My air filter melted
Discussion in 'Performance and Tuning' started by gospurs21, Mar 29, 2012.
  1. Mar 29, 2012 at 7:56 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    No. Try hosting it on Photobucket first then post it here. It's free. Google it.
  2. Mar 30, 2012 at 10:19 AM
    gospurs21
    gospurs21 [OP] Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
    Ok actually im not too sure if it was astock one. I would guess so cause it says "this vehichle comes equipped w/ a non disposable air filter" but like i said we bought it used from a CAR LOT not a dealership
  3. Mar 30, 2012 at 10:28 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    best troll ever
  4. Mar 30, 2012 at 12:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My gas melted...... it was thick....
  5. Mar 26, 2014 at 12:36 PM
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    I know this is an old thread, but I have the same Borla reusable filter. Toyota of the South East installed these and Borla exhaust on a lot of their trucks under the XSP option. My Borla filter is also melted some around the rubber frame of the filter. Last time I checked I noticed that. I didn't remove it, but left it in, it was stuck in there basically. I'm going to replace it with a stock or a K&N filter. I think it is a manufacturing defect on the part of Borla. The engine hasn't gotten that hot, it just looks like the rubber frame is really soft.
  6. Mar 26, 2014 at 12:40 PM
    XXXX
    sKiP
    05 Prius
    PLEASE do not use K&N. Those POS filters most likely cost me a engine. See here for reference.... http://www.tacomaworld.com/forum/new-members/320505-results-drop-k-n-air-filter.html#post8363871
  7. Mar 26, 2014 at 12:46 PM
    mnerren
    Jacksonville, FL
    I'll just get a paper filter then. That's cheaper, but I got to change the more often, but probably better in the long run. Is Fram okay, I want to stop by the Auto Zone and not go to the dealership.
  8. Mar 26, 2014 at 12:50 PM
    XXXX
    sKiP
    05 Prius
    After seeing the inside of their oil filters I stopped using Fram.
    I got a 10pk of Wix online for dirt cheap.
  9. Apr 2, 2014 at 1:51 AM
    gospurs21
    Brownsville, Texas
    thank you! lol everyone thought i was trolling, i had a Borla filter as well and the rubber seal melted idk how tf but it did.. i just bought a $20 that was supposed to be a 3 month replacement but its been perfect for over 2 yrs now
  10. Apr 2, 2014 at 2:39 AM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    :eek::facepalm:
    You are the OP that keeps on giving...you may want to switch out that air filter sometime soon.
  11. Apr 3, 2014 at 12:26 AM
    gospurs21
    Brownsville, Texas
    what?
  12. May 28, 2014 at 1:39 AM
    06texasedition
    06texasedition Well-Known Member
    Picayune ms
    06 Tacoma Texas edition(RIP) 14 tundra limited 4x4
    3" rough country lift. Blue interior lights courtesy of jumper led. Led tail lights avid front and rear bumper guard with 4 Hellas on front. Borla dual exhaust blue led reverse lights color matched satoshi grille
    Which filter did u buy because I noticed this on my Texas edition also
