My battery light just came on in my 4 cylinder 2005? Starts and runs fine. Any sugges
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Happy valley guy, Jun 4, 2012.
  1. Jun 4, 2012 at 6:32 AM
    Happy valley guy
    Happy valley guy [OP] New Member
    Northampton ma
    05 2wd
    My battery light just came on in my 2005 4 cylinder Tacoma. Any suggestions? Starts and runs fine. Belt on.
  2. Jun 4, 2012 at 6:34 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Time for a new battery? They usually last about 5 to 6 years before they no longer can hold a charge.
  3. Jun 4, 2012 at 6:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    The battery light indicates that the alternator is no longer functioning. Take it to a local parts store like Advanced or Napa. They offer free testing. You could also have a loose battery connection.
  4. Jun 4, 2012 at 7:22 AM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Advanced auto? lol..
    Take it to a professional Toyota Tech - give that truck some love!
  5. Jun 4, 2012 at 7:49 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Ya your alternator prob died. First though check your battery connections to make sure they aren't loose or corroded. If not, measure the voltage with truck running. If it isn't over 13.5 volts (ideally closer to 14 or more) then your alternator is likely toast and you're running on your battery alone.
    GL!
  6. Jun 4, 2012 at 7:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    Why pay out the ass when you can get it done for free? You can do it yourself if you have a multi-meter.
  7. Jun 4, 2012 at 7:54 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Because the kids at the Toyota dealership know best......... silly moderator :rolleyes:
  8. Jun 4, 2012 at 7:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    :laughing:
  9. Jun 4, 2012 at 8:00 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Been a member since 2008, you should know better
    ^This
  10. Jun 4, 2012 at 8:14 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    For a alternator or battery? If you go to the dealer bring 2 things...plenty of money and a good supply of lube. :eek:
  11. Jun 4, 2012 at 9:30 AM
    pauldotcom
    Paul
    MA
    I was a Toyota Master Tech and did HONEST work. The pro's get paid for a reason; because they are good at what they do.
    I am all for do-it-yourself labor, but if you have to ask what to do when an alternator light comes on, it's over your head.
    Suggesting Advanced Auto to even breath on your truck is simply ridiculous.
  12. Jun 4, 2012 at 9:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    ...not as ridiculous as paying $90 for a 5 minute job
  13. Jun 4, 2012 at 9:51 AM
    XXXX
    sKiP
    05 Prius
    FTFY
    Anyone can hook up an multi meter even if they don't know what an alternator is. We can walk OP through this simple test without him wasting $90 and hours of his time let alone break down on his way to the dealership.
  14. Jun 4, 2012 at 3:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The only good way to test the battery and charging system is with a load tester. A multimeter will give you a voltage reading, but doesn't supply the load test. There is nothing wrong with Advance Auto or the dealer testing. Your truck your choice.
  15. Jun 4, 2012 at 3:51 PM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    im with the ppl for the local autozone free testing, there, as suppose to the same test at a dealership kinda no brainer
  16. Jun 4, 2012 at 3:52 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    It's recommended you replace your battery annually, though nobody does it.
  17. Jun 4, 2012 at 7:33 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Really? News to me.
  18. Jun 4, 2012 at 8:41 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Agreed.
    I'm an appliance repair tech. Every day it's the same sad song...."WTF, I could have bought that part on Ebay for 1/3 what you charge and put it in myself. It's only ten screws!"
    I always respond the same way...something like this:"Yes sir, I don't doubt that you could do that, but you didn't, you hired me to do it for you. If you want me to do it for you, you have to pay for the training I have invested in to learn how to do this quickly, accurately, and be able to stand behind my diagnosis and warranty my work. You have to pay for my expenses to maintain an office, dispatcher, parts inventory, liability insurance, a running service vehicle, etc."
    The reality is that some folks know how to do things themselves and save a ton of money. Good for them. Then there are folks that are willing to learn. That's good for them if they have the patience and money to spend to screw up a few times and learn from their mistakes. The rest of the folks are better off in the long run spending the money for a proper diagnosis and repair that comes with a guarantee.
    And yes, I know there are dishonest, incompetent people in the automotive business, and in the appliance repair business. There are also dishonest, incompetent people in the real estate business, there are dishonest doctors and lawyers too.
    As far as cars go, either learn to be completely self sufficient and do every single thing yourself, or find someone you can trust and build a relationship with them, it will pay off someday when you are over your head and need your vehicle fixed so you can get yourself to work the next day.
    OP, I have worked autoparts before. The charging system tests that the parts stores offer for free are a quick way to rule out a simple battery problem and identify if the alternator is charging or not. But be aware, if you take the truck to a shop afterwards and tell them to change the alternator and not to charge you for a diagnosis, then they will do just that. If you are wrong, and there is something else wrong, you are stuck with the parts and labor to install that alternator. Pay the diagnostic, then it's the shop's problem if they are wrong.
  19. Jun 4, 2012 at 9:08 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Well said, I can't count how many times a vehicle has come in where the customer has "diagnosed" the problem them self and want us to change parts. Most of them are not very happy when they get billed labour and their vehicle still has the same problem. My favorite is "I read on a forum.."
  20. Jun 5, 2012 at 3:55 AM
    pauldotcom
    Paul
    MA
    The solution is to find a GOOD RELIABLE technician. Yes, there is way more to a charging system test than testing the output voltage!
    Current under a load, regulator voltage, voltage drop testing, and oscilliscope testing for ripples needs to be done also in order to properly determine the issue.
