My Battery Exploded tonight! PICS!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Traveler, Nov 17, 2012.
  1. Nov 17, 2012 at 11:43 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I just replaced mine at 96,960miles.. Alas can't afford AGM, went with a Adavnce Auto one.
    OP check out Advance Auto online if you are just getting a wet cell battery. Picked mine up for 110.99 - $40 'A124' - $25 rebate. Use the link through Fatwallet for cash back and pick up in store.
  2. Nov 17, 2012 at 11:51 AM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Thanks guys just picked up a Duralast Gold from autozone. Total after core charge refund was $116 with 3 year warranty. Truck is running perfectly.
  3. Nov 17, 2012 at 11:53 AM
    The Traveler
    SoCal
    For the record, every wire hooked up to the battery is fused or relayed .just need to be loomed up.
  4. Nov 17, 2012 at 11:53 AM
    theboy12
    theboy12 The Answer is 42, But What is the Question?
    Jon
    Redding, CA
    2005 Tacoma TRD Sport DCLB
    King 2.5 Remote Resi'sand rear 2.0s, Dakar Pack, TRD 1st Gen air intake, Stealth 6's wraped in DynaPro ATms 285/70R17s, SnugTop, ALL Pro Front bumper, Brute Fab HC Rear Bumper, Hella Black Magic Lights, Bedslide 1000
    If you have the cash and like mud, get a sealed battery, so you don't have to worry about the vents getting clogged like that. Get that acid taken care of soon brother, or you'll have a host of other electrical problems.
    Best of luck, sucks you got stuck in town, been there before.
    -Jon
  5. Nov 17, 2012 at 12:01 PM
    JayDirt
    JayDirt I owe it all to little chocolate donuts
    The tale of Fiona continues...Matt, take that thing back and get a sealed battery...just my .02
  6. Nov 17, 2012 at 12:02 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Good to hear the truck's running fine... now get that engine bay cleaned up. :) On a side note... how's the cat doing?
  7. Nov 17, 2012 at 12:12 PM
    The Traveler
    SoCal
    I think I've dealt with enough mud related problems to never go mudding again. I got start taking it easy on this thing. Thanks for the input fellas
  8. Nov 17, 2012 at 12:14 PM
    The Traveler
    SoCal
    And Ramsey is doing great! :D he woke me up this morning by smacking me in the face open-paw
  9. Nov 17, 2012 at 12:16 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    make sureyou neutralize the acid, dont want to let it sit in that engine bay too long
  10. Nov 17, 2012 at 12:18 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Red top!!
  11. Nov 17, 2012 at 12:20 PM
    The Traveler
    SoCal
    I wiped off the spot where the acid was with a towel covered in baking soda to neutralize, waited until it stoppe bubbling, hit it one more time, no bubbles just powder. Then I wiped down the area with simple green, and pressure soap and washed the entire engine bay with the truck running.
    My usual routine minus the baking soda.
  12. Nov 17, 2012 at 12:29 PM
    JaimeSR5
    JaimeSR5 Well-Known Member
    Jaime
    Fontana
    03 PreRunner-4Banger
    K&N filter,-JDM tailights, NGK Spark Plugs, 6k H.I.D head light kit, fog light kit
    the main reason that your battery cap and acid came off its because you turned your vehicle off at the red light and tried to turn it back on as soon as you turned it off creating a physics thing making your cap pop off with all the gases and it forces your cap to blow along with the acid, it happened to me not too long ago, my ex tried to turn my truck on and I had the hood open, the cap popped off and some of it got on my hand but i washed it off as soon as it happened, water neutrilizes acid and irish springs hand soap hahahahaaaa
    but yeah try to avoid that turn off your vehicle and turn back on quickly cause it will happen everytime, best to wait on it for a minute or two then having a battery explosion lol
  13. Nov 17, 2012 at 12:36 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Use baking soda
  14. Nov 17, 2012 at 1:32 PM
    The Traveler
    SoCal
    Yup. Exactly what I did.
  15. Nov 17, 2012 at 2:57 PM
    #35
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Batteries can lose connections inside of them and arc the cap being blown off from pressure would not have put a dent in your hood it exploded inside. Hydrogen is extremely explosive some thing went wrong inside of the battery that's why your lights dimmed. Dealing with the acid later then sooner will probably leave stains you'll never get rid of.
  16. Nov 18, 2012 at 6:41 AM
    #36
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I agree with Bill. Clogging the vent hole in the cap will cause a build up of hydrogen gas pressure.
    Hydrogen is produced when a wet lead-acid battery is charged due to the electrolysis of the water in the electrolyte. Hydrogen gas can violently ignite when the concentration exceeds 4%. [This is why ventilation and wearing glasses is so important when recharging wet lead-acid batteries.] I have seen dozens of pictures of battery explosions and have had first hand experience with one. Your incident appears to be consistent with a single press on cap cell ignition because screw on caps normally cause major battery case damage when the hydrogen is ignited. If the electrolyte level was low in that cell, the most probable cause was a short from low resistance "treeing" between plates. If it were my battery, I would perform preventive maintenance on the battery, test it for latent damage, and ensure that I periodically added distilled water to the cells when required.
    For more information about battery explosions, please see Section 14.3 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
