My Auxiliary Backup Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by griffin407c, Dec 1, 2009.
  1. Dec 1, 2009 at 6:10 PM
    griffin407c
    griffin407c [OP] Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    So, I've had a couple ppl ask me bout my backup lights so I figured I would make a little write-up.
    I decided to use the Hella FF50 Fog Lights (55watt). I wanted a short, wide beam so I opted for the fog lights. I also used the FF50 because they are stylish and the lights are exposed because they are mounted to the OEM trailer hitch. The lights came with black wire, but no colored wire. So, I went to Napa and bought a bunch of different colored wire. I always have relays on hand so I used one of my 30/40amp relays and wired it all up.
    Before mounting the lights, I had removed the trailer hitch and sanded, prepped, and undercoated the entire thing. I mounted the lights to the trailer hitch using the supplied brackets and using self-tapping screws. (Don't mind the horrible upstate ny rusted frame. it's being taken care off.)
    I ran the right-side wires through the trailer hitch main tube and then connected them to the wires on the left-side. All wires were ran in wire loom. The wires were then ran up the frame. The ground wire was grounded to the frame and the power wire was ran up into the truck through one of the rubber grommets, along the driver-side kick panel, through the firewall, and into the engine bay.
    Here's a rough idea for the wiring.
    I wanted to use an OEM fog light switch to keep the install clean and wanted the lights to come on in reverse and independently when I pushed the switch to the ON position. The diode is inline to prevent the ignition source power from turning the OEM reverse lights on when I want to independently turn the Auxiliary backup lights on.
    Here's a pic of the OEM fog light switch and it's placement.
    Here's a pic of the auxiliary fuse panel that I wired the relay to.
    While I was at it, I modified the OEM backup lights and replaced the bulb with a 55watt 886 bulb. I have had no issues with this bulb getting to hot and it has helped greatly, especially because of my tinted tails.
    Comparison between stock and 886 bulb (886 on right).
    Cut just above the brown plastic, with a dremel. DO NOT touch the bulb (it's a halogen bulb).
    When placing the bulb into the socket, I wore rubber gloves and used several tissues to hold the bulb and press it into the socket. I have had absolutely no problem with these bulbs for months now.
    Here's a pic of the tinted tail with the 886 bulb.
    Here's pics of the 886 bulb, the 55watt auxiliary backup lights and their pattern.
    Here's a pic of just the auxiliary lights.
    A few more shots.
    I know that night shots and lighting shots are hard to depict in pictures, but adding both sets off lights has helped me out greatly. The lights also help with the image for my back up camera. I've used the auxiliary lights for hooking up to a trailer at night, when in park. I like to turn the auxiliary lights on when someone is driving on my ass at night. I know, I know, it's wrong to do, but you should see how quickly they back off and stay back.
    I plan on adding another set of these lights in the neat future. Similar to Pb's backup lights that are mounted underneath the front doors. These lights will be wired to turn on with reverse gear, independently from ignition power, and wired to the dome light so when the key fob is pressed (or the doors are open), the lights will come on with the dome light and illuminate below the doors at night.
  2. Dec 1, 2009 at 6:49 PM
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    Very cool. Looks great.
    GA
  3. Dec 1, 2009 at 7:02 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dude sweet i just did something just like that... i will post pics soon
  4. Dec 1, 2009 at 7:24 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    sweet!
  5. Dec 2, 2009 at 3:49 PM
    dalesrn
    dalesrn Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    That looks great.
  6. Dec 2, 2009 at 3:50 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    very nice! I will be copying this in the Spring
  7. Dec 2, 2009 at 7:25 PM
    Taco Ron
    Taco Ron Male Member
    Very nice man. I think I'm going to need to do something similar. I can't see out of the back of mine at all with the camper shell (dark tint) and tinted tail lights.
  8. Dec 2, 2009 at 7:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    awesome mod, man!!! i gotta do rock lights and backup lights before too long.
  9. Dec 2, 2009 at 9:39 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Superb! +1 Reps sent. :thumbsup:
    In your fuseblock photo, I see a label for a power inverter. That's an aftermarket inverter right? I ask this b'cause I was considering relanding my factory inverter ( I have on '09) onto a aux fuse block / aux battery.
    What kind of fuse block did you use?
    Also when you use your digital camera for very close up photos, activate the "macro" feature on the camera, its the icon that looks like a flower.
  10. Dec 2, 2009 at 11:15 PM
    griffin407c
    Upstate NY
    yes, it's an aftermarket 800 watt power inverter. i would recommend buying an aftermarket inverter if you want to run something that requires more juice than the stock inverter (which isn't a lot). If you're not looking to run much, but want AC power in the cab, follow these two threads.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/25944-110v-factory-inverter-always-400w.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/25900-cab-110-ac-outlets-option-2-a.html
    The auxiliary fuse panel is blue sea systems fuse panel with negative buses. They offer the panel in a 6 slot or 12 slot configuration with or without negative buses. I recommend buying the panel with negative buses, but each to his own.
  11. Dec 2, 2009 at 11:19 PM
    griffin407c
    Upstate NY
    thanks for all the comments guys!
  12. Feb 4, 2010 at 1:09 PM
    camiliosalomanda
    camiliosalomanda Well-Known Member
    McKinney, Texas
    Super White
    Grill Craft Hella 500 Bed Aux Wet Okole Wet Okole Arm Rests Weather Tech Magnaflow OS Ram Night Breakers Rocky Mounts Custom IPOD Dock Pioneer AVH P4100 Relentless Sliders AnBCustomFab Bed Rack 3 Inch Icon Lift with leaf pack
    I did the same thing you did minus the diode and used my Hella 500ff from behind my grill.
    Also bought the rectangular Hella550FF and mounted them to the side of the frame underneath the passenger and driver side for side viewing while wheeling in the dark.
    I offroad a lot and the hellas didnt help behind my grill at all so they went to the back.
    Also i dont know if you guys can get OSRAM Nightbreakers in the states but they are by far the best bulb i have used. I run them in my Hellas and also my headlamps.
    I will post pics soon
    Good stuff man I love lights.
  13. Feb 4, 2010 at 1:19 PM
    Capita
    Thats for the awesome post and pics. I'll be doing this when the weather gets better.
    positive Reputation added
  14. Feb 4, 2010 at 1:29 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Nice write up with lots of pics! pics are always nice:D
    But just be careful with those new lights. I have busted 2 diferent sets of aux backup lights that i had mounted under my bumper in that same area. Thats why I built a bed bar with lights on it..
  15. Feb 4, 2010 at 9:08 PM
    griffin407c
    Upstate NY
    i don't off-road or anything so i'm sure i'll be alright. i've had them i think for almost a year now. no problems
  16. Feb 5, 2010 at 5:02 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    they should A okay then! :thumbsup:
  17. Feb 5, 2010 at 5:15 AM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    those are sweet. nice job. they look hella useful
  18. Feb 5, 2010 at 5:21 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Great job and very cool.
    Can you point them up a bit so that when some smarta$$ decides to ride your bumper you can aim them right into their face? Just kidding...
  19. Feb 22, 2010 at 10:36 AM
    SMOKED DC TACO
    SMOKED DC TACO Active Member
    Brad
    North Carolina
    2006 taco tinted smoke lights lift
    smoke tail lights, jdm fog lights, hids, 3 in lift, 20% front tint 1.3 % rear, 33" bfg km2
    do you know of any aux. backup lights that have a blue tint when turned on?
  20. Jan 25, 2014 at 2:33 PM
    Poolstick
    Poolstick Well-Known Member
    What size diode did you use for this? Having a hard time figuring out how diodes are rated.
