My "Blank" Button Place-Holders Have Wiring Behind Them?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j.d.mason, Aug 10, 2015.
  1. Aug 10, 2015 at 7:23 AM
    j.d.mason
    j.d.mason [OP] Well-Known Member
    Toronto, Canada
    2014 White TRD Sport DCLB
    Hi All,
    I was removing my blank button place-holders in order to install my aftermarket switches, and behind two of them I found wiring harnesses/connections for accessories that I do not think I have. I was wondering what these connections are/would be for? Any advice would be appreciated!
    Thanks,
    Button #1 (in the middle location of the lower 3 button positions):
    Button #2 (in the right-hand location of the lower 3 button positions):
  2. Aug 10, 2015 at 7:34 AM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    I think the middle is the "DAC" (downhill assist control), and the one on the right is "RSCA OFF" (turns off airbags roll sensing airbags so they won't go off at "extreme" angles)
  3. Aug 10, 2015 at 9:35 AM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    That's interesting. I may have the switch connectors behind the blanks (haven't checked) but they are not clicked into the switch blanks like you have there.
  4. Aug 10, 2015 at 9:46 AM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    Which brand are you installing? I'd like to know how they eventually fit. Thanks.
  5. Aug 10, 2015 at 10:27 AM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    The wiring harness is the same for all trucks even if they don't have the optional equipment installed. its cheaper than maintaining a separate inventory for each option.
  6. Aug 10, 2015 at 10:36 AM
    Prerunner_gunther
    Prerunner_gunther Well-Known Member
    Scott
    If you were to say add the rsca switch with the wiring already there would you then have a truck equipped with that?
  7. Aug 10, 2015 at 10:52 AM
    bubbabud
    Bob
    Tonopah AZ
    No but you would have the wire in place to install it
  8. Aug 10, 2015 at 12:54 PM
    j.d.mason
    Toronto, Canada
    Wouldn't these options be there on my vehicle though (TRD Off Road)?
  9. Aug 10, 2015 at 1:48 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    No, you'd have to add the airbags and other equipment required for that feature to function. It's more than a wire and a switch.
  10. Aug 10, 2015 at 7:50 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    would be interesting to see schematic to see how these are routed, thru an existing Module, or one that only exists with the optional equipment. figuring out power, ground and eventual load my allow some useful repurposing.
    mahaloTaco likes this.
  11. Aug 26, 2015 at 3:13 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4Ă—4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    My be for factory alarm. Mine had it .key is coded that sensor allows you to start vehicle if equipped.
  12. Dec 4, 2015 at 9:08 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    Any news?
