My alignment specs after 3'' lift, what do you think?
Discussion in 'Suspension' started by Eduskator, Sep 10, 2014.
  1. Sep 10, 2014 at 7:08 AM
    Eduskator
    Eduskator [OP] Well-Known Member
    La Belle Province
    '14 Tacoma
    Hi, just got my truck aligned after a 3'' lift install.
    Here are the final numbers :
    He aligned it with the 2011 specs, because he didn't have the 2014, but I don't think they changed that much...?
    What do you guys think? I think it's pretty damn straight. According to what I read, these numbers are withing the specified range. Mecanic said : when it's green, it's good.
  2. Sep 10, 2014 at 7:49 AM
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    Caster is too low. Toe/Camber should be 0
  3. Sep 10, 2014 at 7:58 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Need that caster up at 3*
  4. Sep 10, 2014 at 8:14 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    Why 3 degrees? I need more than Toyota suggest because of the lift?
  5. Sep 10, 2014 at 8:16 AM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    im guessing OP doesn't have UCA's to correct his alignment.
  6. Sep 10, 2014 at 8:21 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    Nah, still on stock everything. My truck is brand new and I didn't want to void my warranty by changing parts. The Toyota dealer told me a body lift would not void it because it was only blocks between susp.
    Still, the OEM specs accepts 1.2 degrees of caster...
  7. Sep 10, 2014 at 8:23 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Yes.
    NEVER set your truck up to stock specs with a lift.
  8. Sep 10, 2014 at 8:25 AM
    XXXX
    sKiP
    05 Prius
    Those two statements couldn't be more wrong.
    Swapping shocks will not void your warranty if done right.
    Adding spacers is the worst thing you could do to a trucks suspension IMHO.
  9. Sep 10, 2014 at 8:28 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    I didn't ask whether or not lifting with blocks was good... I'm aware of all this...
    Factory specs for caster : 1 to 2.5.
    I guess you need more when you're lifted?
  10. Sep 10, 2014 at 8:29 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    Thank you! :) I'll check to see if they can improve the caster... But I doubt since I don't have aftermarket UCAs.
  11. Sep 10, 2014 at 9:10 AM
    XXXX
    sKiP
    05 Prius
    I was just stating this because the dealer is 100% incorrect.
    If it drives good and you like it....don't worry until the next alignment. Next alignment try and have the caster bumper up.
  12. Sep 10, 2014 at 10:21 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    Sounds good :)
    I'll try it after work and see how it handles. I know bad caster can make the truck drive like crap.
  13. Sep 10, 2014 at 10:34 PM
    Sikyota805
    Sikyota805 Member
    Derrik
    Pismo Beach
    96 dirtdesign tacoma
    Dirt designs long travel kit up front, ford 9" rear, fiberwerx glass f67deavers
    Low caster won't affect much now negative caster is bad. And toe is alright most of the gm vehicles I do at work at either 0.0-0.2 total depending if fwd or rwd
  14. Sep 11, 2014 at 6:17 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    Thank you! Yes, numbers are within the accepted OEM specs, even though caster could have been better but I have no UCAs to correct this... That's all that counts I guess :)
  15. Sep 11, 2014 at 6:28 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Until you go to fit bigger tires...
  16. Sep 11, 2014 at 6:34 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    What UCA's are you going with? I'll have some LR's available soon but they'll need new BJs.
  17. Sep 11, 2014 at 6:47 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Wise decision. I have the LR UCA's. I am giving them a second go only because they replaced them under warranty.
  18. Sep 11, 2014 at 9:23 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    :thumbsup: I understand!
  19. Sep 11, 2014 at 6:54 PM
    ckeene9
    Chesterfield, VA
    See Build Thread
    33's and 35's
    It helps push the tire away from the firewall.
