My bed mounting channels are bending. Anyone else experience this? Any fix?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LOTR_is_awesome, Oct 16, 2023.
  1. Oct 16, 2023 at 10:35 AM
    Spanky3412
    Spanky3412 Well-Known Member
    Dave
    Northern N.J.
    2020 Cement Offroad
    ^^^This! Looks to me like the mounting brackets are bending the rail up.
    soundman98 and GeorgiaTacoJM like this.
  2. Oct 16, 2023 at 10:36 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    i just watched the install video for the ibex and those 2 bolts attach the mount to the rack. there is another bolt that goes down from the top that connects the rack mount to the bed rail mount. the video says tighten to 30 Newton meters. maybe he does need to move those closer to where the bed rail screws into the bed side
    GeorgiaTacoJM likes this.
  3. Oct 16, 2023 at 10:45 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Bronze Oxide
    Wow, glad you came here for advice. Here are a few suggestions:
    1. Move the clamps so they line up with the bolts that hold the rails on. Note those are only 6mm bolts, but it will still be stronger than the way you have it now.
    2. Don't overtighten the clamps. It's interesting that the rails are bent UPWARD.
    3. Add more mounting clamps if possible.
    4. Reduce the weight on the rack if you don't need everything for daily driving.
    5. Get bed stiffeners to strengthen the bedsides, which are carrying the load of the rack.
    I was just thinking that I should offer a bed rail upgrade the other day. Now I'm convinced we need it. If you look at the Jeep Gladiator / Ram TrailRail system it is an aluminum extrusion and WAY beefier than the sheetmetal rails that come on Tacomas and Tundras. I'll be working on this after seeing your post.
    Here are a couple pictures of the TrailRail on a Gladiator.
    kylecrish likes this.
  4. Oct 16, 2023 at 10:58 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    To be clear, when I say bed stiffeners.
    I mean all 4 corners. It’s not just the tail gate corners that crack.
    Racks with weight and bed flex crack the cab corners too.
  5. Oct 16, 2023 at 11:00 AM
    mrtonyd
    Tony
    Colorado
    is that from a gfc?
    did you have any stiffeners before it cracked?
  6. Oct 16, 2023 at 11:00 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
  7. Oct 16, 2023 at 11:04 AM
    TnShooter
    Deogee
    STOCK
    Not my truck.
    It is just one of a few examples that I’ve seen.
    In that particular case, no stiffeners were used.
    You need guys like @Kwikvette to fab up some stiffeners there.
    A few guys have resorted to sliding the “D” hooks up as close to the cab as they can and using a ratchet strap.
    You’re limited on design if you want a true “bolt-on” stiffener. The only mounting point is the channels or the channel bolt holes.
    Kwikvette likes this.
  8. Oct 16, 2023 at 11:15 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I was going to suggest as a partial fix that you put a thicker steel backing plate along the length of the rails, between the Toyota rails and the bed wall. But they are still light instead of heavy-duty ... anything that light at that length is super strong. The system shown above that is lower-profile and made of heavier-gauge material to the wall will bend less.
    Bed stiffereners at the back, front corner gussets like this to make the bed stiffer: https://www.tacomaworld.com/threads/bed-corner-gusset-tie-downs.476843/
  9. Oct 16, 2023 at 12:52 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Not a cheap option, but you could replace it with an 8020 extrusion. There's no way you'll bend it... it would obviously require some drilling and fab work to make it serviceable.
    https://8020.net/1575-black-fb.html
    McHale likes this.
  10. Oct 16, 2023 at 1:03 PM
    RichochetRabbit
    The bolts and the mounting holes holding on the ultra-light rails may be designed for far less weight than that rail you showed. In short ... nice idea, but the Taco bed and liner cannot handle it ... maybe.
  11. Oct 16, 2023 at 1:42 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Right now, the OP's rail is failing, not the rail mounting bolts. This solution would absolutely make the bolts the weak link, but that's not currently the issue the OP is trying to solve.
    If you wanted to address the mounting bolts, I'd recommend adding more attachment points by drilling more holes and adding backing plates behind the bed.
    Charvonia Design and soundman98 like this.
  12. Oct 16, 2023 at 3:10 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    May be worth adding holes through rail/bed and rivets. Keep in mind this is a light-duty pickup.
  13. Oct 16, 2023 at 4:39 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    30 Nm is not a lot (22 lb-ft). Those things only have to be snug. The flex OP is seeing is not from the channels, it's from the rack. Unless you turn the truck upside down, those clamps and rails aren't under a lot of stress. And there are a lot of other things to be worried about if you are turning the truck upside down.
    soundman98 and Bertw192 like this.
  14. Oct 16, 2023 at 5:41 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    this is what i see as well. the bed isn't moving, the rack is moving between itself. no amount of bed attachment is going to correct that. there's really no fix for that in a modular bed system like that. if it's unacceptable, you need to go to something more like heavy metal offroad bed bars.
    you overtorqued the mounting system to your rails. there's no way those will fall back to where they need to be. the side rails need to be replaced.
    i'd also take a very good look at the mounting system assembly to make sure you didn't gall the tightening mechanism, as is also extremely common when creating such a large force.
    essjay and Kwikvette like this.
  15. Oct 16, 2023 at 5:45 PM
    #35
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Uhg... Stainless steel galling has been the bane of my truck modding... first experience was on my Maxtrax mounts. Welded solid.
    soundman98[QUOTED] likes this.
  16. Oct 17, 2023 at 11:45 AM
    #36
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    First anything where you move from the attachment point and apply pressure will flex whether it be a connection point or the material. Stand on a “friends hood” did it flex? The only solution is to use structured material made not to flex and connect that to a solid base.
