My AC sucks
Discussion in '1st Gen. Tacomas (1995-2004)' started by fast5speed, Jun 17, 2014.
  1. Jun 17, 2014 at 6:57 PM
    fast5speed
    fast5speed [OP] Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Hi there,
    I bought my 2000 xtracab v6 5 speed about 5 months ago. I went to turn on the A/C one day, and it didn't...
    So I went to recharge the system with one of those cans from Advance Auto. My system had zero pressure. Usually, when the system is dead, a vacuum has the be pulled, then filled with refrigerant.
    I figured I would try to charge the system anyway. I was able to pressurize it and get the compressor to engage. When the compressor engages, it bogs the motor down a slight bit (like all cars), but it blows warm air.
    The real issue is that when the A/C is on, it makes a hissing noise. I eventually figured out that the hissing noise is coming from the low pressure charging port on the A/C pipe in the engine bay that I used to charge the system. There is actually a vacuum being pulled inside the lines when the compressor is on. This vacuum is sucking the schrader valve open. I put my thumb on the valve opening and felt the vacuum.
    I find this situation incredibly odd, and I have no idea where to start.
  2. Jun 17, 2014 at 7:04 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I think you should take it to someone that has a set of gauges and a vacuum system and let them work on it. Those a/c repairman in a can with a little gauge are useless.
  3. Jun 17, 2014 at 7:06 PM
    Aw9d
    Aw9d That one guy
    ^^^ This.. take it in and have them find the leak and repair it. It happens. I had an intake rub the AC line in a Civic and it put a hole in it just big enough to loose pressure. Replaced the line, good to go.
    Good luck
  4. Jun 17, 2014 at 7:07 PM
    TheTimmyJimmy
    TheTimmyJimmy Dumbazz
    Tim
    Colorado
    04 Tacoma DBl Cab
    Lots of lil stuff
    Plugged somewhere is my guess, receiver dryer? Easy enough to pull out and check.
  5. Jun 18, 2014 at 12:17 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    +1 on the gauges. They will tell you what is, or isn't going on. That, and a vac test will give an indication on overall system health.
    Suva(r-134a) doesn't "wear out" it leaks out. Either a hole in the evap, or condenser coil, normally. A tester can tell which.
    NEVER use a product with stop leak. Nobody will ever work on it again. It clogs their refrigerant recovery machines.
