My AC/fan blower makes a loud noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Leo2003, Dec 28, 2014.
  1. Dec 28, 2014 at 4:27 PM
    Leo2003
    Leo2003 [OP] New Member
    Yuriko
    03 SR5
    Hello everyone, I'm new to this forum.
    My 2003 tacoma has over 160,000 miles and it has been running very well. My truck has been more or less parked for the last 5 months while I was away abroad. When I came back, the truck started just fine and everything works very well, except for the AC fan blower. It barely blows air on low/medium and makes a loud noise when I turn it up to high, as if something is stuck there.
    If I am not mistaken, 2003 tacoma does not have a cabin air filter. I read a very informative post about AC blower motor repair/fix (this man's vehicle is 07). I can take a look at the motor and if it is the matter of cleaning, that would be fairly simple. But what else should I look for/at?
  2. Dec 28, 2014 at 4:39 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe the mouse is hungry. ;)
  3. Dec 28, 2014 at 5:09 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Not enough info really as far as description, but it sounds like the blower motor is not up to full speed, relay maybe? Don't know if it has a resistor set up like the older model trucks did, not matter what maker it was.
    Now if the noise is different like a rubbing, then I'd check the evap box and see if a bag or leaves have gotten into the fan and holding it back or making the rubbing noise.
  4. Dec 28, 2014 at 5:20 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    There are 4 real possibilities. The dash switch (not likely), the resistor, the relay, and the blower. Mine was having problems about 10k miles ago. The resistor/relay looked "fine" to me so I gambled on the blower and all was right with the world. It's easy, 3 screws from the bottom behind the glove box. With the blower out you can scope out the resistor and relay.
  5. Dec 28, 2014 at 5:25 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    He's joking but he may not be far off the mark. :)
    I had a mouse get stuck in the blower fan once. It can happen. If the hvac controls are left on fresh air, critters can get in. Mine made a thumping sound with the mouse.
    You access the blower fan/motor from the passenger side under the dash. It's not hard to get to, remove the bolts (I think they are tiny hex head screws) holding it in place and it will drop right out. If there is something inside you'll see it right away.
    If the noise is squealing, it's prolly bad bushings in the motor.
  6. Dec 28, 2014 at 5:46 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    check the wire at the fan, if you have 12v on high speed then the fan is bad (on slower speeds it gets less then 12v), if not run a wire to the battery and connect it to the fan to confirm it works fine, it may work but still have bad bearings that skweal or it may not be turning full speed and be overheating and stopping on you so you may have a problem with the fan and the switch so check both.
    if you don't have 12v with the fan on high then make sure it has 12v going to the switch, if it does the switch is bad, if not then run a new power wire from the fuse box to the fan switch or try to trace the wire and find and fix the bad section.
    in most cases it is the fan that goes bad, its very rare I see the switch or wiring be the problem.
  7. Dec 28, 2014 at 6:48 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Mine made noises. Changed the blower it's so quiet I can't even hear it.
  8. Dec 28, 2014 at 7:05 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Anyone got a part # for the blower or I guess whatever you need to replace the whole thing, need to get mine fixed before it starts getting hot
  9. Dec 28, 2014 at 9:55 PM
    keakar
    karl
    louisiana
  10. Dec 29, 2014 at 4:44 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    87103-04030
    8710304030
    Double check that before ordering.
    Nevin likes this.
