My bed is loose
Discussion in '1st Gen. Tacomas (1995-2004)' started by VirginiaBound, Jan 13, 2010.
  1. Jan 13, 2010 at 6:58 AM
    VirginiaBound
    VirginiaBound [OP] Whyareyoureadingthis?
    Sam I am, green eggs and ham
    North of Maine, South of Spain
    I have noticed my bed will wiggle a little bit when going over bumps, and it seems to be loose. Its gotten worse and I need to fix whatever is going on under there.
    Where are the bolts at on a 99ext cab at? I cant find them lol I cant physically get the bed to shake while the truck is parked so I dont think its like about to fall or anything, it just very lightly shakes and wiggles when I hit bumps or go offroad and it didnt do that before.
    Is it normal for bolts to come loose over time or do you think that something could be broken/rusted.
    Thanks guys
  2. Jan 13, 2010 at 7:15 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    depends how badit is but this is something called bed shake i think. its normal, unless you just startedin that case its getting worse. find a set of body lift install instructions for your truck, that will help you findthe bolts. also check the bushingthey might be bad.
  3. Jan 13, 2010 at 7:31 AM
    VirginiaBound
    Ok Ill try to find some body lift instructions. It has done it a little bit the entire time owning the truck, and my old Chevy did it also so I think thats just normal shake. But it seems to be noticeably worse and I want to make sure something is broken. It probably is just bolts I need to tighten down. Ill try to find the layout for the bolts and see if I cant get them tightened down.
  4. Jan 13, 2010 at 7:50 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Bushing????
    your bed has 6 bolts holding it on. They are all accessible from under the truck. The bolts go up through the frame mounts and into the cross bracing of the bed. There are 2 at the front, 2 right at the axle area and 2 in the rear... basically 3 down each side. I just took my bed off, and I can't remember for sure.. but the bolts are either 14mm or 17mm heads. There are no bushings on mine, and I don't see any way there could be some because then the bed and cab body lines would not match up. The metal cross brace of the bed sits right against the frame.
    Get you a 1/2" ratchet, 12" extension, and a socket.
    If you can't get any movement from the bed by hand... I would look under it at the cross bracings and see if they are rusted.
  5. Jan 13, 2010 at 12:36 PM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    bushings...yes the truck doesnt sit metal to metal does it? as in cab or bed to frame. mine has little thin bushings in between.
  6. Jan 13, 2010 at 1:35 PM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    My truck has cab bushings, but not bed. and the bed - cab body lines match. I will have to look at some others, maybe I am wrong, but I don't see how their could be bushing unless they are 1/16" thick or less.
  7. Jan 13, 2010 at 2:18 PM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    idk i could be wrong too but i was sure i saw bushings under mine.
  8. May 6, 2010 at 12:33 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I also have big bed bushings :D
  9. May 6, 2010 at 3:36 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Haul smaller women?????:notsure:
    Just check the bolts and body mounts.
  10. May 6, 2010 at 3:37 PM
    VirginiaBound
    This thread is fairly old, it ended up being the bolts. I had checked them once but apparantly they have to be Mr. T Rambo tight to hold the bed down good. :D
    And I keep telling your mother to loose weight I swear shes gonna be the death of my truck!
  11. May 6, 2010 at 3:43 PM
    Afwrestler1986
    Johnstown, NY
    She won't listen to anyone anyhow. Good on ya for trying though man.
  12. May 6, 2010 at 3:45 PM
    VirginiaBound
    Yeah my sister is the same freaking way, I ended up breaking up with her last month, a pure pain in my ass!
  13. May 6, 2010 at 5:47 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    The bolt on the right side of my bed is loose...I can't tighten it up or take it out...The bed makes a lot o noise :(
  14. May 8, 2010 at 8:37 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    So apparently the bolt is stripped...I have to take it in to a body shop and they have to remove the bed :( $125
  15. May 9, 2010 at 7:12 PM
    2000yota
    2000yota Toyota FTW
    Garrett
    Hernando, MS
    2006 TRD Sport
    check on em when you find the bolts asap my dad had a 00 tacoma with 6 inch lift. it rode so rough that one day goin down the road the bed fell off!
