My alignment after mounting 285s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ben96, Mar 9, 2020.
  1. Mar 9, 2020 at 2:58 PM
    Ben96
    Ben96 [OP] Well-Known Member
    2014 Tacoma Sr5
    2.5in billstein 5100’s 1in rear block
    Personally I didn’t seem to think there was any significant uneven wear‍
  2. Mar 9, 2020 at 3:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    All you mention is having tires mounted.
    That will not affect an alignment.
    The hubs are what are aligned; an alignment an be done with no wheels/tires on the vehicle.
  3. Mar 9, 2020 at 3:03 PM
    Ben96
    2014 Tacoma Sr5
    New wheels and larger tires
  4. Mar 9, 2020 at 3:13 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Id
    idiots!!! Truly idiots!!!
  5. Mar 9, 2020 at 8:39 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    bookmarked
    will.i.was[QUOTED] likes this.
  6. Apr 15, 2020 at 6:01 PM
    Jacked Burton
    I just ordered some OME887s and Freedom Offroad UCAs.
    Once I get them put on next week are those same instructions that I should be telling the guys at Tire Discounters when I go in to get it aligned?
    I bought a 5 year alignment from Tire Discounters when I got the 265/75/16s AT3 4Ss Christmas of 18'.
    Thanks
  7. Apr 15, 2020 at 6:05 PM
    gotoman1969
    Do the ucas have built in caster or adjustable caster settings?
  8. Apr 15, 2020 at 6:17 PM
    gotoman1969
    Yep. Jba sells a set of ucas that have no caster simply replacement ucas.
    b_r_o[QUOTED] likes this.
  9. Apr 15, 2020 at 6:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're right, dumb question
  10. Apr 15, 2020 at 6:19 PM
    gotoman1969
    Let’s blame on the Covid it’s making us all crazy.
  11. Apr 15, 2020 at 6:21 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    So I basically had the same issue. Went to 285 had cab mount chop with 1.75" suspension lift. No rub.
    The steering wheel shakes at like 55-60 mph and seems to jerk more when I go over things. Installed front bumper last weekend which caused it to lower about 1". No rub with OEM, but still get shakes.
    Installed UCA Friday and now it is rubbing a bit of plastic when turned and compressed, however, it solved the issue of the sketchy steering wheel. Of course, the rubbing is probably because of the 1" lost when installing the front bumper and I believe UCA stance moved the tire a bit to the rear.
    I have suspension coming in about 3 weeks and will do alignment as well. From what I am researching, you need to be between 3-4 degrees of caster with a 285 setup for aftermarket UCA.
  12. Apr 15, 2020 at 7:01 PM
    Jacked Burton
  13. Apr 15, 2020 at 7:06 PM
    gotoman1969
    Jacked Burton[QUOTED] likes this.
  14. Apr 16, 2020 at 5:50 PM
    06 taco 4x4
    06 taco 4x4 New Member
    2006 silver TRD sport tacoma
    Light bar Level kit Spyder halo ccfl headlights Cali Raised fog conversion-2x2 pods
    Preferred manufac. spec for individual toe is .05. Slightly more toed in (.06-.07) helps with road crown which wants to push/toe out your wheels. So your slightly toed out (still within spec just not preferred spec) which if anything would cause inside shoulder wear or a drift or pull. Your cross camber (difference between camber on front left and front right) isn’t terrible but too much can cause a drift or pull as well. Caster is low as others have said which will cause wandering and little steering wheel return. And then your thrust angle could create a dog-tow effect which will feel like a pull (although it’s a solid rear so not much you can do about that). Honestly isn’t the best alignment.. not terrible but I wouldn’t send that out unless under certain circumstances. Such circumstances as it could be caused if you off-road hard or have hit something and tweaked something. It can make it quite difficult/near impossible to get the vehicle back to perfect specs without additional camber/caster kits or control arms. Also might be worth considering taking to another alignment guy and seeing if the readings match what your guy is giving you. Hope this helps as the way your truck handles could be life or death.
  15. Apr 16, 2020 at 8:40 PM
    #35
    Taco'09
    Taco'09 Well-Known Member
    Permit me to translate: you were just blown off.
    The post above stating it was a toe and go is correct and you have just joined the many who have found yet another lazy or incompetent alignment shop. I would not spend any more time with this place. Find another. All that will likely happen is that your frustration level will escalate. They may have even tried to adjust camber/caster but quickly discovered the infamous frozen cams common on the and gave up.
  16. Apr 16, 2020 at 9:14 PM
    #36
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Is he stock or lifted? 4 degrees of caster while keeping everything else in spec with stock UCA is almost impossible with or without a lift.
  17. Apr 17, 2020 at 7:02 AM
    #37
    gotoman1969
    I’m going lifted since he has 285s , correct if he doesn’t have aftermarket ucas 4* won’t be possible
  18. Apr 17, 2020 at 7:55 AM
    #38
    Sharpish
    Brian
    I’ve got a 1.75” lift (TRD PRO coil overs) and Factory UCA and I was able to manage around 2.4 caster at the expense of a smidge of negative camber. It tracks and drives perfectly IMO.
    If you want 0 camber you’re going to be limited to below 2 caster with a 2” lift. If your lift is more than 2” you’ll be limited even more.
    If you’re rocking a 3” lift or something similar and 285’s, an aftermarket UCA will let you get 4 caster and it will drive very nicely.
