my automaic changes gears hard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJ5685, Jan 4, 2012.
  1. Jan 4, 2012 at 5:38 PM
    JJ5685
    JJ5685 [OP] Well-Known Member
    NC
    08 TRD Off Road v6 sr5 4X4
    pioneer stereo, 10" rockford fosgate punchgate sub, custom box, bull bar, custom trd decals
    I got a automatic and recently it will jerk a little when changing gears. Could this be because it fairly cold here about 25 degrees in the mornings? Or need to change transmission fluid? I don't drive it hard
  2. Jan 5, 2012 at 10:06 PM
    06TRDpre
    06TRDpre New Member
    California
    06 Prerunner TRD
    Same problem here. Clunking down 5 secs after coming to a stop as well. Sometimes my (automatic) transmission even provides 'breaking' (after downshifting into 3rd, I think) while coasting. Not always though, but most of the time. Wonder if a tranny flush will suffice. What? Me worry! Other than that it an awesome truck.
    Hope you get some answers I can use as well.
  3. Jan 5, 2012 at 10:36 PM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Try using manual mode. This increases pressure lines in the tranny. If it doesn't shift hard, I wouldn't worry about it. Cold trans fluid is really thick. Transmission needs to heat up before it operates properly. Unless your towing something, it takes a LONG time for it to even Get warm. Double check your trans fluid too.
  4. Jan 5, 2012 at 10:40 PM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    shit, there is this stuff u can put in ur tranny to make it smoother but i forget what its called at the moment. it works wonders, made my ol 99 tranny feel like new
  5. Jan 5, 2012 at 11:05 PM
    AlaskanTaco
    Anchorage Alaska
    That stuff is HORRIBLE for transmissions. Does nothing but, gum up your seals. Yeah it works....for now! But pretty much destroys your tranny in the long run. Double check your fluid. If your fluid is low, the pump keeps increasing pressure until it MAKES the tranny shift! (hard shift). That and being cold
  6. Jan 7, 2012 at 4:13 AM
    AlaskanTaco
    Anchorage Alaska
  7. Jan 7, 2012 at 12:08 PM
    JJ5685
    NC
    I don't know how to check the trans fluid. It said there is a plug that you fill it to. But today was alot warmer and it did better. How often do you change the fluid. My truck has almost 55000 miles and I bought it at 49k,irk if its been changed yet I read every 30k and 60k to change it.
  8. Jan 8, 2012 at 4:20 AM
    Goldstar225
    Goldstar225 Well-Known Member
    Tom
    Central Arkansas
    2011 Pre-runner SR5 4X2
    I have just under 5,000 on my 2011. The other morning while leaving my house at 17 degrees my transmission gave a jolt when changing gears. Normally it's smooth as silk. After driving about a mile it smoothed back out. I'm inclined to think it was because of the cold transmission fluid. My '98 Silverado would not engage overdrive a cold mornings until it had been drived 1 1/2 - 2 miles.
  9. Jan 25, 2012 at 6:25 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I believe auto tranny fluid is good for life or like 100,000 miles
  10. Jan 25, 2012 at 7:25 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Make sure the fluid level is topped off and you might check your u-joints
  11. Jan 25, 2012 at 7:35 PM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    I have had the same issues since we reached freezing temperatures here. Even after an hour of driving.
  12. Jan 26, 2012 at 6:39 AM
    2011whitetaco
    2011whitetaco Active Member
    Ontario, Canada
    '11 White SR5
    I have a brand new Taco, 1,200kms. It shifted hard the day I picked it up from the dealer but once it warmed up it was fine. Still get the odd clunk a few seconds after stopping.
  13. Jan 26, 2012 at 7:13 AM
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    Sounds like this is a commom thing.
  14. Jan 26, 2012 at 11:49 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    mine auto shifts hard from 1-2 intermittently at light throttle. It has always been like that. One of these days I will have the dealer check it out.
  15. Jan 29, 2012 at 2:30 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
  16. Jan 29, 2012 at 3:09 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    It depends what you read. I think Toyota recommends every 60,000 if you tow/100,000 if not or every 6 years...whatever comes first. According to the Chilton's manual it's every 30,000 or 24 months. Take your pick.
  17. Jan 29, 2012 at 5:26 PM
    TnShooter
    TnShooter Well-Known Member
    07' TRD Off-Road, Auto
    STOCK
    You are not alone. Right after I got mine, I tried to check the transmission fluid.
    I looked all over for the the friggin' dip stick. Well there isn't one. I called Toyota and asked how to check it. They gave me a generic answer of "It's fine until 100,000 miles. I even asked them to check it, but they said it would take 3 hours for the fluid to cool and warm or something.
    Mine does the Auto Engine brake as well. Well, not really. It actually down shifts and fells like an engine brake. It also clanks when you are pressing the brake and change gears. I finally figured it out(thanks to this forum), and it's the brake pads. That is normal as well. And unless you want to change the brakes that still have 1/2 the pad left then you just live with it.
    I will say, TOYOTA QUALITY has gone DOWN with the Gen 2 models.
    My old 96, 98, and 99 were better trucks.
  18. Jan 29, 2012 at 6:11 PM
    hamsterhater
    hamsterhater Well-Known Member
    long island
    11' dc mag grey taco
    level kit- exhaust -cai n-fab light bar-4 piaa 6"new hood w/scoop
    definitly common with cold.bought mine in summer first cold day or two and shifted different.i would worry as long as fluid is full. if you want you could unplug battery and reconect to make computer to learn how to shift again which doesnt hurt anything. just has to relearn itself if it went off a little.
  19. Jan 29, 2012 at 8:22 PM
    NMTrailRider
    New Mexico
    yeah, i liked my 98 much better than my 2nd gen. i do like the upgrade to the double cab, though. the braking issue is normal, as someone already said. i actually like it... i am guessing that the reason for it is so you don't have to ride the break on hills with an auto transmition (or downshift, which would be a pain in the a..)
  20. Jan 30, 2012 at 4:40 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    That's prolly it...
    But FWIW harder shifts are (generally) better for transmission life. Soft shifts means the clutches slip and slipping clutches means they wear out sooner. Wear gets much worse when you're towing.
    If you feel the urge to change transmission fluid be sure to use the Toyota ATF-WS. Using something different can change shift feel.
