My Brake Master Cylinder crapped out! $$$?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScrippsRanch67, Aug 11, 2022.
  1. Aug 11, 2022 at 8:40 PM
    ScrippsRanch67
    ScrippsRanch67 [OP] Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    My 06 Tacoma Quad Cab Pre-Runner V6 Brake Master Cylinder appears to have crapped out. (170,000 miles) How much should I anticipate to pay to have it rebuilt?
  2. Aug 11, 2022 at 8:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Rebuilt or replaced?
    I’d go with replaced?
    Bivouac likes this.
  3. Aug 11, 2022 at 8:42 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    The communication I got from the Dealership I believe says Rebuilt.
  4. Aug 11, 2022 at 8:45 PM
    TnShooter
    Deogee
    STOCK
    @Bishop84 do you guys rebuild them?
    Or replace them with a rebuilt unit?
    OP, I’ll check my labor guide and give you hours.
    But do understand, not all shops use the same labor guide.
  5. Aug 11, 2022 at 8:46 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Don't really rebuild master cylinders anymore, you either get a new or remanufactured one. As long as you have the standard master cylinder and vacuum brake booster and not the hydraulic booster I wouldn't think it would be too much to replace.
    TnShooter likes this.
  6. Aug 11, 2022 at 8:51 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    "wouldn't be too much" is relative....$1,000? $2,000?
  7. Aug 11, 2022 at 8:52 PM
    TnShooter
    Deogee
    STOCK
    Hydraulic MC - Remove and Replace is 3.0 hours
    Vacuum MC - 1.6 hours
    Remove, rebuild and replace
    3.6 hours for either system
    Again, this means nothing really.
    ScrippsRanch67[OP] likes this.
  8. Aug 11, 2022 at 8:52 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    Might be a hydraulic booster?
  9. Aug 11, 2022 at 8:54 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Do it yourself, parts are under $100 and the work is easy.
    Jimmyh, Bivouac and Dm93 like this.
  10. Aug 11, 2022 at 8:54 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Standard Vacuum booster and master cylinder
    Hydraulic booster and master cylinder
  11. Aug 11, 2022 at 8:56 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Standard master cylinder is around $100 aftermarket on rock auto, the hydraulic boosted one can be well over $1000.
  12. Aug 11, 2022 at 8:57 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I believe those are only on the TRD off-road to control the DAC/ATRAC, everything else would have a vacuum booster.
  13. Aug 11, 2022 at 8:58 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Some of the early build trucks (05-08) that had VSC had the hydraulic booster but they aren't very common.
    stickyTaco[QUOTED] and TnShooter like this.
  14. Aug 11, 2022 at 9:02 PM
    Bishop84
    Bishop84 Well-Known Member
    I wouldnt even rebuild my own, its kind of a dead art.
    Not a typical DIY item, simply because you have to do a very specific adjustment of booster to master that uses a special tool, or a specific wrench.
    Not sure what Toyota sells anymore, we havent sold many masters except for the 2017 model campaign.
    SUMOTNK, TnShooter and Dm93 like this.
  15. Aug 11, 2022 at 9:29 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    It's a Vacumn Booster
  16. Aug 11, 2022 at 11:03 PM
    Waasheem
    Waasheem
    2007 xrunner
    What symptoms do you have to feel it’s gone bad?
    Dm93 likes this.
  17. Aug 12, 2022 at 3:00 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    Refill brake fluid reservoir, pump the brakes, watch it empty of fluid. Weird noise-vibration in the brake pedal.
  18. Aug 12, 2022 at 3:14 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Where is the fluid ending up? The vibration in the brake pedal could be the ABS kicking in.
  19. Aug 12, 2022 at 3:18 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    The fluid has to go somewhere. Pull all 4 wheels and rear drums. Make sure none are wet.
  20. Aug 12, 2022 at 3:55 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @Bishop84 @TnShooter @Dm93
    In your experiences, how do the non-OEM brake master cylinders compare to a factory toyota unit?
    Reason I ask is because I purchased the SOS Performance Tundra/Sequoia master cyl upgrade for my tacoma. Included is a new (non oem) master cylinder....looks like an AC Delco or Centric unit.
    I've been holding off on installing this upgrade because I've been thinking about using a geniune toyota sequoia master cylinder versus the Delco/Centric one because I dont know the rep that they have when it comes to hydraulic brake components.
    If you guys think I'm overthinking it and the non OEM one are good enough...please share your advice. Why I havent purchased a new toyota cylinder is due to cost. Thanks
