual, small electronic components and they should have some.
  10. Aug 5, 2010 at 6:59 PM
    m3zy6
    Richmond, VA
    Ok, so I had more time today to figure out the red backlight for the AC controls, and the blue changes for the clock assembly.
    I started the red backlight process first -
    I got a red see-through from Staples and cut it to fit in the back of the bezel
    This ended up not being red enough for me, so I pulled open a red sharpie and put a really thick coat of permanent red in the back of the bezel indicators.
    I then glued the clear red plastic over the red sharpie. It is hard to capture it in the pics, but its as red as the red indicator on the temperature control knob.
    I started on the clock next.
    Its kinda tricky to get out of the bracket. There are about six clips that you have to work to get it out, just be careful.
    Once you slide it out you can open it up and you'll have this -
    The face isn't held on by anything other than adhesive, just carefully pull it off. Grab some light plastic polish and a Dremel and start taking off the amber film on the back of the clock window.
    Be very patient, don't bear down or work too fast. Use a lot of the plastic polish so you don't build up too much friction. It will take quite a while, but eventually you will start making progress. It is very easy to score the plastic by rushing, so don't. This is the easiest place to mess up. Since you cant just buy the face, and the whole assembly costs about $200, it is a very expensive mistake.
    About halfway there -
    And all done -
    Now cut out a piece of your tenting material (a blue folder for me) and stick it to the back of the clock window.
    Now its time to swap out the amber passenger airbag LEDs for some blue ones.
    Get some LEDs. I used some 5mm's from Radioshack-
    I am swapping the "on" (LED2) and the "airbag" (LED4) LEDs with blue ones, and the red security (LED1) LED with a brighter red one.
    EDIT
    - The red LED in the picture ended up being dimmer than the stock one, so I switched back.
    That gives us this -
    Put it all together and it looks like this. Please keep in mind that my camera skills suck, so the colors aren't right. The AC controls are really red, and the clock isn't washed out like it is in the pics.
    UssMoGn and Tacobajasr5 like this.
  11. Aug 22, 2010 at 3:34 PM
    c.coulby
    c.coulby Well-Known Member
    Cameron
    Summerville, Georgia
    2009 TRD Sport
    the guages.. are those stock colors or did you mod them?
  12. Aug 22, 2010 at 3:50 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
  13. Aug 22, 2010 at 3:54 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    He modded them
  14. Aug 22, 2010 at 3:56 PM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    Great mod. Reps to you
  15. Aug 25, 2010 at 6:56 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    i need to do this . or you should start a service on here and do for members $$$
  16. Aug 28, 2010 at 1:20 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    what kind of rotary bit did you use for the clock?
  17. Aug 28, 2010 at 1:47 PM
    m3zy6
    Richmond, VA
    Its the standard large polishing wheel. I went with it because it gives/flexes more than the smaller ones, so your less likely to apply to much pressure.
    However, you can still mess up using this bit. I dug in slightly once, but thankfully its toward the border and not really noticeable.
  18. Aug 28, 2010 at 1:51 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    WHOOOAA...I gotta do this. Good job man!:thumbsup:
    Dmeng2112 likes this.
  19. Aug 28, 2010 at 3:34 PM
    BCTacoma
    BCTacoma Well-Known Member
    Port Hardy, BC
    06 SR5 Tacoma
    Toytec ULK, OME Dakars, Bilstein Shocks, Extended Brake Lines, 285/75/16 Duratracs, Pro Comp Steel wheels, Relentless Fab Front Bumper/Sliders
    nice. one of my next mods for sure.
  20. Aug 28, 2010 at 10:55 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
